After a few goes on Modular Grid, assisted by real-world alpha testing, I came up with the following: https://photos.app.goo.gl/c5PFJsW8mptXM8mB7
So, a quick walk through of the skiff:
1 Master clocking and additional trigger pulses are from Pamela's Workout
2 Pam's also feeds the MIDI <>CLK module for clock divisions and MIDI clock feeding the RV-500 for tempo-sync'd delays
3 Intellijel Quadra is providing VCA and filter envelopes
4 Make Noise Dynamix is acting as a VCA here, as well as sub mixing the levels of the analogue voices
5 2x Oscillation VCOs and 2x Doepfer LPFs
6 Steady State Modbox for modulating PWM and sample & hold duties
7 Intellijel Mixup for sub mixing the modular, 808 kick, and external synth
8 WORNG LRMSMSLR mid-side processor that adds reverb and delay to anything panned left or right whilst keeping the kick drum dry
9 Tip Top Audio BD808 kick drum module
It's a bit of a misnomer because there is no sequencing here, it simply wouldn't fit using the modules I have. It's still very much a work-in-progress because I will have to settle on which sequencer I want to use and am currently torn between the power of the NerdSeq vs the immediacy of the SQ-1. There really is no contest in terms of sheer versatility, but I interact very differently with the one vs the other, and for this setup, I think the SQ-1 may be the better option.
As an accompanying synth, I am also equally torn between the DSI MOPHO and the MiniBrute, for pretty much the identical reasons: the MB has an integrated keyboard and the parameters are right there, whereas the MOPHO has presets, 2 VCOs and an onboard sequencer if needed.
