Isomorphism FTW
Re: Isomorphism FTW
I've been looking out for the rare/discontinued Axis 64 for years now. I thought I might be within reach when one turned up at Vemia a few weeks ago, but was outbid at £1100, plus fees and delivery. That's just too much.
There's another one for sale at the moment on Reverb, but it's even dearer at £126K...
...behold the original prototype for the Axis 64. Now, that's cool.
https://reverb.com/uk/item/47445296-the ... ru-axis-64
There are currently only two hexagonal MIDI controllers commercially available; the Lumatone and the Microzone, both well over $3K. But I still think the Axis 64 had something special going for it, and I'm daydreaming about trying to build a clone. I think I found just the keys for it.
https://wooting.io/lekker
This is a new Hall-effect analogue key in the Cherry MX format. (The Lumatone uses Hall-effect keys. These produce a continuous range of values rather than on/off, thus velocity.)
To my surprise, I recently found these are already available to order, and comparatively cheap. I've ordered half a dozen to start with, though if this works out I'll need a few hundred more. (And a crash course in Arduino key-scanning libraries.)
Re: Isomorphism FTW
I originally came across these optical ones...think they might be out of production and selling off old stock, though I'm not sure. (I'm also not certain if these are entirely self-contained, or if they're just part of the sensing mechanism.)
https://wooting.store/products/analog-f ... s-big-pack
I contacted them via the address on that page to ask, and they suggested the Hall-effect ones instead, although I don't see them advertised anywhere. But they let me order half a dozen which are apparently now on the way.
Here's a blog from a few years back where they describe the different technologies.
https://blog.wooting.nl/analog-input-te ... keyboards/
They produce "gaming keyboards" where individual keys provide a range of analogue values for use with compatible software, but potential applications seem much wider, and I think they're hoping they'll catch on.
It's very difficult to find light, comfortable buttons which can be used to deliver velocity information, so they could be onto something.
Assuming they work...what's the best way to sample the state of a couple of hundred of them with a Teensy to get note-on velocity values?
(The original Axis used a custom silicon-rubber overlay with concentric carbon contacts. Velocity was calculated from the timing between the two consecutive connections.)
*edit*
...oh, looking at those keys again, I don't reckon they include the Hall-effect sensor, just the magnet that activates it. In the same way, I think those Flaretech optical keys only have half the equation.
Never mind; still interesting. If this is the case, you can pick up bundles of Hall-effect sensors fairly cheap if you know what type you want. Hopefully they can advise.
Re: Isomorphism FTW
It's been a long wait, but I logged into Reverb this morning for my routine check for interesting new MIDI controllers, and this flashed up, listed a few hours previously.
I didn't hesitate for long; I knew it would be gone in a day or two. They rarely appear, could be another year until another one turns up, and I've waited long enough for one of these.
First thing I'll do is peel off those dumb note stickers, then get to work on the Harmonic Table.
Re: Isomorphism FTW
Nice!
- resistorman
Frequent Poster (Level2) - Posts: 2679 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Re: Isomorphism FTW
Well done Ben - all things come to those that wait eh?
Posts: 20599 Joined: Wed Jan 13, 2010 8:44 am
Re: Isomorphism FTW
Nice one.
I have one of the 49 ones somewhere, I wonder where it is...
- Guest
Re: Isomorphism FTW
Intuitive Instruments, creators of the Dualo, have posted a video for a new hexagonal MPE keyboard that's currently in development. Hopefully see this on Kickstarter at some point.
https://www.youtube.com/watch?v=xXQuLvs ... nstruments
Re: Isomorphism FTW
Now available on Kickstarter...
https://www.kickstarter.com/projects/du ... =user_menu
I think this is the first MPE hex-layout keyboard. I'm in.
Re: Isomorphism FTW
It seems very good value at the early bird 229 Euros price, and I somehow doubt that you'll be flummoxed by the lack of casing on the controller.
Re: Isomorphism FTW
So is there an advantage to this layout for playing scales or chords?
Or is it like any good instrument - you put in your time, you get results.
- ManFromGlass
Jedi Poster - Posts: 6645 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
