low end on jazzy guitar won't fit in the mix
Post by Vlaaing Peerd »
I'm mixing recordings of a friend's band, but in one of the tunes I'm really struggling with getting the guitar to fit in the mix.
It's a jazzy tune, where he is playing a semi-acoustic jazz guitar lead with a lot of octaves, similar to the sound of Wes Montgomery/George Benson style of playing. The rest of the tunes are more funky and I have no trouble mixing those.
When playing solo I really got the sound right, but compared to pop/rock guitar there is really quite a lot of low end. If I remove it, it simply doesn't sound like a jazz guitar anymore but the track is begging for that sound.
In the mix it's competing with the electric bass and the lower notes of a Rhodes piano, where I either need to drown out those, or just cannot have that fat wooly jazz sound on the guitar.
So I listened to old jazz records, but there I notice the (upright) bass is much lower in levels than a modern recording and pianos generally more brittle and thin, which obviously provides the space for a fat guitar.
In my case I do need the bass to stand out more than that and I can't settle for a thin-sounding Rhodes either.
Likely I'm not the first person to run into this and I'm wondering if others have experience in fitting in a jazz guitar without compromising that typical low end sound.
Vlaaing Peerd
Posts: 59 Joined: Wed Jun 02, 2010 12:00 am Location: Groningen, Netherworld
who is Kees and why is he so special?
Re: low end on jazzy guitar won't fit in the mix
Sounds like the arrangement really needs reworking to accommodate the instrumentation more effectively, and then a new recording done.
That, or greater compromise in the tonality of keys, bass and guitar.
Posts: 37586 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by MOF »
You could subtly duck the piano and bass when the guitar is playing the low notes, using frequency selective compressors.
MOF
Posts: 2214 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
If the arrangement and recording can't be redone, then I think I'd probably start with some automated EQ on all the competing instruments, be really clear about what instrument is leading at each point and drop the competing frequencies from the others at that point. Yes you'll get a bit of tonal compromise, but you'll be preserving the character of the most important instrument at that point. When the focus shifts, shift your cuts.
If you've got a piece with a bit of back and forth then a bit of dynamic eq / mutli-band compression side-chained to the other source should also give you a bit of space without being too obvious.
Posts: 23101 Joined: Sun Jul 05, 2015 12:00 am Location: York
Ignore the post count, I still have no idea what I'm doing...
Post by Peevy »
How about trying the Wavesfactory Trackspacer plugin? It automatically ducks frequencies in real time. You send the guitar track to the input of Trackspacer which is placed as an insert plugin on the bass track (and/or Rhodes track) It’s very straightforward to use and effective for this type of mixing issue.
https://www.wavesfactory.com/audio-plugins/trackspacer/
Peevy
Posts: 133 Joined: Wed Mar 19, 2008 12:00 am
Thanks, the comments are much appreciated.
Hugh Robjohns wrote: Mon Sep 20, 2021 2:06 pm Sounds like the arrangement really needs reworking to accommodate the instrumentation more effectively, and then a new recording done.
oh the struggles, if I would change the tonality of the Rhodes, it would sound fundamentally different than that same Rhodes on the other tracks. They should overall stay the same sound-wise.
I could ask the keyboard player to rearrange and avoid some lower end playing. The weird thing is that when played live, I hear no problem at all. It really starts to become an issue when it's mixed, so I should be able to mix it with exactly the same arrangement...I think.
It's also not entirely clear why the bass and guitar is competing. They are almost at all times at least one octave apart and the bass is already really muffed and low end.
MOF wrote: Mon Sep 20, 2021 2:29 pm You could subtly duck the piano and bass when the guitar is playing the low notes, using frequency selective compressors.
I avoided side chaining and frequency ducking, with that typical vintage sound, I tried to stay away from techniques that were not applied in those days. But yea, I should have a go at it by now.
I think I will apply all 3 suggestions as subtle as possible in order not to compromise too much compared to how it sounds live.
If anyone has experience with mixing fat jazz guitars, I'd love to hear some advice as there must be some general guidelines for it. It is very different from other styles where the guitars usually have more mid and high end.
Vlaaing Peerd
Post by RichardT »
Jazz guitar in real life does have a lot more bass than on most recordings. It really can get in the way of bass and piano. Its quite a heavy sound, particularly if the player is using thick chords. I would be quite ruthless in cutting lower frequencies from the guitar, and leave the Rhodes sound alone. In my experience that sounds fine.
RichardT
Posts: 3513 Joined: Fri Aug 13, 2004 12:00 am Location: Ireland
blinddrew wrote: Mon Sep 20, 2021 3:06 pm I'd probably start with some automated EQ on all the competing instruments, ...*knip* ... should also give you a bit of space without being too obvious.
That is a very good advice, thanks. In general I didn't have much editing to do on these tracks, the musicians play very well and had their sounds setup nicely. But I will have a go at it, it makes a lot of sense.
Peevy wrote: Mon Sep 20, 2021 3:27 pm How about trying the Wavesfactory Trackspacer plugin?
This might actually be the most work saving effects plugin I've ever seen. As the situation is more like Blinddrew describes, different moments where an instrument needs to be upfront, for this one I'll go the manual route, but this VST is definitely on the way to my toolbox.
RichardT wrote: Mon Sep 20, 2021 3:46 pm Jazz guitar in real life does have a lot more bass than on most recordings.
Yes it's noticeably much more than in other styles, but if I cut it rigorously it sounds nowhere near to how it sounds live and loses that jazz tone.
Well, up to the attic and put all this advice to good use. Many thanks so far and I'll come back here to tell how far I got.
Vlaaing Peerd
Vlaaing Peerd wrote: Mon Sep 20, 2021 5:03 pm
I agree with Drew, and suspect this is one of those situations where some automated EQ should do the job nicely - if it becomes obvious just dial back the amount of EQ adjustment until it isn't, and you should hopefully still hear an improvement in overall mix clarity.
Good luck!
Posts: 20301 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Ultimately I'd be looking at dynamic EQ, but I agree with Hugh - if you're having to fight to make everything fit that fundamentally calls into question the arrangement.
Nothing is sacred when it comes to the mix - if the lows of the Rhodes needs to be manipulated to benefit the whole I'd do it without hesitation. There's only room for one person stage-front-centre at any point in time.
Posts: 19629 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by ManFromGlass »
But in a big band situation didn’t guitar players avoid lower voicings when the band was playing so they cut through better and only use lower voicings when they soloed? This isn’t that situation but maybe the same principles could apply?
Posts: 6306 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Post by RichardT »
ManFromGlass wrote: Mon Sep 20, 2021 5:57 pm But in a big band situation didn’t guitar players avoid lower voicings when the band was playing so they cut through better and only use lower voicings when they soloed? This isn’t that situation but maybe the same principles could apply?
I wish they did. Some big band guitar players are not so sensitive to the needs of the ensemble! Grant Green, however, used to play with an almost acoustic sound where the string noise was a big part of his sound and it had very little body. That worked well. That's why I advocate radically chopping the lower frequencies from the guitar sound.
RichardT
