Thanks Mike.
I'll invest in a load of bubblewrap for the portable HDD, find a sturdy table, tell the drummer not to bash the kick drum so hard and hope for the best...
Behringer UFX-1604 Available for Silly Money!
Re: Behringer UFX-1604 Available for Silly Money!
- Ronnie Wibbley
Regular - Posts: 135 Joined: Thu Jan 31, 2002 12:00 am Location: Stuck behind a tractor.
Ronnie Wibbley wrote: Is these any technical reason something like, for example, the WD 500 GB My Passport Go Portable wouldn't work in the same way as a portable HD?
Do they have a list of approved drives? I know that Allen and Heath do for their Qu series and I bought a 500GB WD Elements drive specifically because it was on the list when the larger drives weren't as far as I can remember. It worked fine for the particular job that I bought it for and has worked fine for everything else I've tried since (though I've not tried it on a Behringer mixer).
Posts: 15869 Joined: Mon Sep 10, 2001 12:00 am
They don't even have a proper manual for it, so I doubt there's a list of approved drives. I'm sure I read somewhere that they recommended using drives with an external power source rather than USB-powered ones, but I can't find where I read it now.
- Ronnie Wibbley
I have used an external SSD successfully. USB sticks in general all seemed to be slow but this one:
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
Works every time for me. It was only £40 when I bought it and there are other USB3 SDDs for more sensible money listed as similar. So long as the listed speeds are in the ballpark should be good.
- Random Guitarist
Frequent Poster - Posts: 1134 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
Yes, can confirm that a cheapy 120 Gb portable SSD works fine for this.
- Ronnie Wibbley
