Buying microphone cable, 100m drums.
Re: Buying microphone cable, 100m drums.
Post by Mike Stranks »
Most mixers specifically designed for broadcast have microswitches in the fader tracks. This meant that when I was in BBC Local Radio, faders could:
* Switch on the Red Light when a mic channel was opened
* Mute any loudspeaker in the room when a mic channel was opened
* Auto-start a CD player (f'r instance) when the relevant channel was opened
... and of course being BBC faders they opened by being pulled towards you! :)
Posts: 8790 Joined: Fri Jan 03, 2003 12:00 am
In addition, on big network broadcasting consoles, the same microswitches could also be configured to auto-cancel the channel's PFL mode, and unmute any pre-fade audience PA foldback sends.
Sadly, the days of faders opening towards the operator are long gone.
Posts: 32779 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Wonks wrote: Tue Jul 27, 2021 4:38 pm If you've got 100m drums, you're going to need some bloody long drumsticks! :D
And a gargantuan Persian rug! ;)
Posts: 3877 Joined: Mon Jul 21, 2003 11:00 pm Location: A studio deep in the fenlands of Cambridgeshire, UK
Search 15,579 SOS Reviews+Techniques articles: www.soundonsound.com/search
Hugh Robjohns wrote: Tue Jul 27, 2021 6:04 pm Sadly, the days of faders opening towards the operator are long gone.
Just turn the mixer around 180° - instant nostalgia! :tongue:
Posts: 6774 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by RichardT »
And an elephant to hear the fundamental.
RichardT
Posts: 1508 Joined: Fri Aug 13, 2004 12:00 am Location: London UK
Post by Dan LB »
Hugh, why do you say ‘sadly’? Do find reverse faders more intuitive or preferable in some way?
The option is there on a couple of Calrec Alphas that we have but I’ve never tried it. I must give it a shot sometime!
Dan LB
Posts: 1626 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
I found them much easier to use, especially when needing to open or switch between faders quickly.
Reversed quadrant faders were the best, ergonomically -- that up and over action follows the natural movement of the wrist very well -- but reversed flat faders are okay.
To open a fader to a set level, you just drop your thumb in front of the required fader level, and then use your 3rd/4th fingers to pull the fader up to the thumb. Fast, accurate and comfortable.
It's not as easy to place your 3rd/4th finger beyond the mark and push the faders up with a thumb. Possible, of course, but it's not as comfortable or easy to do, and I don't think it as accurate or precise, either.
For semi-static music mixes the faders direction makes little difference, but for a fast news or panel programme it really does!
And then there are other practical benefits, like not accidentally knocking a faders open with your jacket sleeve... ;)
Post by Rob Kirkwood »
Also gives you space to put your coffee cup.
Rob
Rob Kirkwood
Posts: 92 Joined: Tue Jan 07, 2003 12:00 am Location: Nottingham, UK
:shocked::o:shock:
I’ve got a red LED studio light, it’s only small, but it works, I’ve just never got around to wiring it up.
Posts: 9626 Joined: Sat Jul 12, 2003 12:00 am
"Don’t let the noise of other peoples opinions drown your inner voice"
Post by Music Wolf »
Hugh Robjohns wrote: Tue Jul 27, 2021 10:02 pm And then there are other practical benefits, like not accidentally knocking a faders open with your jacket sleeve... ;)
For the benefit of any younger readers who may have wandered in. This is how we used to lay down those sick beats back in the day.
Music Wolf
Posts: 2516 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Back in the day? Look into the studio and you can see Ed Sheeran! This is cutting edge technology.
Posts: 12265 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
