It looks and sounds like something that has been programmatically generated rather than by any human.
For starters the time signature really should be 4/2, and the last 2 bars form a very odd cadence. Voice leading is strange too, and the piece opens on a blatant parallel 5th - there are other parallels too.
Basically it ambles around C major and then does a half-hearted modulation to try and end in G but that's about it. So there isn't much functionally going on at all.
Thanks for the reply.
In fact it seems to be circling around C maj, going everywhere and nowhere.
One more question...
What is the general practice when one is harmonizing a melody? Accept the chords that come from the available notes or try deliberately a certain function to each chord?
There is no right answer regarding 'the general practice' of harmonising a melody. It all depends on the musical style or genre you are working with, and of course the particular effect you are trying to create. So many things really.
The style of the musical example you have provided is homophonic, rather like a section of a church hymn - if you wish to develop that style you should look at the chorale harmonisations of JS Bach. But that is simply one approach.
I don't understand what you mean here. A melody only consists of one note at a time, so there are no other 'available' notes.
I'd suggest finding a copy of Melody And Harmony, by Stewart Macpherson if you want to really get into the formalities of this sort of thing.
| I / ii V | I V vi iii | ii / V vi | V vi V viim (iii of G) | I / / II7 (V of G) | V / - - |
There is a ii V I, other than that it breaks all the rules or 'guidelines' . The voices crossing each other make it more difficult to read than it could be. Some of the chords don't have thirds, so they're ambiguous. Because it's mostly in C the final chord sounds like a iisus4 that wants to resolve, even though it was set up as a resolution with the F#.
Thank you all for your replies and book sugestions.
GilesAnt wrote:There is no right answer regarding 'the general practice' of harmonising a melody. It all depends on the musical style or genre you are working with, and of course the particular effect you are trying to create. So many things really.
In fact I am reading "The style of palestrina and the dissonance" by Knud Jeppeson so I believe that might be the reason why it sounds like that. If you disregard the last two measures and the top voice you'll notice that it is according the "rules". The rest of the work, the top voice and the last measures were just an attempt (frustrated) to add a third voice.
I'm thinking in these terms: A melody note is just one note but together with two more notes it'll become part of a triad. Obviously there are infinite ways to approach this piece but I've used this one just to see what could come out of it (which triads would come out of it and how it would sound).
I made a more conventional harmonisation of this :
Now it goes :
| I / IV / | I / / / | V / / I | ii / V / | I / II7 | V / - - |
I used two soprano clefs so the red note is out of her range. Of course the robot soprano can do it -- no sopranos were harmed in the making of this harmonisation.
Well done merlyn for having a crack at this rather unpromising piece. It certainly sounds more hymn-like now, especially with the classic modulation.
I'm guessing one of the 4 repeated Gs in the top part was mean to be an E. You might want to look at bar 4 again where the lower 2 parts both move in parallel from F to G.
GilesAnt wrote:
@rbarata - was this an exercise of some kind?
As I wrote before I'm reading Knud Jeppeson's book about Palestrina style. I wrote a piece with two voices only and it seemed to be correct but, just for fun, I tried to add a third voice.
The one in the first post is, errrr, "unusual". Which were the first two voices and which is the third added one later?
If I were to analyse and harmonise the top voice, I think I'd naturally be drawn towards:
GilesAnt wrote:I'm guessing one of the 4 repeated Gs in the top part was mean to be an E. You might want to look at bar 4 again where the lower 2 parts both move in parallel from F to G.
Yes, I didn't realise it was the second line that was being harmonised and I took the top note -- the highest pitch as the melody and I did make an error. I think the parallel motion was trying to stay within the soprano range, but there's no excuse.
The way this is taught in school is to start with root position I IV and V. If the melody is diatonic it can be harmonised with those three chords. Then inversions are brought in, then minors. As I'm sure you know functional harmony is :
I = iii = vi
IV = ii
V = viidim
This melody is more advanced because of the F# but as you said using it as part of a secondary dominant works.
rbarata wrote: If you disregard the last two measures and the top voice you'll notice that it is according the "rules".
It makes more sense with just the bassline and the melody. I did another version where I took your idea of a scalar bassline from bar 2 and kept that going.
If we take bar 2 as an example the melody is a C major arpeggio. That's a strong C sound, so you don't want a V in this bar. What i did was -- first beat C major with E in the melody so the middle is G. Second beat B and G. That's E minor -- leave the G. Third beat A and C -- A minor so add E. Fourth beat G and E -- add C.
GilesAnt wrote:As I wrote before I'm reading Knud Jeppeson's book about Palestrina style. I wrote a piece with two voices only and it seemed to be correct but, just for fun, I tried to add a third voice.
You will probably know from your book that Palestrina is best known for a polyphonic style whereas your example is essentially homophonic. Taking your original middle part as the melody you have some large upward leaps in bar 2 which is uncharacteristic of Palestrina, hence my assumption that this was more like a hymn tune. Palestrina's melodic phrases are typically flowing in small scalic steps with occasional leaps, and never 4 upward leaps in succession (as far as I know).
Also if Palestrina is your model you will need to think differently about harmony. At this time (late 1500s) functional harmony was only gradually evolving from the earlier modal styles.
@merlyn
Your second attempt is much improved. Obviously you aren't attempting Palestrina (that would be impossible here as I said above), but as a diatonic harmonisation it is effective. In the spirit of constructive criticism I would suggest the bass in bars 2/3 where the G is repeated is weak. I would revoice the last beat of bar 2 to avoid this. Also you have parallel octaves from last beat of bar 3 to first beat of bar 4. The scalar/stepwise bassline is definitely stronger though and makes a much more satisfying harmonisation.
As an exercise why not try a 4-part harmonisation. I'll have a go myself as soon as I can work out how to cut and paste from my scoring software into this forum post.
GilesAnt wrote:In the spirit of constructive criticism I would suggest the bass in bars 2/3 where the G is repeated is weak. I would revoice the last beat of bar 2 to avoid this. Also you have parallel octaves from last beat of bar 3 to first beat of bar 4.
Thanks. I'm using MuseScore and I'm still learning it e.g. the red notes and screenshotting the wrong version . I've edited the previous post with a version without parallel octaves. Bar 2 is the given from the original post. I think I went to F in bar 3 to avoid repeating the G. It's tricky to put a different note on every beat -- respect to J.S. Bach -- the guvnor
Getting a lot of mileage out these six bars -- I'll do a four part version.
Strange how such an unpromising 6 bars can yield a lot when you put your mind to it. I've got a version too, but will probably post it tomorrow. I'm using Cubase, but I'm not all that familiar with the score features yet.
Yes, Bach is the master for this kind of stuff, although even he made mistakes now and then with consecutive 5ths and 8ves. When you consider how much he was churning out though it is hardly surprising.
N.B I am only taking exception to consecutives within the spirit of chorale or hymn tune harmonisation. I do realise that in other contexts these can be acceptable (Debussy etc).
@rbarata - fancy having another go at this. Suggest you use your middle line as a melody though. or just take what merlyn has done as your starting point.
Here it is the original score. The melody (top voice) was written by me. After, I added the bass. Changed the time sig and the the score accordingly.
In fact, according Jeppeson certain consecutive leaps are permitted. He mentions 4 different cases, being one of them the outlining of major or minor triads, usually in root position or second inversion. In bars 2 and 3 there's a C maj triad in with a doubled E but we can look at it in two different ways: a 1st inversion of a CMaj triad if we start on the E or a 2nd inversion of the same triad if starting on the G. Not sure if this way of thinking is valid or not.
GilesAnt wrote:Also if Palestrina is your model you will need to think differently about harmony. At this time (late 1500s) functional harmony was only gradually evolving from the earlier modal styles.
Yes, Jeppeson's book has an exhaustive first chapter about it.
GilesAnt wrote:@rbarata - fancy having another go at this. Suggest you use your middle line as a melody though. or just take what merlyn has done as your starting point.
I have found MuseScore good. There's some spurious rests in the screenshot above which will be due to my unfamiliarity with it. A good feature is that there is a screenshot functionality built in. If I was doing this on paper I would use a piano stave, rather than four separate staffs -- who wants to use an alto clef if they can avoid it? MuseScore allows four separate voices (could be more) on one stave -- that's how I got the stems of the notes to face different ways making the four voices easier to distinguish.
@rbarata thanks for your melody, it's been fun harmonising it.
Here is my effort - not sure if I have got it right in inserting an image though.
I have modelled it more on a late 19th century Romantic style, deliberately chromatic (in contrast to what merlyn has offered) to show how there is no 'general practice' when harmonising a melody.
A pat on the back for the first person to spot a consecutive 5th or 8ve!
The image wasn’t displayed so I had a quick edit. Looks like the BBcode is embedded in the link your host provides, so you don’t need to use the image tags when you make your post, just paste the link ‘as is’ into your post.
Like to see your works.
I've been trying to harmonize the melody but only in 3 parts (which I have never done before). In this particular melody it has been difficult as there are a lot repetitive functions so it's hard to find variety without breaking the "rules".
The melody itself already has some problems (a leap followed by another leap when it should be by step, for ex.)
I've already reached a lot of dead ends so I haven't post anything yet.
About the images...I use postimages.org then copy and paste the img direct link between the img codes.
I couldn't find any consesecutive 5th/8ve but isn't there a dim 5th between the bass and soprano (bar 4, last note of the bass - G#-D)?
Why are you just working with that original melody - maybe you should use something more distinctive to Palestrina, or whoever is your inspiration. Palestrina is a tough one to start with, and I would advise trying some Bach chorales instead. At least you are more or less guaranteed a melody that will reward your efforts, a more natural phrasing and cadencing too, whether in 3 or 4 parts.
Thanks for checking my consecutives - not sure if there is a 'rule' covering the diminished 5th, but I will excuse myself on the grounds of taking my inspiration from the late Romantics such as Bruckner.
My main goal was to add to what merlyn had already shown as a diatonic harmonisation, adding some chromaticism by shifting into A minor as soon as possible before resolving (and modulating) via D to G. As you can see there is no 'right answer'.
PS - Thanks Andy for correcting my issue with inserting images
