FREE mac Plug ins....
Re: FREE mac Plug ins....
Post by Stevie4Music »
What a find!!!!! These plugs are astonishingly high quality.
And the 101 clone - it brings back memories for me to. SH101 was my first synth as 16: the fundamentals of synthesis I learnt on that exquisite machine have stood me in great stead over the years. I can't think of a better synth to learn on.
I remember dreaming of having a whole orchestra of SH101's - and now I can do it: I've just loaded up 16 instances into logic and am having a ball!!!
Back in 1989, I eventually ended up with two, and used to run them with a TR606 and a Seq. Circuits Pro One. What a meaty set up that was... At gigs I would program the 101 sequencer on stage between each song..... I was very proud of that feat!
This whole suit is the best set of free plugs I have come across by a mile.
Thanks for the heads-up: you've made me a very happy bunny and given a much needed injection of inspiration to my workflow...
S.
Stevie4Music
Posts: 5 Joined: Wed Jan 28, 2009 12:00 am
Post by Dr_Jezz »
Dr_Jezz
Posts: 15 Joined: Sun Jul 06, 2003 12:00 am
Post by jayzed »
QUOTE: Line 6 are giving away Pod Farm for free until 30th September if you have an iLok or other Line 6 hardware.
And the buggers had the cheek to send me the email offering this, after I'd paid the $US for the very same thing!
jayzed
Posts: 507 Joined: Fri Mar 19, 2004 12:00 am Location: North London
Post by Andrew Hutchinson »
It's been mentioned on these fora before, but SPL are giving away their "Attacker" plug free, until 15 Nov., as well as the free ranger, a diminished version of the standard graphic, inductor EQ. The attacker is, as you would imagine, the first/left half of the Transient Designer. Neither requires an iLok, and are available in all three formats, as far as I know. I only downloaded the AU, since that's all I use.
Andrew Hutchinson
Posts: 36 Joined: Mon Jun 30, 2008 12:00 am
Post by ken long »
Hi any analysis tools floating around? PPMs, phase scopes, etc?
ken
ken long
Posts: 3594 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
Post by DaleSmith »
blue cat audio do a great set of free plugins. they include a really analyser, not sure about a phase scope tho..
DaleSmith
Posts: 261 Joined: Tue Apr 29, 2008 12:00 am Location: Hull, UK
Post by ken long »
Thanks Dale! :bouncy:
ken
ken long
I'm All Ears.
Post by Scope »
jameslerouge wrote:well i know about these plug ins from dont crack, so i was not completely over the moon, anyhow, having become a recent convert to the MAC, i want really some advice, i have always used cu base on my pc. i now want to try out some other software, but not buy just now, does anyone know of any where to get hold of some software much the same as cubase, or indeed a version of cu base i could use meanwhile, as i am rather lagging and dwelling on this one, and i fear i will have to purchase cubase again, which terrifies me. Any advice on a good program, well, i would be seriously grateful!
take a look at this thread :-
Cubase AI - For FREE ( and its all legit ! )
Scope
Posts: 550 Joined: Mon Jul 03, 2006 12:00 am
Post by Ian Shaw »
A nice one here: TCElectronics
Three days inly , so go get it!
Ian
Ian Shaw
Posts: 181 Joined: Wed Dec 22, 2004 12:00 am Location: Somerset
'...and when we got bored, we have a world war...'
Post by ruchis »
The plug ins information is very nice to work on. It gives a lot of think to work on it. It really gives me a lot of good explanations there to make it my job more easier. Thanks for sharing with us.
ruchis
Posts: 1 Joined: Sat Nov 21, 2009 12:00 am
VFX app - PC CSTs in Mac OS!
Post by Dr_Jezz »
As I posted in the main forum:
VFX application - anyone using it?
I did a search to see if this has been discussed, but couldn't find anything. I'm going to post this in the freeware VST sticky, because it seems to allow you to run PC VST FX in Mac OS and there are many free ones out there! I'm trying this now - anyone else had much success with it?
Here
Dr_Jezz
Re: VFX app - PC CSTs in Mac OS!
Post by Dr_Jezz »
Still evaluating above post since my new Apogee started annoying me, but can't remember if anyone's mentioned any of the Stillwell stuff (as used by Mix Rescue) - They're not FREE - but you can check them out without limit - and as far as I can hear so far...... I'm about to PAY (the very reasonable cost) for at least 3 since I found out - amazing. Between these and TAL, I'm lost for typos ;) here
Dr_Jezz
Post by gridlocked »
midiot wrote:Hi-
I am a pro composer/musician, working for 3 USA networks, so my list of plug ins is embarissingly deep and way too expensive, but in many ways, the most inspiring plug in I have ever used in terms of creating new ideas's from static grooves is a free plug in called Live Cut, from Mcdsp software.....combined Livecut with a drum groove generator like Stylus RMX, EZDrummer, etc. is just fantastic...the comapny asks for a donation, and i sent them 30 bucks, thinking i was insulting them, but was told in a reply that that was the most they had ever received, so a 5 dollar paypal transfer would make you both happy. its still free if you choose not to, but once you try it, you will want to help them develop this great tool even more
it is basically a low cpu drain AU/VST plug-in used as an audio track insert (in DP mixer at least) that takes any audio on that channel and slices it up in real time...it has a ton of controls to modify, randomize and repeat the slices, as well as a "Squarepusher" contol for the truly adventurest jungle/D&B/chill/trance madman in you.....it never fails to amaze me what comes out of it, and you can record it free form as you dial away and then edit the best bits....works on any audio, and as a sidebenefit, when used with Stylus RMX; it mutes the output of stylus rmx when you stop or pause DP. hit play and you are back to groovin. I believe you can search for it in SOS, as they gave it a very nice mini review a few months ago
imho, it's just an Amazing Drum & Bass tool, and it beats the heck out of improvising ideas over a static 2 bar drum loop.
Beta bugs chorus is another nice fx, as is Crystal synth....i wish they would charge for crystal and put the money into even more developement, so get it while it is still free.
hope this is of some help. good luck
Is this plug-in still about anywhere? I'm looking for a glitch / stutter / randomizer sort of plug in for the Mac! (Running Logic 9.1)
gridlocked
Posts: 13 Joined: Thu Jul 26, 2007 12:00 am
Post by ainternational »
A quick Google search reveals this page: http://mdsp.smartelectronix.com/livecut/
Looks tasty - I'm going to try it, but please let us know how you get on with it...
I'm after something that does something similar to the roll effect on the Pioneer DJM mixers: anyone know of a freebie out there that'll do this?
ainternational
Posts: 81 Joined: Thu Apr 24, 2003 12:00 am Location: Amber Valley
Amazing...I tried searching and came up with nothing! I'll let you know how I get on with it...
gridlocked
Post by Dr_Jezz »
couldn't edit my original post, but the original link explains how I found this stand-alone utility unworkable for me.
Dr_Jezz
Post by trouser_snake »
will definitely check alot of these out. ive just got into downloading au units for my macbook, is there a danger that any units will damage or interfere with the running of my mac? ta
trouser_snake
Posts: 29 Joined: Fri Mar 21, 2008 12:00 am
Post by DaleSmith »
Hey. Ive downloaded over 100 free AU plug-ins, and they all work fine, running Logic 8.
cheers
DaleSmith
Post by DaleSmith »
http://www.dontcrack.com/freeware/audio-software.php/id/11300/downloads/Togu-Audio-Line/
a couple of great additions to the TAL range.....
I've not tried the new reverb or eq yet, but if the early plugins are anything to go by, these will be very good indeed!!!!
DaleSmith
Post by Guy Johnson »
Looks good, thanks!
Guy Johnson
Posts: 1336 Joined: Fri May 02, 2003 12:00 am Location: North Pembrokeshire
This is my few words.
Post by DaleSmith »
http://www.meldaproduction.com/freevstplugins/
just found these!!! not used em yet, but they're free....
DaleSmith
Post by jonpuget »
Just found these when I was checking out Flux trax
Stereo Tool and Bitter Sweet ii
Haven't used them yet:)
http://www.fluxhome.com/products/freewares/bittersweet2
jonpuget
Posts: 44 Joined: Sat Jan 20, 2007 12:00 am Location: dublin, Ireland
Post by DaleSmith »
not tried the 2 free bundles yet but they look promising.
www.acustica-audio.com
DaleSmith
Post by geoffbrecker »
I've checked a lot of these before but I got some new ones too.
You can never have enough money, sex or plugins.
Thanks man.
geoffbrecker
Posts: 4 Joined: Fri Oct 15, 2010 12:00 am
