Thanks. I think what got me thinking about my set up is that I use an Edirol FA-66 (via firewire) and have been since 2006. I seem to remember an SOS review (from 2000 or 2001) saying something about some aspect of it sounding 'digital', but, come to think of it, I think it was the pre-amps not anything to do with the A-D or D-A converters.
I suppose one day, who knows, AI technology will be able to 're-imagine' any recording regardless of original quality, and re-render it to sound pristine. By then, we might have electronic ears that can hear music containing frequencies above 22kHz!
A-D & D-A converters, budget vs high-end
Re: A-D & D-A converters, budget vs high-end
Jack Ruston wrote:That's not true.
Some things do sound better above a certain point. It's not just a question of simply spending more, but it's not price independent. The question becomes - does it make a difference? And that depends on the rest of the setup and environment, the nature of your role, working method, and how much the negative factors affect you personally. We are really dealing with what isn't there at that point. But I 100% agree that nobody should now have to feel that their equipment is the limiting factor, by online gear snobs of whatever ilk.
Sound better to who? Sound better to how many more % of people?
With so many people happy with mp3 you have to be a virtual golden eared type to think that better gear makes a sonic difference.
hobbyist wrote:Jack Ruston wrote:That's not true.
Its a common fantasy that the best and most expensive gear is "just as good" as budget stuff. Its not a new story. Indeed, from Aesop's fables in the 7th century we are taught of a fox who tries to climb a great vine to reach the grapes at the top.
After his many failed attempts to reach them, the fox declares he never wanted them in the first place because they were sour. Sour grapes.
hobbyist wrote:With so many people happy with mp3 you have to be a virtual golden eared type to think that better gear makes a sonic difference.
No. You just have to be able to learn to listen critically, understand and analyse what you're hearing. With a little effort and perhaps some training most people can do it regardless of the colour of their ears. Whether or not it's important to you is another matter.
- forumuser840717
Regular - Posts: 405 Joined: Thu Jun 16, 2016 5:20 pm
forumuser840717 wrote:hobbyist wrote:With so many people happy with mp3 you have to be a virtual golden eared type to think that better gear makes a sonic difference.
I am happy with how I listen.
And millions and millions other folks are happy with mp3s quality.
hobbyist wrote:forumuser840717 wrote:hobbyist wrote:With so many people happy with mp3 you have to be a virtual golden eared type to think that better gear makes a sonic difference.
That's entirely your choice, but around here many people aspire to produce recordings of a higher quality for those people who can and do hear a difference.
- Bob Bickerton
Jedi Poster -
Posts: 4741 Joined: Fri Dec 20, 2002 12:00 am
Claims and counter claims here. It would be good to be given an actual example where say the lower noise floor of a top converter really makes a difference, and another where it doesn't.
- Tim Gillett
Frequent Poster (Level2) - Posts: 2555 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
I think that's already been done Tim, by both Jack and Hugh. If you've got ALL the rest of your signal chain at a very high quality, then you'll be able to hear the difference. If you're in a compromised room, with budget monitoring, recording from budget mics via a cheaper interface - well, then you've got other things to concentrate on first.
The 'lots of people are happy with MP3s' argument doesn't really stack up either. That's an end-user consumption format, we're talking about doing a completely different job so we use different tools.
Well it’s not a bad idea, it could be done to set up two recording chains with the same performer using recording with two instanced of the same mic and pre, but one going into a regular AD and one into a higher end converter.
Then of course there’s only the playback chain, needs a great monitoring system and great DA. But the two files could be there to allow people with good monitoring to hear by themselves. Or just upload them at the local hiifi shop
SOS did something similar with multiple mics recording the same vocalist and of course the famous preamp battle.
It would be educational as most people have not heard a raw track recorded with higher and converter, so have no idea what to expect (we hear final mixes all the time of course but mostly on either compromised formats or compromised playback systems)
I have a lucid AD/DA in the studio (used to be pretty good, but it’s a few years old now) but no two identical mics and pres, alas, otherwise I’d be happy to set it up..
I think Jack's earlier comments about working with high-quality equipment is apposite. While high-end converters have easily measurable technical improvements -- greater dynamic range, lower noise floor, lower distortion (of all forms), more accurate Nyquist filtering, stable performance when clocked externally, and so on -- we don't generally perceive these benefits in that kind of 'technical' way.
Instead what we perceive -- those of us who actually do audition and use equipment at this level -- is usually a sense of effortlessness and naturalness in the sound presentation, and a greater clarity with which you can hear into and around mixes.
As Jack said, it's often "...a feeling that something irritating and uncomfortable had gone." That might sound 'wishy-washy', but it's actually a very good description of my own experiences too. You just don't have to work so hard at trying to ascertain what's going on. You don't feel the need to turn the monitoring level up to hear the detail. You don't get tired as easily, and the working is just more pleasurable and comfortable.
The obvious result of being able to hear into the mix better is the ability to mix better -- because it's far more obvious what needs to be done to improve the mix, and what effect your processing is having. And you can work faster and more accurately because there's less confusion or doubt about what you're doing. You don't agonise over whether the eq or fader should be up or down 0.5dB because it's far more obvious!
But at the end of the day, not everyone can afford or justify owning high-end equipment, and not everyone will benefit from using it -- just as not everyone can drive a sports car like Lewis Hamilton, or appreciate the finer differences between a Ferrari and a Porsche... say.
Posts: 35511 Joined: Fri Jul 25, 2003 12:00 am
CS70 wrote:Well it’s not a bad idea, it could be done to set up two recording chains with the same performer using recording with two instanced of the same mic and pre, but one going into a regular AD and one into a higher end converter.
Better still to use one mic and signal chain until the output of the preamp then split that to two converters.
Jedi Poster - Posts: 17921 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Your karma has run over my dogma
Sam Spoons wrote:CS70 wrote:Well it’s not a bad idea, it could be done to set up two recording chains with the same performer using recording with two instanced of the same mic and pre, but one going into a regular AD and one into a higher end converter.
Brilliant, Sam - you're perfectly right! I obviously need more coffee.
A few thoughts:
1) the "low end" converter would likely be the one built in into an interface (I have a U28M laying around doing nothing, even if the preamps in that one are actually pretty good... no idea about the converters.. maybe I should borrow an entry level interface).
That means going from the preamp output into the interface line input, which is often not a separate path, but passing thru the preamp.
I remember Dave and other electronic experts saying that it's practically irrelevant, but as we are talking very subtle differences here, and it's important to compare apples with apples, would it be an issue?
I'm not aware of any "low end" converter which exists separately (and if there was one, I wouldn't have it..).
2) My acoustic guitar recording space is reasonably well treated, so should do fine as recording space? If the differences in A/D performance are overshadowed by the room properties, it makes no sense to test.. however, it will be the very same performance. Can play some guitar or sing a little.
3) So the chain is: performer -> mic -> preamp -> splitter, one going to the Lucid, one going to a regular interface and PC. The Lucid hopefully could go directly to the interface digital input and same pc, or another interface and PC altogether.
The U28M has S/PDIF in but the Lucid, if I'm not mistaken, doesn't have a S/PDIF out (makes sense, it's 8 channels). Hard to find a consumer interface that uses AES/EBU.. the Lucid has ADAT so maybe I could take use my RME instead that has an ADAT input - but kinda messy to detach it from the home PC (it's a PCI card and breaker box).
4) Is the Lucid high end enough? (dont remember the exact type and I'm not at the studio, but googling a little should be a 88192)
