Expression Pedal Recommendations?
It would be plugged in to one of the controller inputs of an IK Multimedia AXE I/O interface, and would be primarily for wah / volume, though I could imagine other creative uses, so versatility is always welcome.
Thanks,
Thanks,
BWC
Re: Expression Pedal Recommendations?
I use these in my keyboard rigs https://www.andertons.co.uk/guitar-dept/guitar-pedals/volume-expression-pedals/moog-moogerfooger-ep3-expression-pedal
They just do the one thing they’re supposed to well. Have had one of them for at least 7 years + and it’s had some hammer! But still works great.
The AXE I/O manual doesn't specify what sort of expression pedal is required apart from 'will work with any 1/4" TRS expression pedal', which I think is rather poor. Does the fixed voltage go out on the tip and the signal come back on the ring, or the fixed voltage go out on the ring and the signal come back on the tip? What is the maximum and minimum pot resistance that it will work with?
Whilst some pedals (like the Moogerfooger one) have a switch so that it can work in both modes, not all expression pedals do, and if you get the wrong one, then it won't work properly (or you have to rewire the cable to suit, which isn't great if you can't solder).
Another vote for the Moog pedal. I have one and although it hasn't had much use it's been 100% reliable and is well constructed. The minimum output pot control is also a useful feature.
I've no idea how they're designed these days, but the best ever that I came across had a lamp and an LDR. The pedal worked a vane between them. Beautifully smooth, with no pot to wear out. This was in the 1960s and was specific for a lugable simple organ
- Folderol
Jedi Poster -
Posts: 19918 Joined: Sat Nov 15, 2008 12:00 am
But I expect that LDR was a CdS device. RoHS rules mean they can't be used in new equipment because of the cadmium. Which is why I need to finish off replacing the noisy add-on tremolo board in my 68 Custom Deluxe Reverb amp with the lamp/LDR 'roach' they fit in the US.
And they are just pots, typically 25k, 50k or 100k, wired as potential dividers. Sometimes with a second pot wired as a variable resistor to provide a non-zero minimum setting facility.
Thanks Wonks. Pretty much as I suspected.
Incidentally, you can still get LDRs from RS (prolly Farnell too). I expect they'd work quite well with a yellow or green LED
- Folderol
Jedi Poster -
I like the Yamaha FC7. The pedal angle range can be configured for sitting or standing positions, and there is an adjustable spring-return 0-10 degree 'overpress' action if required for emphasis 'stabs' which can be handy. It has a 50k pot and the wiring obviously suits Yamaha keyboards, but I've not had any problems with any of the things I've plugged it into so far.
Posts: 42222 Joined: Fri Jul 25, 2003 12:00 am
The Moog certainly looks like a solid choice. The other one that caught my eye while browsing is the Yamaha that Hugh likes, and for exactly those reasons.
What I saw in the manual was a little different, but not really any more useful or detailed. I suspect, in keeping with the overall design philosophy of the thing, it's able to cope with as many scenarios as possible, and offers software control of curves, and ranges, and whatnot. For the record, a little soldering is not a problem for me, though my lazy side objects.
Thanks,
Wonks wrote: The AXE I/O manual...
Thanks,
BWC
Folderol wrote:Thanks Wonks. Pretty much as I suspected.
It’s like 60/40 solder. You can still get it and use it for repair work but can’t use it commercially any more.
I’ve bought a pre-assembled ‘roach’, and have already removed the add-on board (I fail to see how they couldn’t design a circuit that didn’t make an audible tick every cycle). I just need to fit the ‘roach’.
Apologies for the thread hijack but as I started I may as well finish...
Just soldered the 'roach in' and I now have an almost noiseless trem/vibrato. There's still a very faint pulse in the background, but its far quieter than anything I could get with the add-on board, and replacing the circuity driver valve may make it even quieter still. The add-on board had a trim pot to minimise the pulsing noise, but even the best adjustment couldn't make it silent. When playing, the noise got hidden, but when you stopped, back it came. It's now fully useable.
This will be the case in most of the Fender reissue amps built after RoHS came into effect in 2006, including the 65 Deluxe Reverb, or any other Fender amp that uses a LDR trem/vib circuit. And it's a pretty simple fix to replace the add in board with the lamp+LDR 'roach' and it will cost less about £10 for a pre-assembled 'roach'.
Wonks wrote: Apologies for the thread hijack...
Eh, these things happen. I'd think that there'd be a modern, fully compliant, optical expression pedal on the market, but I haven't come across one. Anyone know of such a thing?
BWC
I don't know of any. The fact that it's an expression pedal means that you don't get the audio path going through it, just a control voltage, so if the pot did become slightly scratchy, you wouldn't hear it in the same way as you would as if it was a pure volume pedal with audio going through it.
A pot-based expression potential divider pedal can work with any extra-low DC voltage level likely to be thrown at it, say from 15v dc down to millivolts (though 9v and 5v are more likely). An optical pedal may need to be built for a specific input voltage, or else ignore the provided input voltage completely and have its own selectable output voltage range.
And optical volume pedals like the Morley 20/20 volume pedal are expensive (more so in the UK than the US), so I'd expect an optical expression pedal (if anyone made one) to be similar. If you've got a mid-price keyboard and want three expression pedals, by the time you've got three optical ones, you could have spent the best part of the cost of the keyboard again. Pot-based expression pedals are certainly far more affordable, and most can be DIY repaired by replacing the pot.
Using a splitter cable (TRS to 2 x TS) it should be possible to use a basic optical volume pedal as an expression pedal with a TRS style expression connection (provided the volume pedal doesn't have any DC blocking capacitors in the circuit). Whichever of the TS jacks provides the constant voltage output, then that goes in the input to the pedal and the other TS jack goes into the output of the volume pedal.
Any more complex optical pedal with boost functions is likely to have DC blocking capacitors, so your DC voltage will never get through. I've read on the web that the Morley 20/20 volume pedal can be used as an expression pedal, so that indicates that there aren't any DC blocking capacitors, but I can't guarantee it. It's also expensive and large and needs its own power supply, so will take up a lot of real estate on a pedalboard. Also, I once had a Morley Power Wah, and I couldn't get on with the range of pedal angle; it was all wrong for my feet and I had aching ankles after 30 seconds or so. On an angled pedalboard I'd imagine it would be even harder to use. But YMMV.
Just to clarify, the one I was referring to had the LDR in the signal path. There weren't any voltage controlled amplifiers in those days. The organ was populated entirely with discrete transistors - mostly germanium ones. If I remember right, the only silicon ones were in the 12 (yes 12) master oscillators, so the instrument was semi free-phase.
- Folderol
Jedi Poster -
Yeah, that's what I thought, not worth it when a potentiometer will do well enough, but you never know, I've seen crazier things brought to market.
So, I think I might prefer the Yamaha to the Moog, but looking again, it looks like the Moog has the advantage of being easier to keep out the dust, and hair, and such. Hard to be sure from pictures, any thoughts?
BWC
Hair and dust are going to find their way in on any pedal with a pot, a treadle and a notched gear arm to operate the pot. It's a fundamental law of nature.
Otherwise you are balancing the facilities of the Moog's minimum output setting and tip/ring input selection switch with the Yamaha's fixed connection configuration (without doing any rewiring) and the adjustable pedal angle . Both have 50k pots.
The Yamaha has a fixed 5' cable, whilst the Moog has a TRS socket and comes with a 6' TRS/TRS cable. Both fine for under keyboard use, but the Moog is more flexible if you want it further away from your device by simply using a longer TRS/TRS lead.
With this interface, I don't think the controls of the Moog will be needed, though I can't be 100% sure of that at this point.
I've never been fond of fixed cables, mainly because of the extra effort required if they need replacing, but an extension could always be added if more length is needed. In this case, as little as 4' would be plenty.
Neither pedal is terribly expensive, I might just have to order them both.
...unless anyone has any other options worth considering...
BWC
There's a company Lehle that has developed a magnetic system :
https://lehle.com/EN/Lehle-Dual-Expression
I don't own one but I was looking at volume pedals and saw the Lehles. It seems like a good concept -- nothing to wear out.
The Yamaha pedal has been sat on the floor in my studio for years and, despite the tumble-weeds of dog hair and dust that occasionally manifest, I've yet to have any problems with it at all.
The Lehle pedal is an interesting design, and obviously very versatile. But very expensive, and while the sensor won't wear out, you do have yet another power supply to remember and rig up. And I reckon I could change quite a few pots in the Yamaha pedal for the extra cost of the Lehle!
Hugh Robjohns wrote:The Yamaha pedal has been sat on the floor in my studio for years and, despite the tumble-weeds of dog hair and dust that occasionally manifest, I've yet to have any problems with it at all.!
One day you'll actually get round to plugging it in.
It's a digression into volume pedals but --
I was looking at an Ernie Ball MVP which is also expensive for what it is. Built like a tank, though and they have the best actions. They use a string and rollers and ... well it felt right when I tried it (Pre-Covid). It also has gain boost, so yes that would need power, but for me it's just another connector on the daisy chain. So given I was already in that ballpark the Lehle didn't seem that expensive.
Scratchy pots. You just know it's going to go in the middle of a gig, or without sufficient time to change it before the gig.
Perhaps not quite so important for an expression pedal.
The Lehle does seem cool, but is a bit more than I'd like to spend on this right now, and for my current setup, I'm not loving the additional power supply.
As for poorly timed failures, for the price of the Lehle, you could get several of the Moog or Yamaha pedals for backup.
BWC
