What is your favourite distortion plugin and why?
You can tell a lot about a musician/mix engineer/producer about the plugins they use.
With this in mind, pray, share with us what your favourite distortion plugin is and why?
Re: What is your favourite distortion plugin and why?
TheLegit wrote:Fabfilter Saturn is good, can really mangle audio in ways I've not heard elsewhere
Good man.
For gain management I'm happy with Cubase's in-channel tube emulation. For anything more overt it's Soundtoys Decapitator.
But I do still miss the simple, humble, free TubeBaby that was the victim of 64-bit.
Depends what you mean by distortion. I like SoundToys Devil Loc for mangling sounds, Temper from Creative Intent is good too.
For guitars and instruments I just tend to head to amp/cab emulations - either the free Reaper option or Voxengo's version that was shared on here earlier but I can't currently remember the name of.
I'm just about to buy decapitator as it's the last thing on my plugin list and has just come on sale.
Forum Aficionado -
Posts: 24583 Joined: Sun Jul 05, 2015 12:00 am
Ignore the post count, I still have no idea what I'm doing...
blinddrew wrote: ...Voxengo's version that was shared on here earlier but I can't currently remember the name of.
You probably are talking about Boogex, which I also discovered on that previous thread and am currently using quite a bit myself.
Saturn 2 is penultimate for me. Sound design craziness, subtle warmth, pinpoint accuracy, and flexibility. It would be my desert island only saturator choice!
In the other various grab bag of different flavours I often sprinkle in -
Kazrog True Iron - Wonderfully subtle touches of warmth, so easy to use.
Blackbox Analog Design HG-2 - Presets feel like cheating, really quick results !
Soundtoys Devil Loc - Technically a compressor, but I usually use just touches of the compression and mostly the distortion. I love the obnoxious crushing-crunching sounds out of it that I season to taste with the mix knob.
Ooh this is a really tricky one for me to answer, as I'm far more likely to reach for a 'preamp' plug-in to add some grungy character than an all-out distortion plug-in. My favourites for this are Fuse Audio Labs VPRE-2C (because you can grunge up the low end, high end or all of it), and Black Rooster Audio VPRE-73, although Kazrog True Iron made regular appearances in my mixes for even more subtle warming (I'm not so keen on it when driven really hard into distortion).
I do use Decapitator occasionally for distortion, but only once again on more subtle settings. My most recent favourite for all-out distortion is the incredibly versatile Fuse Audio Labs Dozer Drive (Fuzzface and Green Screamer stomp pedals in series or parallel), and for more creative destruction Unfiltered Audio Indent 2.
If I had to pick just one I'd go for Dozer Drive:
Last edited by Martin Walker on Thu May 13, 2021 10:09 pm, edited 3 times in total.
Posts: 20634 Joined: Wed Jan 13, 2010 8:44 am
Decapitator. You can always get the sound you need....the black box emulation is quite good too...but it depends...the std Cubase stuff does the job, still love me a quadrafuzz...
Airfix wrote:Zukan wrote:You can tell a lot about a musician/mix engineer/producer about the plugins they use.
Indeed! What does Zukan distort with?
I use different ones for different flavours, but:
Saturn 2
Decapitator
VSM-3
SDRR
Blackbox
BX Saturator V2
SSL X Saturator
J-37
manwilde wrote:blinddrew wrote: ...Voxengo's version that was shared on here earlier but I can't currently remember the name of.
Yes, that's the one!
Forum Aficionado -
coreyautobee wrote:Saturn 2 is penultimate for me. Sound design craziness, subtle warmth, pinpoint accuracy, and flexibility. It would be my desert island only saturator choice!
Did you find it a major upgrade from Saturn
I have a Softube Console 1 + Fader combo, so I tens to use the drive options on that (I have a couple of extra ‘channel strips’ for it, and since I own it, their Tape plugin also appears as a drive option)
I also like IK’s Saturator X. It does nice things.
- Aled Hughes
Posts: 1746 Joined: Tue Oct 24, 2006 12:00 am
TheLegit wrote:coreyautobee wrote:Saturn 2 is penultimate for me. Sound design craziness, subtle warmth, pinpoint accuracy, and flexibility. It would be my desert island only saturator choice!
I never used Saturn 1, but judging from the old GUI and the consistent quality from FabFilter I trust that their new versions are meaningful improvements!
Most used is the bus saturation knob in Mixbus32c, followed by the saturation and soft clip options within uhe presswerk.
- Funkyflash5
Regular - Posts: 215 Joined: Thu Apr 26, 2018 12:43 am Location: Wisconsin, USA
I like the distortion that comes out of Amplitube 5 or Bias FX 2. I also like Trash 2 and some of the presets in EZMix for guitar sound pretty good.
- alexlimbert
Poster - Posts: 27 Joined: Thu Feb 07, 2019 6:50 am
Scuffham Amps S-Gear is fantastic for guitar, I haven't tried it on other instruments but I imagine it would be great if you're after an overdriven amp sound with speaker IR.
I also use Trash 2 quite a lot, very flexible from subtle to totally wild with loads of interesting options for sound mangling including filters, delay, eq, IR options, etc
- groovelator
Poster - Posts: 68 Joined: Tue Oct 21, 2003 12:00 am Location: Bristol, UK
