Good small monitor controller.
Re: Good small monitor controller.
The TC is just fine - simple big knob with a nice action and you won’t notice any problems.
- Bob Bickerton
Jedi Poster -
Posts: 4930 Joined: Fri Dec 20, 2002 12:00 am
What Bob said. ^^^
It's the ideal tool for the job you want to do.
Jedi Poster -
Posts: 23042 Joined: Sun Jul 05, 2015 12:00 am
Ignore the post count, I still have no idea what I'm doing...
Arpangel wrote:After all this talk I’m regretting ordering my TC, sounds like passive is verboten from what you all say!
You're really not good with decisions are you? Or technical descriptions, come to that...
A passive controller is absolutely fine when used appropriately. And inherently compromised when not used appropriately.
Your application is an appropriate use for a passive controller, and hopefully you can be trusted to install it correctly as previously advised.
The alternative is a well-designed active controller and that's going to cost you £200+ as a minimum....
Posts: 37531 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote:Arpangel wrote:After all this talk I’m regretting ordering my TC, sounds like passive is verboten from what you all say!
Thanks, I’m using short leads, as I said, so it should be OK.
I know it’s not a good idea, but there are Youtube reviews that have said it sounds very good, more transparent than the Mackie for instance, but who knows, I’m sure it’ll be fine.
Wu Wei
Arpangel wrote:Thanks, I’m using short leads, as I said, so it should be OK.
Yes, it should.
...there are Youtube reviews that have said it sounds very good, more transparent than the Mackie for instance...
I was very disappointed with the sound quality of the original Big Knob (I haven't listened to the later models). I found it a little noisy and veiled... but PW thought it was fine and used one for years very happily...
The original Big Knob is active, isn't the one discussed up-thread the BK Passive?
Jedi Poster - Posts: 18665 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Your karma has run over my dogma
It's my age...
Sam Spoons wrote:The original Big Knob is active, isn't the one discussed up-thread the BK Passive?
I've lost track... but it's hard to imagine a comparison with a passive BK involving comments about a lack of transparency. But I could see how that comment might be levelled at an active BK, and especially the early ones.
Both BK's were mentioned early in the thread with the discussion moving towards passive controllers later.
WRT my possible DIY job*, I'm trying to get a schematic drawn out and was wondering what app you used to draw your diagram? All the ones I can find for Mac seem to either be general drawing apps or for PCB design (or hugely expensive and/or complicated).
* Costed out at around £65 but if I can make it work I have some DT4P toggles switches, a large knob and a bucketload of XLR and phono sockets so just need a box, stepped attenuator and a bag of suitable resistors which ebay will provide for the princely sum of £36.56. That said a Big Knob passive would pretty much get the job done for £65 and save me the hassle
Sam Spoons wrote:...was wondering what app you used to draw your diagram?
Coreldraw. Straightforward vector drawing program.
So often the case! Unless you want something particularly unusual a commercial product will often work out less expensive than a custom DIY job.
Still pondering, the features on the BKP are almost spot on :-
Stereo balanced input - (X32 control room outputs)
Stereo unbalanced input - (Logitech BT receiver)
Stereo balanced output - (Quad 522/Kef 104bAs)
Mono balanced output - (Avantone Mixcube)
Volume control
Input switching
Output switching
Mute
BKP features not required on custom box :-
Mono (output 2 is mono)
Dim
Volume control
Input switching
Output switching
Mute
Dim
