Looking for a decent pedal power supply
Post by Ben Asaro »
I've been having increasing issues with noise using a 1-Spot for my pedals. Sooo ..
I am looking for a power supply for 5 pedals, all in the 200mA range. I am thinking of the strymon Ojai.
Does anyone here use one? Thoughts? Alternative recommendations?
Ben Asaro
Posts: 2306 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Re: Looking for a decent pedal power supply
Post by Dan LB »
I haven't used the Styrmon, but I do have a few of their pedals and the quality is top notch. I'd imagine their power supplies are too. I doubt you'd go wrong by getting one. :thumbup:
I have a Palmer PWT 05 MkII which would seem to fit your needs. 5x 9V outputs @ 250mA each - costs about €80. Not sure of availability on your side of the pond though. I've had it for about 3 years now and it's never given any trouble.
Dan
Dan LB
Posts: 1664 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
Post by Ben Asaro »
Thanks! Most of the pedals I will be using need more than 200mA each.
Ben Asaro
Post by al_diablo »
The one spot pro is fully isolated and well priced
al_diablo
Posts: 227 Joined: Thu Jul 24, 2003 12:00 am
Ben Asaro wrote: Wed Sep 15, 2021 9:28 pm Thanks! Most of the pedals I will be using need more than 200mA each.
Maybe giving the full mA requirements per pedal will help, otherwise you’ll be looking up a lot of recommended PSUs that simply aren’t up to the job.
Posts: 15721 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by Ben Asaro »
I’m going to go with the Ojai or Zuma, was mostly curious to see if anyone else here used one, but then I saw some demos that convinced me.
Ben Asaro
The separate PSU is a weak point for me. A shame they haven't got an integral IEC option.
Post by Ben Asaro »
I agree, but it’s not a deal breaker for me.
Ben Asaro
Post by ore_terra »
I have an Ojai. What can I say about it… it’s a power supply: if you can’t notice it it’s doing its job well. I dont notice it at all :mrgreen:
ore_terra
Posts: 1029 Joined: Fri Dec 02, 2016 12:56 pm Location: Seville - Spain
casmoestudio.com
I use an MXR Isobrick, works just fine, variable voltage outputs, lots of different loadings.
I’m running my Big Sky, vintage Boss stuff, and a couple more, no noise issues.
Posts: 14836 Joined: Sat Jul 12, 2003 12:00 am
Wu Wei
Post by Ben Asaro »
ore_terra wrote: Fri Sep 17, 2021 6:58 am I have an Ojai. What can I say about it… it’s a power supply: if you can’t notice it it’s doing its job well. I dont notice it at all :mrgreen:
Thanks, that's precisely what I'm looking for! :D
Ben Asaro
Post by Macca_25387 »
GigRig Generator is unbeatable in my opinion. Had one for about 10 years now. Modular so it can grow and shrink as required. Brilliant investment.
Macca_25387
Posts: 19 Joined: Sat May 23, 2020 10:18 pm
