Hi everybody,
I'm using a MOTU828mkII firewire on a Macmini late 2012 with OSX Mojave and I still can't figure out if and how I can address my streaming audio (coming from internet) to my main outs (I set the box in the MIDI-audio panel but with no results); the same is for audio preview: if I press the spacebar I can only hear the audio preview in an analog pair of outputs, 5-6, but I can't change them and I don't understand where this setting is established...
I'm asking if something is no more ok with compatibility between MOTU and OS Mojave but I didn't find anything about it...
Thank you for helping me...
Arturo
motu 828mkII routing in mac os
Re: motu 828mkII routing in mac os
It's a while since I owned a MotU audio interface, but when I did the audio routing was handled by MotU's own utility which over-rode the settings in the Mac OS Audio MiDI setup. I'd start by looking there.
RockinRollin' VampireMan
Thank you BigRedX,
I've tried different setting on cuemix and MOTU audio setup utilities but it appears more like they control audio input more than output...
I'm trying to contact MOTU support but it's not so easy...
Arturo
Arturo
From my memory of using one of those units the main outs are by default on 9 & 10. You should be able to set macOS to use them by opening up the 'Audio MIDI Setup' utility. Select the interface on the left, select the Output tab then click the 'Configure Speakers...' button in the bottom right, then set Left to output 9 and Right to output 10. If 9 & 10 don't work you could try each of the other outputs in turn and use the Test buttons to find the ones that work.
If that doesn't work it's possible you need to change some routing settings in CueMix.
- Black Sheep
Poster - Posts: 25 Joined: Wed Apr 16, 2003 12:00 am Location: Edinburgh
Hi Black Sheep,
i tried quite everything I could, included, what you're suggesting but I can't get out...
At the moment I have audio (file preview, itunes, web streaming) coming from stereo analog outputs 5-6 and I can't change this; even if I try with audio setting and I set 7-8 or 3-4 and the test is succesful (I see it in the led panel) at the end anything changes...
I only could get audio from internet in my main outputs creating a multiple output device (but the name is misleading because I can only choose MOTU main out) but in this case my apple volume remote control is unuseful...
What makes me crazy is that I set audio 5-6 with a previous OS version, I had Mavericks before jumping to Mojave, and it was ok so I'm asking about compatibility....
The situation is different if I use Cubase ore Live: in this case I can route output and inputs as I want, fortunately; so it seems that audio software seized audio control...
I'm still trying to contact MOTU support...
Thank you for writing,
Arturo
Arturo
I bought Rogue Amoeba's Loopback a couple of years back.
It's excellent for this sort of stuff.
Never used the MOTU software, but looks like you're on the right lines!
- adamburgess
Regular - Posts: 76 Joined: Sat Nov 03, 2018 12:18 pm
Create an aggregate device adding your 828 to the system ins/outs in the Audio/Midi Setup app then you should be able to use any combination.
Programmer, sound engineer, artist, musician
HI s_e_a_n,
I did it too
but when I select MOTU 828 it only gives me the option for channels 1-2 (main out...).
I also downloaded the ultimate audio setup versio but when I open it there are still old options selected; maybe I should uninstall and reinstall but this is the very last try (I'm afraid issues could be worst than now....)
Thank you
I did it too
Thank you
Looking at https://motu.com/techsupport/technotes/driverlog, it seems like the driver support for the 828mk2 only goes up to macOS 10.13
- Black Sheep
Hi Black Sheep,
it seems so, actually... :-/
I'm trying to get in touch with MOTU tech support...
In the meanwhile I downloaded MOTU mac audio installer from https://motu.com/download (it mentions 828x) and I installed it (v. 1.6 83634) with no troubles but anything changed...
Hope MOTU tech support will definitely clarify this question... I'll let you know
Thank you,
Arturo
Thank you,
Arturo
Did you not buy the motu to use in a DAW? I guess that's one major question I also have for you..
I hope you find a solution. I'm also planning on getting an old mk3.
- wearashirt
Regular -
Posts: 83 Joined: Wed Jun 09, 2021 4:18 am
