Dynacord PowerMate 600-3 with active speakers
Post by george_vel »
Hi everyone!
This is a powered mixer and there are outputs on the rear side for passive speakers.
But how can I connect active speakers to this device?
I do look for a mixer that is able to support both options (passive and active speakers) and want to know is this one capable to do it. From what I read so far, I am not sure how active speakers can be connected to the 600-3... or, is it possible at all?
george_vel
Posts: 190 Joined: Sat Mar 10, 2018 3:03 pm Location: Sofia, Bulgaria
Re: Dynacord PowerMate 600-3 with active speakers
Post by Mike Stranks »
Here's the manual: https://products.dynacord.com/binary/User%20Manual_Handbuch_PowerMate%20600-3%20(EN-DE).pdf
You can use the MASTER A (41) or MASTER B (43) outputs - as referenced in the manual - to connect powered speakers.
Mike Stranks
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
As far as I can tell, you can connect active speakers to the Master A XLR outputs on the top panel.
There's a block diagram that tells you what you need to know at
https://products.dynacord.com/binary/ED ... 20600-3%20(EN-DE).pdf
Posts: 15868 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by shufflebeat »
...faster than a speeding management consultant, the flying fingers of the SOS come to the rescue yet again - in duplicate!
Nice little mixer amp, btw. If you don't have the metal cover for the front panel, get one.
shufflebeat
Posts: 9718 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Thanks, Masters!
As always, you rock! :mrgreen:
george_vel
