DIY question - using a transformer as an inductor
I've been looking at some guitar circuits (like the Gibson Varitone and LS6) and Wah pedals that use inductors. And it's not easy to source small inductors from 1/2 a Henry through 1.5H to 7H, but a lot of what I've read suggests using signal transformers like this as an inductor.
Of course, regular readers will know that I am in need of help, but specifically what I am asking is whether there is a simple method of calculating the inductance of the primary and secondary of a transformer like this. Everything thing I've found so far starts fine but then descends into gibberish... ie. 'You count the number of turns and wibbly wobbly bibbly bobbly bob, obviously'.
Maybe Hugh, Dave, Folderol, or one of the other smart guys here could help.
Posts: 13022 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Re: DIY question - using a transformer as an inductor
Post by dmills »
Strap a small cap across it and find the resonant frequency by injecting the output of a signal generator through a few K ohms of resistor and watching the voltage across the transformer with a scope or high impedance audio millivolt meter, once you have found the resonant peak then apply
f = 1/(2 * Pi * sqrt(L*C)) with your known values for f and C to find the inductance, easy.
Moderators: Can we PLEASE have LaTex support on this forum, $$\math {2^2}&& works on the OU forums and is useful, it would be nice here as well!
Regards, Dan.
dmills
Posts: 1533 Joined: Fri Aug 25, 2006 12:00 am Location: High Wycombe, UK
Audiophiles use phono leads because they are unbalanced people!
That's probably the only practical way to do it, but not a lot of help if you don't have a box full knocking around, and are looking up catalogues.
Might be worth contacting somewhere like Oxford Electrical Products explaining the situation and telling them what sort of inductance you need.
P.S.
In theory you could calculate it from the DC resistance and the impedance, but there is a slight problem. Impedance only really applies to a single frequency and they never say what frequency the impedance is measured at!
Posts: 19899 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by grab »
The easy answer is "find someone with an LCR meter". :) If you were anywhere near me, I could lend you mine, but you're a bit far for that. (Own trumpet: I won it for "letter of the month" in EPE with a quick and accurate method of rescaling 0-1023 to 0-999, which you often want for reporting 10-bit ADC measurements on PICs and Atmels.)
Also be aware that it's not just primary and secondary inductances but also the effect of the transformerness (to avoid wibbly words), which will change the overall inductance depending on how the secondary is connected.
As Dan says, if you have a sig gen producing a sine wave and a meter that can do true RMS (i.e. not fixed at 50Hz like many multimeters that do AC), you can first work out the DC resistance, then put the sig gen on and work out the total impedance at some frequency. A quick bit of maths after that tells you the inductance. Incidentally, PC soundcard inputs and outputs will be good enough for producing a sine wave and metering to do this. Maths to be added later, although any decent electronics book should give you the sums for a potential divider where one side is an inductor or capacitor.
grab
Posts: 2420 Joined: Sun Jul 08, 2007 12:00 am Location: Cambridge, UK
Posts: 18117 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Many thanks guys, that link is a good candidate dave, thanks.
Folderol is on the money, I don't have the equipment or skills to make the measurements as described. But amongst my adventures online I did see reference to calculating from the DC resistance, impedance, and number of turns. And that's what I was hoping to find.
Hey guys, it's OK to call me Will :roll:
... especially as it's my name :D
see v
. . . . v
. . . . v
. . . . v
. . . . v
OK Will :)
And thanks everyone for your help. I've been trawling t'interweb for assorted clues and struck lucky.
Someone who uses a number of Xicon 42TL series transformers has measured the inductance of several models in the series. And if anyone stumbles across this thread in the future and would find this useful, here they are...
42TL022 1.5K Ohms .56 Henry
42TL021 4K Ohms 1.5 Henry
42TL018 7K Ohms 2.6 Henry
42TL019 10K Ohms 3.75 Henry
42TL025 17K Ohms 6.4 Henry
42TL017 20K Ohms 7.5 Henry
All are available from Mouser UK and at far more attractive prices than the Kent Armstrong tone choke which is a very useful 1H but a scary £26.51.
An online LRC calculator will let me pick the capacitor and resistor values to get the right frequencies for each setting.
Post by Howdy Doody Time »
Nice to see resolution. All's Will that ends Will.
Howdy Doody Time
Posts: 827 Joined: Sun Jan 18, 2009 12:00 am Location: Huai Yai, Chon Buri, Siam
The only excuse we have for making music in the first place is to make it differently..vis-a-vis our own difference (Glenn Gould)
Howdy Doody Time wrote: Nice to see resolution. All's Will that ends Will.
{ahem} :roll:
Post by wjmwpg »
zenguitar wrote:OK Will :)
Andy, a decade has past but I just found this post and it made my day - thanks!
Long-shot question - would you happen to know if these measurements were made using only the primary as an inductor, or running through the primary and secondary in series?
wjmwpg
Posts: 2 Joined: Fri Aug 11, 2017 4:16 pm Location: Winnipeg, Manitoba, Canada
Hi wjmwpg,
Glad you found this vintage topic useful.
A decade is a LONG time !! So it isn't easy to recall, but my gut instinct is that the figures are for using the Primary as an inductor. However, it's difficult to be sure. Since my original post I've switched from Windows PCs to Apple Macs so I can't even track down the post I was quoting.
Post by BigRedX »
zenguitar wrote:Hi wjmwpg,
OoI did you ever use this to produce the relevant inductors?
One of the problems I've come across is that nearly all the schematics for Gibson guitars and basses with varitone controls available on the internet give part numbers rather than values for the inductors which doesn't help if you are trying to build your own circuit.
BigRedX
Posts: 2811 Joined: Fri Sep 03, 2004 12:00 am
I ordered parts but never got around to building a circuit. I've had a trawl through my old data.
Here's more detail on the inductance of the various transformers.
And I found this old schematic with inductor values if that helps.
Post by wjmwpg »
:o Extremely helpful! Thanks Andy! :bouncy:
wjmwpg
