Buying microphone cable, 100m drums.
Re: Buying microphone cable, 100m drums.
Post by Mike Stranks »
Most mixers specifically designed for broadcast have microswitches in the fader tracks. This meant that when I was in BBC Local Radio, faders could:
* Switch on the Red Light when a mic channel was opened
* Mute any loudspeaker in the room when a mic channel was opened
* Auto-start a CD player (f'r instance) when the relevant channel was opened
... and of course being BBC faders they opened by being pulled towards you! :)
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
In addition, on big network broadcasting consoles, the same microswitches could also be configured to auto-cancel the channel's PFL mode, and unmute any pre-fade audience PA foldback sends.
Sadly, the days of faders opening towards the operator are long gone.
Posts: 42200 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Wonks wrote: Tue Jul 27, 2021 4:38 pm If you've got 100m drums, you're going to need some bloody long drumsticks! :D
And a gargantuan Persian rug! ;)
Posts: 4614 Joined: Mon Jul 21, 2003 11:00 pm Location: A studio deep in the fenlands of Cambridgeshire, UK
➡️ ➡️ FREE 2nd Edition RECORDING TECHNOLOGY eBook
🔎 Search 17,722 SOS Reviews+Techniques web articles plus 6,909 News stories (more added each day): www.soundonsound.com/search
➡️ 🆘 SUBSCRIBE to SOS Print / Digital magazine
www.soundonsound.com/subscribe - help support your favourite content provider in the Music Technology & Recording space.
➡️ 🎙️ 🔊 🆘 Podcasts - Listen to 190+ ear-grabbing episodes across 3 SOS Podcast channels - more podcasts released weekly. Search "Sound On Sound" on Apple, Amazon, Spotify.
Hugh Robjohns wrote: Tue Jul 27, 2021 6:04 pm Sadly, the days of faders opening towards the operator are long gone.
Just turn the mixer around 180° - instant nostalgia! :tongue:
Posts: 9596 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by RichardT »
And an elephant to hear the fundamental.
RichardT
Posts: 4984 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by Dan LB »
Hugh, why do you say ‘sadly’? Do find reverse faders more intuitive or preferable in some way?
The option is there on a couple of Calrec Alphas that we have but I’ve never tried it. I must give it a shot sometime!
Dan LB
Posts: 1688 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
I found them much easier to use, especially when needing to open or switch between faders quickly.
Reversed quadrant faders were the best, ergonomically -- that up and over action follows the natural movement of the wrist very well -- but reversed flat faders are okay.
To open a fader to a set level, you just drop your thumb in front of the required fader level, and then use your 3rd/4th fingers to pull the fader up to the thumb. Fast, accurate and comfortable.
It's not as easy to place your 3rd/4th finger beyond the mark and push the faders up with a thumb. Possible, of course, but it's not as comfortable or easy to do, and I don't think it as accurate or precise, either.
For semi-static music mixes the faders direction makes little difference, but for a fast news or panel programme it really does!
And then there are other practical benefits, like not accidentally knocking a faders open with your jacket sleeve... ;)
Post by Rob Kirkwood »
Also gives you space to put your coffee cup.
Rob
Rob Kirkwood
Posts: 135 Joined: Tue Jan 07, 2003 12:00 am Location: Nottingham, UK
:shocked::o:shock:
I’ve got a red LED studio light, it’s only small, but it works, I’ve just never got around to wiring it up.
Posts: 19893 Joined: Sat Jul 12, 2003 12:00 am
Post by Music Wolf »
Hugh Robjohns wrote: Tue Jul 27, 2021 10:02 pm And then there are other practical benefits, like not accidentally knocking a faders open with your jacket sleeve... ;)
For the benefit of any younger readers who may have wandered in. This is how we used to lay down those sick beats back in the day.
Music Wolf
Posts: 2865 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Back in the day? Look into the studio and you can see Ed Sheeran! This is cutting edge technology.
Posts: 18308 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Wonks wrote: Wed Jul 28, 2021 8:30 am Back in the day? Look into the studio and you can see Ed Sheeran! This is cutting edge technology.
We’ve got frosted glass on our studio door, the control room is in the basement, and the live room is upstairs, what I need is CCTV.
I'm nearly out of Brylcreem.... :lol:
Hugh Robjohns wrote: Wed Jul 28, 2021 9:40 am I'm nearly out of Brylcreem.... :lol:
A little goes a long way with you these days. ;)
Music Wolf wrote: Wed Jul 28, 2021 8:01 am
So presumably all these microphones are fully open? (Other than channel 8)
Posts: 28077 Joined: Sun Jul 05, 2015 12:00 am Location: York
Nope. That's a commercial music studio (Abbey Road?) using the faders in what has become the 'conventional way', not a BBC studio.
The real reason the BBC used faders opening towards the operator is entirely logical.
The early broadcast consoles, like this Type B desk, used rotary faders -- big knobs that you operated by rotating your wrist. They were fast and accurate, but you could only operate a maximum of two at a time.
Then someone came up with the idea of a 'linear fader' with a pivoted arm which dragged contacts across an arc of studs, each connected to a chain of resistors to make an adjustable balanced attenuator. (Note the two microswitches which operate at each end of the fader travel.)
This arrangement allows a lot of faders to be placed next to each other so that several could be operated with separate fingers, allowing multiple channels to be balanced simultaneously, and allowing far more channels to be controlled in a compact desk.
However, the fader knob obviously travels on an arc -- it goes up and over. Here is a Painton quadrant fader looking end on, with a BBC fader scale.
If that is installed into a flat console desktop, then the scale numbers on the side away from the operator (0-10) become invisible and so it's impossible to open the fader accurately to a particular mark because you can't see it.
But if the fader is configured to open towards the operator, it becomes very easy to open to a particular setting because that's marked on the side facing the operator.
Standard BBC practice was to use 23 (the scale goes up to 30) as the unity gain point on the fader. During rehearsals the operator would 'take levels' and note down the required fader setting on the script -- 20, 23, 27 or whatever it might need. During the recording/broadcast they would note the required value from their script for an upcoming source, place their thumb on the scale in the appropriate position, and be confident that they would open the fader to exactly the right mark every time. The up-and-over action also worked very well with the human wrist -- it is a very natural movement.
EMI also used Painton quadrant faders, but with a different scale and in the opposite direction. The scale had 'Out' at the near end (off) and went up to (I think) +20 at the far end, with ) at the unity mark.
Another nice feature of those Painton quadrant faders was that they could be fitted with lightbulbs at each end to illuminate the perspex cover. That could be used to indicate active channels or, when different colour bulbs were used, to indicate channel group routing (or other functions).
This was over forty years before Studer decided to 'invent' the idea of coloured fader slots to indicate channel routing etc, and patent it as 'FaderGlow'... (Now also seen on some Soundcraft digital consoles too)
I’m trying to pin down those large monitors, I see a Quad 33/50e under the right hand speaker, but can’t work out what those monitors are.
Post by nathanscribe »
Fascinating! Something new every day etc :thumbup:
nathanscribe
Posts: 1542 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
Post by Dan LB »
Thanks for the info Hugh. Fascinating stuff indeed.
I’m definitely going to have to try it out.
As for the ‘fader glow’ you can also find it on some newer Calrecs too…
Dan LB
Arpangel wrote: Wed Jul 28, 2021 10:31 am I’m trying to pin down those large monitors, I see a Quad 33/50e under the right hand speaker, but can’t work out what those monitors are.
My guess would be Altec Lansing 605A 'Duplex' monitors
Here's the 'hi-fi' version:
Comprised a 15-inch woofer with a mid/treble horn. Used at Abbey Road in the pop music studios (2/3 -- and that picture looks to me like it's Studio 3) from the 1960s.
Dan LB wrote: Wed Jul 28, 2021 10:52 amAs for the ‘fader glow’ you can also find it on some newer Calrecs too…
Ah... well... there's an interesting story there.
I don't know what the current situation is with Calrec, but I believe Studer tried to prevent Calrec from using their coloured ID strips alongside the faders by claiming the patent they somehow were granted on their own 'FaderGlow' system covered Calrec's system too because it was conceptually similar (but physically completely different).
Studer's engineering of the FaderGlow system is quite clever and typically Swiss. But I still struggle to understand how they could claim FaderGlow as a unique invention when the concept of electronically selectable coloured, back-lit faders or fader slots or fader escutcheons, as an aid function identification, pre-dates their design by nearly fifty years, and with at least four practical implementations of similar schemes in existence in the UK alone!
The first implementation of the idea that I know of was with the Painton faders, as already discussed. The next I know of was when SADiE introduced coloured virtual fader slots to indicate different fader automation modes in V3.0 of their DAW, which was around 1996.
One of the nicest implementations of the concept of changing fader colour to indicate function was from Audix Broadcast (UK). They showed a really clever and fully functional prototype system in 2001 where the actual fader knob changed colour. Sadly, AFAIK no commercial product was ever made with their technology.
Calrec's system on the Apollo desk (as in the image above) was around the early 2000s, as in your picture and it used a strip of multicoloured LEDs running alongside the fader slot.
In contrast Studer's FaderGlow system uses an end-lit perspex strip mounted inside the fader slot.
I now want an old BBC console.
Just because.
(I don't want to have to maintain it though! :D )
:-D
Actually, not that hard to maintain. All discrete components on relatively spacious circuit boards in well-engineered chassis, and wonderfully detailed comprehensive service manuals still exist.
This is a section of a BBC Type D console -- the type I did my first live broadcasts on:
And here's a typical* channel module:
*This particular module is supposed to be from an EMI console, but it is uncannily similar to the BBC Type D...
