Anything cheaper than iZotope's RX?
Re: Anything cheaper than iZotopes RX?
Don't think there's any need for embarrassment. We've all been caught out by cunningly hidden settings! But it does sound very likely that the clicks were indeed due to the buffer being too small to sustain glitch-free playback. Glad it was an easy fix!
Posts: 42144 Joined: Fri Jul 25, 2003 12:00 am
BillB wrote:The important thing is that a) you found the problem and b) you shared the solution. That way we all get to learn something.
+1.
TNGator wrote:
Hi Ken. What is a spectral editor please? perhaps if i can explain more clearly. Let me go through the tracks and find exactly which ones have the crackles. Some tracks were recorded by mic such as vocals and a fender strat. Some were done by DI such as the bass. Im very careful about gain staging and dont record hot at all. In fact the level is quite low. let me see what exactly what is popping and how it was recorded. In the meantime I'll continue searching for a good software tool for this.
OK - seems as though you're talking about noise in the signal rather than any clicks from syncing your convertor.
Many editors have a spectrum view that will allow you to surgically remove the clicks much like photoshop. Izotope has this but so does Wavelab and SADiE. There's also Sony's Spectral Layers etc. Not sure which is the cheapest or which one would provide you with value for money if it's a one-off repair.
I'm All Ears.
ken long wrote:Many editors have a spectrum view that will allow you to surgically remove the clicks much like photoshop.
Yes, there are many spectral editing tools now but they're not all created equal. I believe only CEDAR and iZotope can intelligently fill the gaps left behind by your spectral edits by interpolation, in the same way that Photoshop can when, for example, removing a telegraph pole from a pic. The others just allow you to remove/manipulate the existing data and perhaps apply crossfades with the adjacent bits
Mixedup wrote:ken long wrote:Many editors have a spectrum view that will allow you to surgically remove the clicks much like photoshop.
Well not really. Wavelab is very good at this too (I use it everyday for such tasks). And as I mentioned, Sony Spectral layers takes it a step further with the ability to reveal layers behind layers. There's quite a few options on the market now.
https://www.youtube.com/watch?v=juD6KKrM0Bs
Glad to hear it was a buffer issue. Makes it much easier to deal with
I'm All Ears.
ken long wrote:Well not really. Wavelab is very good at this too (I use it everyday for such tasks). And as I mentioned, Sony Spectral layers takes it a step further with the ability to reveal layers behind layers. There's quite a few options on the market now.
Yes, really.
For all their other strengths — which I agree are many — neither Wavelab's spectral editing nor Spectralayers generates new background sound based on analysis of the surrounding material to fill the blanks when removing unwanted noises. Nor do the various others, except RX and CEDAR's software. If they did, without CEDAR's permission, I imagine CEDAR would litigate to enforce their patent; they've done so successfully before...
Mixedup wrote:ken long wrote:Well not really. Wavelab is very good at this too (I use it everyday for such tasks). And as I mentioned, Sony Spectral layers takes it a step further with the ability to reveal layers behind layers. There's quite a few options on the market now.
Yes, really.
I guess I missed the bit where you wrote "intelligently". Wavelab is probably a little behind in this respect as it's still a bit of a manual task. But you can still analyse the surrounding areas. It's just not as automatic.
I'm All Ears.
Re: Anything cheaper than iZotope's RX?
All in all...there seem to be a few software packages out there that can do this sort of cleaning. Although it seems i got out of jail on this occasion, it would do no harm to have this sort of toll in the toolkit going forward. Although expensive, it seems a lot of folks here have mentioned the iZotope software (and Cedar too). As an existing iZotope user i'll touch base with them and keep an eye out for deals for existing customers.
Southern kin y'all
Mixedup wrote:neither Wavelab's spectral editing nor Spectralayers generates new background sound based on analysis of the surrounding material to fill the blanks when removing unwanted noises. Nor do the various others, except RX and CEDAR's software. If they did, without CEDAR's permission, I imagine CEDAR would litigate to enforce their patent; they've done so successfully before...
Unless I'm using RX's spectral repair in the wrong way I don't see it as being particularly intelligent. If I'm removing clicks then I find Audition's 'Fix single click' to work far better than attempting the same thing in RX. If there is a transient close to the click then RX has a habit of removing the transient - even though it is outside the selected area - which sounds very odd. Unfortunately my version of Audition only repairs clicks in this way so it can't be used as a general spectral repair tool.
Posts: 15852 Joined: Mon Sep 10, 2001 12:00 am
Hugh Robjohns wrote:Don't think there's any need for embarrassment. We've all been caught out by cunningly hidden settings! But it does sound very likely that the clicks were indeed due to the buffer being too small to sustain glitch-free playback. Glad it was an easy fix!
Thanks Hugh. Nice to get friendly support even you screw up
Southern kin y'all
BillB wrote:TNGator wrote: I'll keep testing but this is starting to look like an embarrassing goof on my part.
The important thing is that a) you found the problem and b) you shared the solution. That way we all get to learn something, including about cheaper alternatives to RX
Plus we get Mike’s priceless tale.
Glad you got it sorted.
Thanks for the support Bill. Nice to to be able make goofy mistakes and come clean and not get laughed. Some forums out get some really nasty smart remarks. Thanks again all for the tips and help
Southern kin y'all
Mike Stranks wrote:The tales I could tell from the last 50 years!
Just a few weeks ago I was asked to run a small sound system for a local village fete. Two radio mics and background music. Simples.
Set-up was fine and all power-lights lit up as expected. Tested mics all fine. Music feed from PC - zilch.
USB lead duff? Change lead: nothing. USB socket gone funny? Different socket: nothing. Laptop got its knickers in a twist? Full reboot: nothing.
Then I turned up the channel gain and all was well....
We are clearly related. Probably even take the same meds
Southern kin y'all
Well gang... you have all been really helpful as usual when I have a question so let me throw a must have bargain your way as a thank you. Izotope are doing about 6 or 7 elements packages for $49 . Yep..49 not 490 You get RX, Trash, Nutron, Nectar, DDLY
I already have most of them but getting RX for 50 bucks (ok Irish tax is a further 11 bucks but still). Have a look here. I jsut got mine. great deal. Ironic that earlier in this thread some suggested I hold out for one of Izotopes sales and get RX and whaddaya know.
https://www.izotope.com/en/products/bun ... erm=Jun+21
Southern kin y'all
TNGator wrote:Izotope are doing about 6 or 7 elements packages for $49 . Yep..49 not 490 You get RX, Trash, Nutron, Nectar, DDLY. I already have most of them but getting RX for 50 bucks (ok Irish tax is a further 11 bucks but still). Ironic that earlier in this thread some suggested I hold out for one of Izotopes sales and get RX and whaddaya know.
Keep in mind that for Spectral Editing you will need the Standard version or higher:
https://www.izotope.com/en/products/rep ... rison.html
One of the cheapest ways to get RX Standard is often with the Music Production Suite.
JRRShop have the upgrade from Elements (any) for ~£277 with group discount code. Sell on the included Melodyne license and you have the rest of the Suite for ~£240:
Nectar 3 | RX 7 Breath Control | Ozone 8 Advanced | Neutron 3 Advanced | RX 7 Standard | VocalSynth 2 | Insight 2
Speaking as someone who bought RX Elements, the only reason to buy it is so that you can get a good upgrade deal on the full RX. In my opinion RX Elements is missing the processes where RX really shines and isn't worth buying unless you are planning on using it to upgrade cheaply to the standard version.
I wouldn't be as categoric as James about Elements. I bought it and have stayed with it - not upgraded. I find the Voice Denoiser useful for quick-fixes and use Declip on over-enthusiastic recordings sent to me by others. But I'm only occasionally doing anything that needs lots of 'fixing'
But if I was doing lots of serious restoration or rescue work then I'd upgrade in a trice...
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Mike Stranks wrote:I wouldn't be as categoric as James about Elements. I bought it and have stayed with it - not upgraded. I find the Voice Denoiser useful for quick-fixes and use Declip on over-enthusiastic recordings sent to me by others. But I'm only occasionally doing anything that needs lots of 'fixing'
Good point. Im no expert at all but this project was the only that caused me such problems and it turned out to be a rookie goof on my part. Im just saying that for less than 50 bucks I think this is a killer deal for whats being thrown in. Trash2 alone is worth well over 100 for what it can do.
Southern kin y'all
Maybe I should add that I already own an old version of Adobe Audition which works better for me than the processes included in RX Elements. Audition's de-clicker does less damage to the original audio (RX loses too much detail) and its de-clipper is as good as RX's. RX wins out with its spectral de-noise, spectral repair (very versatile) and de-crackle. All of the winners are only available in the standard edition.
Mike Stranks wrote:I wouldn't be as categoric as James about Elements. I bought it and have stayed with it - not upgraded. I find the Voice Denoiser useful for quick-fixes and use Declip on over-enthusiastic recordings sent to me by others. But I'm only occasionally doing anything that needs lots of 'fixing'.
I'm in the same boat with the video stuff I do at work. Voice Denoiser does a great job of getting rif of air-con hum, background traffic noise etc, but also is suprisingly good a taming obvious room reverb.
But again, I'm only looking for a light tidy up, and I'm not shooting for broadcast quality!
Posts: 28022 Joined: Sun Jul 05, 2015 12:00 am
I moved from RX Elements to Standard because the deal on offer was too good to miss (it was offered to me as a long term loyal customer after I'd owned Elements for, ooh, at least three weeks). It is better, of course, but I wouldn't have lost sleep waiting for it as Elements is surprisingly capable if it's your first ever exposure to noise reduction software.
- ConcertinaChap
Jedi Poster -
Posts: 14392 Joined: Wed Jul 20, 2005 12:00 am
Mr Punch's Studio
In my defence I was unsupervised at the time.
blinddrew wrote:...and I'm not shooting for broadcast quality!
There was a time when that phrase actually meant something...
We now seem to have cinema-standard, just-good-enough, and portrait-smartphone as the three defining levels of video quality...
Ha! Put me in the 'just good enough' category then.
