A Long List of Compromises - new music space
Re: A Long List of Compromises - new music space
Post by ManFromGlass »
Last group of photos showed a squeezebox and an unsolved Rubics cube.
Both torture devices in the wrong hands
Posts: 7479 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
What do you think the padding on the wall is really for?
Posts: 28059 Joined: Sun Jul 05, 2015 12:00 am Location: York
Only slightly related to torture -
Is this worse than actors miming be able to play guitar on tv? Two bagpipers on tv who have the mouth moves correct but couldn’t make their fingers mime Amazing Grace in time.
Sure, sure, blame the picture editor!
Post by MOF »
I wish that editors would re-synch archive footage used in music documentaries, which is usually out by about two frames for some reason.
MOF
Posts: 2472 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
and quite a number of old movies too. Hard to watch that stuff.
While it's sadly all too common to see out-of-sync material from the source, it's worth bearing in mind that sync errors can also be caused by the viewing equipment, particularly if you take audio from a TV to reproduce via a hifi system or external 'sound bar' as so many do.
Some systems -- either the sound system or the TV itself -- will include facilities to delay the audio to match the inherent delays of the visual display, but not all do, and even if they do, not everyone is aware of the feature or how to adjust it!
Posts: 42186 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Does anybody know of an app/plug-in that can do the same with Youtube?
Posts: 21938 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
I find some Amazon programs drift out of sync after a while. I have to exit the program and resume watching to get it in sync again. Never found that with Netflix.
Posts: 18299 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Wonks wrote:I find some Amazon programs drift out of sync after a while. I have to exit the program and resume watching to get it in sync again. Never found that with Netflix.
Until about a year ago I had a TV that I bought in 2008. When watching pretty much any streaming content the audio would drift out of sync with the video and occasionally I'd get weird distortion on it as well. The solution to the distortion was to pause for 30 seconds, but the sync issue never went away.
Got a new TV early last year (a cheap but nice non-smart thing, as I use external devices for the smart part) and both problems went away and haven't re-occured, so maybe it would be worth trying a different TV if yours is getting on a bit?
Posts: 9592 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
It's a Sony and only 4 years old max. And it's only sometimes, and only on Amazon. Maybe it's the app on the TV, though I do try and check for software updates about once a month.
It's usually the decoding software which loses track of the time stamping between the audio and video streams, and often because of a change to the encoder software intended to 'improve quality'.
So a TV software update will often fix it, but only if software updates are still being generated for that specific TV. Panasonic seem very poor at supporting their TVs once they're more than about 5 years old... :(
Chapter whatever: of progress and impediments...
Working on the wide diffusers for the back wall.
Step 1, cut, plane and sand wood:
Step 2, cut to random size, tidy with rasp, and layout to confirm backplate size:
Step 3, realise that you've forgotten to factor that you're creating two plates and have therefore only done half the requisite cutting, planing, sanding and rasping.
Step 4, buy more wood and repeat step one:
18 meters in total, if you're interested...
Step 5, cut to size and split for two boards:
Step 6, decide things are going too well so trap finger in car door and half-sever the tip.
Step 7, glue blocks to back boards:
Step 8, add a bit of trimming and mounting plate:
Step 9, read wall diffusion complete:
And that actually completes the main build and treatment.
I just need to build a cabinet for the computer now and then we're back up and running for recording and mixing. After that there are a few cosmetic jobs like some nice lights and the nameplate for the front, but a) they don't affect the use of the room and b) I can clear all the tools out of the room and do that work in the garage.
Yay!
So when is the grand opening?
Posts: 19879 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Well, the cabinet build will probably take a couple of days - longer since I've decided to paint it actually. And I've got a couple of weekends coming up that I can't dedicate to this (shocking I know), so I'd guess we're still a month away. Allow time for me to balls things up again a couple of times, and Life to stick its oar in, say, end of March?
Do the diffusers make any obvious difference?
blinddrew wrote: Step 6, decide things are going too well so trap finger in car door and half-sever the tip.
Yikes - given my primary instrument this sort of thing terrifies me. Lovely work on the diffusers but more to the point, be careful Drew! I hope it heals well and fast :wave:
Wonks wrote:Do the diffusers make any obvious difference?
They look lovely, so from an aesthetic viewpoint I'd say yes :lol:
No idea on the diffusers. When I was reading the audio handbook and doing the maths it was borderline with a room of this size. But I've probably got about 24 square feet of diffusion there (counting the rest of the bookcase and the diffuser/absorber bit) so it should be enough to make a difference, if only slightly.
I've not yet done any kind of critical listening in the room as it's still more like a carpenter's workshop than a music studio so we'll wait and see.
But yes, I think they look nice. :)
Oh most tasteful diffusers - like a pair of miniature skyscraper cities.
Bravo that man!
Posts: 21653 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
I think they're the only thing I've made that my other half actually likes the look of. :)
blinddrew wrote:I think they're the only thing I've made that my other half actually likes the look of. :)
be careful... they may disappear :lol:
Not that much!
Not a lot of progress on the cabinet today but on the positive side the finger is healing up nicely.
You're not supposed to pull it that hard . . :smirk:
Ba dum tsh!
