Using powerline adapters for studio network?
Post by Fishnish »
Question:
Do powerline based internet extenders cause noise or other problems when used in the studio?
Background:
We live in a 200 year old property with metre thick stone walls and have a studio in a modern extension. Our router is in the main part of the house.
Wifi doesn't reach the studio and even with wifi repeaters it's pretty hit or miss as there are several very substantial walls to navigate. Rigging a permanent cable from router to studio would be something of a civil engineering job.
Previously there's been no huge requirement for internet in the studio and when doing updates, installing new stuff etc we've got by with running a very long cat 5 cable across the floor of 5 rooms from the studio into the router in the main house.
Recently we've been using some plugin controlled hardware (Tegeler Creme RC - love it!) and it requires an ethernet connection. Everything works fine with a wired connection from the router to a switch in the studio and thence to studio PC and Creme RC. Although of course the PC is permanently connected to the internet then.
With a wifi extender in place of the long cable everything sort of works, although the plugin is slower to recognise the hardware at first startup and weirdly the DAW (Cubase) crashes every time on exit if the control plugin is used. This doesn't ever happen when it's wired.
The Creme RC can allegedly be connected sans internet directly to the single ethernet port on the PC, but we haven't yet been able to get things working in this configuration - More research, a conversation with Tegeler, and semi-regular grovelling under the studio desk seems to be required.
Hence my question. Might power line based network extenders have any advantage over wifi extenders, and could they present any problems, such as hum, noise or other interference? BTW there are 2 seperate mains circuits in the studio - one is currently used for all things audio and the other for anything else.
Fishnish
Posts: 233 Joined: Fri Dec 24, 2010 12:00 am
Re: Using powerline adapters for studio network?
Post by RichardT »
I’ve used these before to connect a general purpose computer to a router. My experience was OK. The speed was acceptable, and it was reasonably reliable.
You shouldn’t have hum or noise problems as what comes out of the adaptors is a digital data stream.
I think it’s a case of trying it. You’re trying it over a greater distance than I did!
RichardT
Posts: 4983 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by Fishnish »
Thanks Richard, they're not that expensive so as you say probably worth a try. In a building like this I'm sure we'd find a use for them even it it was't to be in the studio. I've not actually measured the distance, but the cable we currently use is 35m, it's laid straight across the middle of the floors + there's very little slack. Also there's 3 x 1 metre thick walls made of basalt boulders to pass through. Hence the poor wifi performance!
Fishnish
Post by IAA »
I posted the same question a few years ago, and was reassured there should be no noise. I had to use one to get WiFi in my studio. Worked fine, used a separate socket and had no noise through any audio connection (other than expected from old synths etc!). As Richard notes speed is less than your pure WiFi, I found the Ethernet connection on them more acceptable.
Definitely worth a try.
I used the BT ones FWIW.
Ian
IAA
Posts: 1429 Joined: Fri Dec 28, 2007 12:00 am Location: York
Post by Fishnish »
Thanks Ian, that's encouraging. I'm not planning on using one that does wifi as well, just the ethernet and I'm pretty used to slow speeds due to living in the back of beyond.
After browsing around for suitable units I see they come in differing speed flavours and/or Gigabit ethernet. Is there any advantage to looking at the higher specced and consequently more expensive units, taking into account that our source internet speed is never wonderful after it's journey down over a kilometer of copper?
Fishnish
I've used them where running a cable isn't practical. They are okay and do that job. I've never had any interference or noise issues. But I've not found them hugely reliable or fast... And one set died because internal power supply capacitors exploded!
That sounds more dramatic than it was -- one specific cap in each unit expanded and popped! It was a known fault and fairly easy to replace, but it dented my confidence in the brand and product!
Posts: 42186 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: That sounds more dramatic than it was -- one specific cap in each unit expanded and popped! It was a known fault and fairly easy to replace, but it dented my confidence in the brand and product!
If that's the type i think it is, I just don't understand why anyone still uses them. The plastic case cracks, the paper insulation inside then absorbs moisture, and the result is totally predictable :crazy:
Posts: 19879 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
They were TP-Link TL-PA4030 500Mbps powerline adapters. I wouldn't use TP-Link units again...
Post by ConcertinaChap »
I don't use powerline now, I eventually went to hard wiring the house. Real wire is always best if you can do it, faster and problem free and a cable can be up to 100m long so distance is not a problem. Having said that, if you must go powerline then when I did use it I standardised on Solwise kit and had decent problem-free performance.
ConcertinaChap
Posts: 14404 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Mr Punch's Studio
In my defence I was unsupervised at the time.
Post by merlyn »
Fishnish wrote:Is there any advantage to looking at the higher specced and consequently more expensive units, taking into account that our source internet speed is never wonderful after it's journey down over a kilometer of copper?
It could be worth distinguishing between the WAN and the LAN. The WAN -- the wide area network -- is on the other side of your router. You connect to your ISP and the whole rest of the internet. The LAN -- the local area network -- is on your side of your router. It's all the devices in your house.
The Tegeler is using the LAN, not the WAN so the speed of the internet connection coming into your house is not a factor in controlling hardware over the LAN.
merlyn
Posts: 1545 Joined: Thu Nov 07, 2019 2:15 am
Post by 1024-QAM »
I wouldn’t think you would have any noise issues using them. I think they operate somewhere between 10 and 30 MHz at around 2V peak to peak. They shouldn’t have anymore impact than any switch mode power supply. The networking topology used for Ethernet over power creates a single collision domain so if you have more than one end on the power line you suddenly have the situation where multiple devices might be trying to transmit at the same time. Causing collisions and resulting in dropped packets and an increase in latency. But excluding all the technical dribble they do seem to work ok so I would just give it a go. Just try get the 2 ends as close together as you can to minimise any cable losses and issues with time domain the faster the packet gets from point a to point b with the best SNR possible the faster and more reliable it will be.
Another thing to look at if you have access to the roof space is putting a Wifi access point in the roof if you use a good quality AP as long as your ceiling hasn’t got any metal lined insulation between the AP and your target devices it should work ok. Use a POE access point and you only have to run the single Ethernet cable. The biggest upside to this is you can then run as many devices as you like think phones tablets ect. Something like the Ubiquity AC PRO or AC LR.
1024-QAM
Posts: 18 Joined: Thu Apr 01, 2021 1:05 pm
I know nothing please explain things to me like I am 5
I use them here in my shed because the wifi doesn't quite reach this far. Mine are badged D-Link and are generally pretty good. Maybe once every two or three months one of them will throw a bit of wobbly but just unplugging and plugging everything in again sorts them out.
Posts: 28059 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Fishnish »
Hugh Robjohns wrote:They were TP-Link TL-PA4030 500Mbps powerline adapters. I wouldn't use TP-Link units again...
We currently have a box full of the last 2 decades worth of broken and obsolete telecom and internet bits + bobs waiting to go the tip. I notice one brand is particularly well represented in it. Buy cheap buy twice and all that.
ConcertinaChap wrote:I don't use powerline now, I eventually went to hard wiring the house. Real wire is always best if you can do it, faster and problem free and a cable can be up to 100m long so distance is not a problem. Having said that, if you must go powerline then when I did use it I standardised on Solwise kit and had decent problem-free performance.
I'm looking into hard wiring as a best option. Of course, it would have been easier if we'd thought of it of it whilst initially configuring the extension wiring a few years back! Failing that, it seems as though a powerline setup might work ok as an option B. It's a relatively cheap and easy option to investigate anyway.
Thanks everyone for the useful technical info and advice.
Fishnish
I don't quite understand why you need to connect to your router. All you need is a network switch to go between the computer and the Tegeler Creme RC. You will need to assign static IP addresses to both devices though. If you don't want to assign IP addresses manually you could use an old spare router as both a switch and a DHCP server - the DHCP server will automatically give each device an IP address.
Powerline adaptors don't usually cause interference at audio frequencies but short wave listeners hate them.
Posts: 15868 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Fishnish »
James Perrett wrote:I don't quite understand why you need to connect to your router. All you need is a network switch to go between the computer and the Tegeler Creme RC. You will need to assign static IP addresses to both devices though. If you don't want to assign IP addresses manually you could use an old spare router as both a switch and a DHCP server - the DHCP server will automatically give each device an IP address.
TBH I'd rather not have it connected to the router full time. I've tried setting it up manually both with a switch and without, using the info supplied from Tegeler, but can't get the plugin to recognise the static IP address. Could certainly try using an old router rather than a switch though.
Fishnish
James Perrett wrote: Powerline adaptors don't usually cause interference at audio frequencies but short wave listeners hate them.
Exactly!
The things crap all over long established and well used bands. Personally I won't touch them with a barge pole. The alternatives might be slightly less convenient, but will be much better in every possible respect.
Post by n o i s e f l e ur »
What IP address does the Tegeler unit sit on when it's directly connected to the ethernet port on the computer?
Is it perchance something in the range of 169.254.0.0 through 169.254.255.255?
n o i s e f l e ur
Posts: 424 Joined: Sat Aug 04, 2018 6:20 am
Exactly!
Except where the alternatives don't actually work... ;)
Post by Fishnish »
n o i s e f l e ur wrote:What IP address does the Tegeler unit sit on when it's directly connected to the ethernet port on the computer?
I'm not in there just now but the number 10.20.30.44 rings a bell
Fishnish
Hmmmm - not quite the same issue I was thinking of - and probably simpler to fix as a result.
Are you on Windows? Can you do an "ipconfig / all" when it's connected directly to see if its IP address is marked as "preferred"? Or whatever the MacOS equivalent is these days?
It sounds like Tegeler have hard-coded the address into the plugin or whatever helper app (if any) and there's an issue with DHCP afoot.
I think your easiest and cheapest fix here is to install a second NIC and connect the unit directly to the computer. There's really no good reason I can think of to have it reachable from the LAN generally, as per your description.
n o i s e f l e ur
Post by Nazard »
"The things crap all over long established and well used bands. Personally I won't touch them with a barge pole. The alternatives might be slightly less convenient, but will be much better in every possible respect."
I agree, Will and James! I transmit, (have an amateur radio licence), and like many others, weak signal propagation is something I am involved with. I use software defined radio (SDR) very often, and being able to view 10MHz of the spectrum at a time, you can see the ADSL, Powerline and other RF pollutants. Of course OFCOM couldn't care less..................
Nazard
Posts: 745 Joined: Sat May 15, 2010 12:00 am
Post by Mixedup »
I've been testing a Crème RC and had a similar issue, which turned out to be an error in the otherwise very helpful quick start guide, whereby they printed the IP for a different Tegeler unit. Try incrementally changing the final digit of its IP address, staying in the 40s. So .40 then .41 etc. to establish a connection. (I can't be sure off hand but I think .47 did it for me.)
Mixedup
Post by Fishnish »
Mixedup wrote:I've been testing a Crème RC and had a similar issue, which turned out to be an error in the otherwise very helpful quick start guide, whereby they printed the IP for a different Tegeler unit. Try incrementally changing the final digit of its IP address, staying in the 40s. So .40 then .41 etc. to establish a connection. (I can't be sure off hand but I think .47 did it for me.)
Thanks, I'll give that a try. Was planning to give Tegeler a call today anyway but I'll try that first. I'm also due due speak to my pal the electrician who did the wiring in the studio and find out how all the cable is routed - if it's not too hard to get a network cable through, I might just do it anyway. Notwithstanding the Tegeler issue, It's got to be better than trailing a 100 foot cable across the floor of half the house every time I want to use the internet in the studio.
Fishnish
Very old buildings often have a vast, continuous loft space. It might therefore be possible to go up from the router, across the ceiling and down into the studio?
An alternative could be to run a cable outside in some 40mm waste pipe to keep the vermin off it? Even on listed buildings I think they allow you plumbing!
Posts: 18109 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
