Second set of monitors?
All is well, at Angel Towers, no major concerns about the studio, but I’ve expanded on a side table, so the whole set-up is in a big L shape, monitors and computer in front, keyboards etc to the side, so I need another pair of speakers.
I’m OK when mixing etc, but I need another set for when I’m sitting at the synths, as I can’t hear very well to the side. I’ve got a hi-fi I could have used, but my partner has commandeered it for conservatory music duties.
I can’t think, do I say goodby to my Behringer monitors, and use those for programming, getting a better pair of main monitors, or should I just get a cheap pair for programming and keep the Berry’s as usual?
Yours, confused.
Posts: 19884 Joined: Sat Jul 12, 2003 12:00 am
Re: Second set of monitors?
Post by resistorman »
Same thing happened to me. I bought Eris E5XTs with an Eris Sub 8 for synth duties. A lot of fun and surprisingly accurate, though maybe a bit too flattering for critical mixing. Still, it’s nice to shake the room up a bit with those low notes for extra synth inspiration.
resistorman
Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
I don't think I have ever read an SoS review of the Behringer monitors? You seem to rate them and in truth (see what I did there!) I have not read anything bad about them but maybe this is an opportunity to get something REALLY top notch?
Phil Ward was very taken with a pair of (Polish?) speakers a while ago and I think they were sub £1k5 a pair?
Regarding the 'stolen' hi fi speakers, bit risky putting synths through them unless they were unusually massive?
Posts: 18116 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by MOF »
The KRK range are very good value for money. I’ve got the VXT6 version.
https://www.krkmusic.com/
MOF
Posts: 2472 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
Post by ore_terra »
MOF wrote:The KRK range are very good value for money. I’ve got the VXT6 version.
agree. the non rokit KRK's are good and usable.
ore_terra
Posts: 1083 Joined: Fri Dec 02, 2016 12:56 pm Location: Seville - Spain
casmoestudio.com
Post by Mike Stranks »
Yup! :thumbup: I have the VXT4s
Mike Stranks
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
I'm going to plug the Adam T5Vs again, I have no connection with them but when I went to listen to some with a friend last year they were definitely the best in the sub £300 category to my ears.
Posts: 28072 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by shufflebeat »
blinddrew wrote:I'm going to plug the Adam T5Vs again, I have no connection with them but when I went to listen to some with a friend last year they were definitely the best in the sub £300 category to my ears.
I'll second that. My meagre folkie offerings translate much better to the car and other systems since I started using them.
shufflebeat
Posts: 9728 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Post by uselessoldman »
I have a set of Adams T7Vs and love them to bits. Besides the 5 yr warranty when I was researching and testing studio monitors I found them to be miles better than anything in their price range and better than some that cost significantly more.
I found the 7s had just that little more bottom end punch than the 5s, yes they do cost a little bit more but worth it.
uselessoldman
Posts: 246 Joined: Sun May 03, 2020 7:39 pm
Dave, the Berry’s are absolutely fine, for the money, they don’t have any major glaring issues, that distract me, I can remember searching very hard at the time for something cheap and cheerful, and these were the best of the bunch, and of course, over the years, my ears have got even more used to them.
In my last flat I had loads of spare speakers that never got used, but now I’m in this house, they’ve all got used up, on various things.
Monitors I’ve heard and liked, what I call "serious" ones, are Event Opals, ATC SCM20 Pro, SCM25, and the venerable Yamaha NS10, I always liked I like a lean sound, so many monitors seem to have a bass hump, another one I liked was the Acoustic Energy AE1.
The Presonus system with the sub as mentioned here sounds like it could be good for programming, I like their stuff, I may give them a try anyway, but for main monitoring, I really don’t know, if I replace the Berry’s they will be used for my synths anyway.
OK, decided no sub, could be really bad, I just need two speakers.
Prepared to spend on either of these two, Eris 5 XT, or Adam T5’s, any overall opinions appreciated, it’s no big deal, I don’t want to ad any more to the equation, either of these could be good.
How are you planning to switch between these two sets of monitors?
Posts: 42194 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote:How are you planning to switch between these two sets of monitors?
It’s OK Hugh, it’s two separate systems, I’m mixing and monitoring off the computer interface on the computer table, the monitor out on my MixWix will be connected to the synth table monitors, I don’t need to switch from one to the other, I’ll always be using the new speakers at the synth table.
Taking delivery of a pair of Genelec 8030's, today, don’t worry, I haven’t bought them, a friend is clearing out, and he no longer needs them, this is going to be very interesting, as I’m not a fan, but I’ll see how they sound in the basement, I’ll report back.
I get the feeling these won’t be anywhere near the going rate, so whatever happens they may be tempting, unless I totally hate them!
Post by ConcertinaChap »
I've still got my Genelec 8030s that I replaced with a pair of KH120s years ago, so the Genelecs got moved into the studio recording area because I couldn't bring myself to sell them. There they're doing sterling service and I've always thought they run the KH120s surprisingly close. If you've got the chance to buy them unusually cheap and they're in good nick I'd say don't let them get away.
I'm a bit of a fan of Genelec speakers and elsewhere in the house I've got a pair of 8020s and another of 6010s all earning their keep.
ConcertinaChap
Posts: 14408 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Mr Punch's Studio
In my defence I was unsupervised at the time.
ConcertinaChap wrote:I've still got my Genelec 8030s that I replaced with a pair of KH120s years ago, so the Genelecs got moved into the studio recording area because I couldn't bring myself to sell them. There they're doing sterling service and I've always thought they run the KH120s surprisingly close. If you've got the chance to buy them unusually cheap and they're in good nick I'd say don't let them get away.
Interesting, what do you particularly like about them?
They sound OK to me, but I’m not sure I’d like to spend even this amount on them, I listened to them last night, they sound a bit forward, and larger than life compared to my Behringers, could be a good thing though, especially for playing synths through, programming.
But then you've got used to the sound of the Bs and that is now your 'normal'.... :)
Mike Stranks
Yes, that’s true, but if I’m going to be spending serious money, to me, more than the Berrys,
then the new ones have got to be an undoubted obvious improvement, like, wow!
The Geny's are good, I’m not putting them down, it’s as you say, my ears have got used to my monitors, so they feel more "comfortable" familiar, even though ultimately they may not be as good.
I think I’m going to have to pay a lot more, up into the thousands, to get something that’s going to be a definite improvement, but then again, what’s the point in that? My room is untreated, and has issues, this is why I’ve never bought anything else, or got further than tentative enquiries.
It was good though, borrowing these monitors, it’s made me think a bit more about the whole situation.
ONCE upon a time... the quality of speakers, both in the upper echelons of 'hi fi' and studio monitors was compared to REAL acoustic instruments!
I would say the ideal of becoming 'imprinted' on a set of speakers would be totally alien to the old guard that I was brought up with? People such as John Crabbe, Angus McKenzie (Hi Fi News) Hugh Ford (Studio Sound) Peter Walker (Acoustical 'Quad') Percy Wilson and many others that went to CONCERTS!
Comparing speakers to 'speakers' is to me a Zanzibar fallacy.
Ok, apart from that rant Arp'. Having a "less than perfect room" is to me no obstacle to getting some highly accurate monitors. Surely the listening experience can only be enhanced and at least you know you have a solid baseline from which to consider treating the room? Cannot have a silk room with pig's ear speakers!
ef37a wrote:ONCE upon a time... the quality of speakers, both in the upper echelons of 'hi fi' and studio monitors was compared to REAL acoustic instruments!
I’m happy though, with my speakers, if not I wouldn’t be using them, my recordings are OK, I can hear what I’m doing fine. What I’m saying is that there isn’t such a big difference between certain speakers, in the real world of my studio.
There are various schools of thought, like you say, comparing with the natural sound of acoustic instruments as a reference point, that’s fine, and I agree, if you’re working a lot with acoustic instruments, or making classical recordings, that’s a good way of judging things, but I don’t work with acoustic instruments most of the time, and I have no real world reference, as the sounds I make haven’t been heard before, largely, so there’s nothing to be compared, in this scenario, I go for a speaker that sounds best with my music or the type of music I make, that’s where comparing speakers with speakers comes in, what else am I supposed to do?
When I record piano and Marimba here, it sounds fine on my speakers anyway, this whole thing about reference points, the whole monitor shebang, is all a bit of a joke sometimes, you just have to go with what you like, and that’s it.
Sorry, just picked up on this thread again. I like the Genelec monitors because they have a nice clear sound that is not dissimilar to my KH120s (now my main monitors). I particularly like the way that sound is common across the family which makes moving between the various monitors (and to the KH120s) unproblematic. Almost all my recording is acoustic and very little with the synths, which suits them well. However when I have listened to electronic music on them I have not felt discomfited. Also they feel well made (another trait they share with the KH120s).
At the end of the day they're just nice speakers.
ConcertinaChap
Mr Punch's Studio
ConcertinaChap wrote:Sorry, just picked up on this thread again. I like the Genelec monitors because they have a nice clear sound that is not dissimilar to my KH120s (now my main monitors). I particularly like the way that sound is common across the family which makes moving between the various monitors (and to the KH120s) unproblematic. Almost all my recording is acoustic and very little with the synths, which suits them well. However when I have listened to electronic music on them I have not felt discomfited. Also they feel well made (another trait they share with the KH120s).
Hmmm? I used a pair of K+H 110’s for awhile, they were OK too, but I had to give them back, are the 120’s any different to those?
:think:
No idea, sorry.
ConcertinaChap
Mr Punch's Studio
