Attic Room Studio Build
Re: Attic Room Studio Build
Post by Luke W »
Thanks, Eddy, much appreciated :thumbup:
I've been making an effort to just use the space for a while now. No soldering anything, no deciding I just need to quickly make this, that, or the other. It's definitely been worth the wait.
I did get a quick shot of the gobos in action though, I took the chance to give them a test at the same time as trying out a mic.
Luke W
Posts: 1655 Joined: Thu Feb 19, 2009 12:00 am Location: Northamptonshire, UK
Looking very nice there :clap::clap::clap:
Posts: 28031 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Luke W »
After a few months of just using the studio and actually doing some work, I've been making things again. Something that had been on my list for a while was some flooring panels, since the whole room is carpet I wanted something I could pair up with the gobos to liven things up a little if tracking acoustic instruments.
I used some leftover laminate flooring, some offcuts of flooring underlay, some nasty adhesive that gets everywhere and a sheet of 6mm MDF to create a couple of these things:
Handles cut in so they can be moved around easily, and they are sized so that the wheels on the large gobos roll either side of them. When they're not in use they butt up together and live in front of the sofa. The only photos of them in action at the moment contain me, and nobody needs to see that...
Lastly, the whole room is finally clear and tidy. Here's a shot from the other week, taken while filming a promo video with some rather fancy looking gear (by someone who knows what they're doing, not me!).
Luke W
Beautiful :thumbup::clap:
Posts: 9590 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by Luke W »
Cheers Eddy :thumbup:
Luke W
Yes indeed, looking very good. :)
Like the keyboard desk....
:think:
Posts: 19852 Joined: Sat Jul 12, 2003 12:00 am
How many more 'impressive's can we cram into this thread?
Well certainly another one from me, based on this level of expertise :clap:
Posts: 21638 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Luke W »
blinddrew wrote:Yes indeed, looking very good. :)
Much appreciated, thanks :thumbup:
Arpangel wrote:Like the keyboard desk.... :think:
It's worked out well, pretty much everything about this build has been focused on saving space and that keyboard shelf has been a real winner there.
Martin Walker wrote:How many more 'impressive's can we cram into this thread?
Cheers Martin, really appreciate it. Although I'm sure if I could probably fill another thread with photos of me frowning at things that didn't quite work out or fit properly!
Luke W
{sigh} wish I had something even remotely as nice as that. It doesn't just look like a well designed setup. It looks cosy, and somewhere you'd like to be - even if mentally freewheeling :clap:
Posts: 19871 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by Luke W »
Folderol wrote:{sigh} wish I had something even remotely as nice as that. It doesn't just look like a well designed setup. It looks cosy, and somewhere you'd like to be - even if mentally freewheeling :clap:
Thank you very much. Getting the room clear made a big difference, it does feel very welcoming now I can just sit down and get to work rather than spotting things i need to finish building or installing...
Luke W
I know what you mean there, i'm down to just three more jobs to do...
Post by Luke W »
blinddrew wrote:I know what you mean there, i'm down to just three more jobs to do...
I do have the patchbay to sort out (I picked it up second hand and it needs de-soldering) but until I add a couple of bits of gear I’m eyeing up I can totally do without it. And now I think about it, little bits like cable/mic storage need sorting... But nothing like piles of cable and old racks scattered around the place anymore, so it at least has the illusion of being finished.
I was catching up with your thread earlier, looks like I’ve missed quite a lot! It’s looking spot on.
Luke W
Post by Luke W »
Well, it was all going so well but I've been tinkering with things again. Made up a little MIDI controller to sit next to my keyboard and give me a bit more hands-on control over a few parameters. I really like the intergration that the NI keyboard provides and mostly everything I ever want to adjust or automate is covered, but I've found myself wanting a few faders recently.
Pretty much everything I looked at buying either had a load of controls I wouldn't use, tiny faders, or was just a bit too expensive for my needs. Seeing as I've already got the kit and I like learning things I decided on building one.
It consists of 3 x 10k linear faders in a box, with a Teensy dev board doing the thinking.
The result:
The parts came to about £50 delivered (annoyingly I had to order from a couple of suppliers each with a delivery cost so it could be made for even less), and it works really well. All built and coded by following guides from kind people on the interwebs, I can take no credit for any part of it!
Luke W
That's a really neat piece of kit. Well done! Perfect for orchestral arranging.
And I'm wondering if my own skills are up to it... :headbang::?
Posts: 21008 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by Luke W »
The Elf wrote:That's a really neat piece of kit. Well done! Perfect for orchestral arranging.
Cheers :thumbup: That's the plan for it, I gave it a very brief test last night and I think it'll do the trick nicely. The part that I found a bit tricky was cutting the slots for the faders, and I did get it pretty wrong the first time around, but that was a patience problem on my part more than anything. If you were to look at the bottom of the box you'd see a slot cut out that a fader definitely can't follow...
Also, I'll probably have a synth based question or two in the not too distant future, I may drop you a message at some point if you don't mind?
Luke W
Post by Luke W »
Another little update, I've been doing one of my favourite jobs (yes, really) and tidying up some cables. One of the lower racks is now "finished". I fitted a drawer to store my headphones and other bits and pieces, and a cable management bar so I can still get in the drawer without anything thats plugged in getting in the way. It'll also hopefully stop me running over cables with my chair.
It looks like my laptop is going to stay as my main machine for longer than I'd thought, so over on the other side I've fitted a sliding shelf to house it neatly without the mess of cables that it was living in and around. I also took the chance to tidy up the network and hard drive cabling and used a bit of leftover Cara to make a panel that hides the annoying external power supplies.
There's still a bit more to go, but it's certainly a lot neater than when I started.
Luke W
Bravo Luke!
I spent some time updating/cleaning/ my power cable contacts & mains distribution boards on the floor behind my desk some weeks back, and also took the opportunity to carefully lift all the audio cables away from them and clip them together a couple of feet off the floor, just below the surface of my desk.
I couldn't hear any background hum before these tweaks, but just for laughs I also did a couple of quick spectrum analyser checks on before/after hum levels, and you could see an improvement. 8-)
Very nice work. Like those faders :thumbup:
Post by Luke W »
Martin Walker wrote:Bravo Luke!
Cheers. :thumbup: I always think it's worth it for the looks and ease of fault finding/replacing anything, but a measurable difference as well is reassuring!
It's really easy to overlook I think, especially in a rack when it's hidden away behind kit. I set it up thinking I'd be replacing the machine before too long, so it didn't seem worth fiddling around and bolting everything down to pull it all back out again. Also by the time the build was at the point where I was able to get the computer in I was so keen on just getting everything fired up and actually using the place that it seemed to matter a little less.
Folderol wrote:Very nice work. Like those faders :thumbup:
Thank you. They were an interesting project, and a frustrating way to learn how many Micro USB cables have no data pins connected...
Luke W
Post by Luke W »
Another little update... I recently fitted some LED strips along the back wall for a bit of ambient lighting, I took some pictures intending to put them up here and then forgot. Reading through Eddy's build yesterday jogged my memory so here they are...
The ceiling spots are great for working in the centre of the room, but one of them shines straight at my screens so I usually have them off while doing any work at the desk. I've got some spots in the panels above the mix position which light up the desk area nicely, but I was finding that with the rest of the room completely dark it just felt rather strange.
It's worked really well and I think it creates a nice atmosphere to work in, I'm certainly finding it much more comfortable than before. I've also managed to keep the place tidy after working around piles of cable/kit for far too long.
Luke W
Ooh that does look lovely :clap: I'm very much looking forward to getting mine set up though my short term future looks very plasterboardy!
Post by Luke W »
I've been doing a few bits here and there over the course of the year, a couple of updates:
I added a Scan 3XS PC a few months ago and finally got around to tidying up the right hand rack and wiring which is now looking nice and neat:
A more recent addition is an Elgato Stream Deck, which sits quite nicely on top of my controller keyboard and is proving to be a brilliant bit of kit. I've only just started getting it set up and trying things out but I think I'm going to find lots of uses for it.
There's always something left to do, but I think it's safe to say I'm running out of excuses to get involved in the next forum album project. :lol:
Luke W
Looking very smart Luke, it is a lovely space you have there. I'm looking forward to your participation in the next forum album; I find a good environment feeds the muse significantly and hopefully that'll end up being true for you also :thumbup:
