How can I separate this background horn music from the audio?
Post by Down102 »
How can I separate this horn background music from this audio. Sorry if any of you are having a hard time listening to the horn in the background. The reason why it's hard to hear is because I edited the original audio.
You can still hear the background horn in the audio but it is very low because I edited the original audio so much. The horn music is most likely made by a synthesizer. It's pretty much the only music in the audio. The other sound that's mixed with it is basically the sound of a wooden floor cracking.
Now what I truly want is for me to separate the wooden floor cracking sound from the horn music. How can I do that? Are there any softwares that can help me with this? I tried using Spleeter but it still didn't do it. I tried using Noise Reduction, Vocal Reduction, and Vocal Isolation in Audacity but it only made the audio low quality and low volume.
How can I fix this?
By the way, the audio is in the link below.
https://m.soundcloud.com/heehahahaa/mysterious-sound
Down102
Posts: 1 Joined: Thu May 06, 2021 12:46 am
Re: How can I separate this background horn music from the audio?
Post by Fishnish »
If I were faced with this task I'd probably start by reaching for Izotope RX's Spectral Repair, but I wouldn't be too confident of getting a perfect result. Izotope RX itself is pretty powerful but my own spectral editing skills are only fairly basic, it's still quite detailed + time consuming work for me. Removing short sounds like squeaks, bumps, the occassional fluffed note, traffic and wind noise is pretty easy but long sections can require a fair bit of work.
Recently I've been wondering about Spectralayers too. Mainly because I'm a Cubase user and a slimmed down light version of it is included in the latest version of Cubase. Not sure how the full Spectralayers compares to the Izotope I already have though, and whether it would sit nicer with Cubase than RX does.
Fishnish
Posts: 233 Joined: Fri Dec 24, 2010 12:00 am
Let us hear the original audio - the sample you put up is too mangled to give any idea of the problem.
Posts: 15859 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
