I'm wondering how I can get the crunchy reverb & phaser sound heard here:
https://www.youtube.com/watch?v=Ay_PkoT23GY&t=56s
or here:
https://youtu.be/wSynp5sY5fU?t=371
but also on many other Lee Scratch Perry productions?
To me it sounds like reverb, phaser, and delay - but I'm not sure.
Thanks for any insights into what effects pedals + models, that are available today, would help to reproduce this sound.
Crunchy Reggae Phaser & Reverb Sound
- Special Monkey
New here - Posts: 9 Joined: Wed Feb 10, 2021 3:31 am
Re: Crunchy Reggae Phaser & Reverb Sound
LSP used an Roland RE-201, Mu-Tron Bi Phase, and probably lots of other stuff. Some hand made.
A good spring verb and a delay will get you in the ball park.
The desk is crucial when mixing it all together. I suppose you could programme it in the box but it probably wouldn't be as much fun and would take much longer.
- ken long
Frequent Poster (Level2) - Posts: 3507 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
It's really quite simple, as Mr Perry himself explains:
""It was only four tracks on the machine," Perry explains, "but I was picking up twenty from the extra terrestrial squad. (...) I see the studio must be like a living thing, a life itself. The machine must be live and intelligent. Then I put my mind into the machine and the machine perform reality. Invisible thought waves - you put them into the machine by sending them through the controls and the knobs or you jack it into the jack panel. The jack panel is the brain itself, so
you got to patch up the brain and make the brain a living man, that the brain can take what you sending into it and live."
Let me know if you have any questions.
- SecretSam
Frequent Poster (Level2) - Posts: 2631 Joined: Tue Oct 29, 2002 12:00 am Location: Officially, I do not exist.
Instant gratification is actually pretty good. It's fast as well.
Ah, right, piece of cake then
Jedi Poster - Posts: 18941 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Posts: 38076 Joined: Fri Jul 25, 2003 12:00 am
Given the 1977 date of the 2nd one (1st video wasn't available to me) I'd suggest the phaser may be a Roland AP-7 Jet Phaser. This had a distortion circuit in front of the actual phaser, so it gave it a very whooshy sound, more akin to an aggressive flanger, but flangers didn't really appear in pedal form until 1978.
A demo of a Jet Phaser here.
https://www.youtube.com/watch?v=HygFy1A_hWc
Of course it may have been one of the other phasers available at the time, like an MXR Phase 45, 90 or 100, or an E/H Small Stone, used in conjunction with a fuzz pedal. or even just a hot signal overdriving the input to a tape echo. Any reverb on the guitar was probably from the amp used.
Wonks wrote: ↑Thu Oct 14, 2021 6:18 pm Of course it may have been one of the other phasers available at the time, like an MXR Phase 45, 90 or 100, or an E/H Small Stone, used in conjunction with a fuzz pedal. or even just a hot signal overdriving the input to a tape echo. Any reverb on the guitar was probably from the amp used.
I believe LSP used a 1960's Grampian spring reverb as a fuzzbox prior to the Mutron Bi-phase to get his characteristc crunchy phaser sound:
“Creating some of those sounds was really hard,” Boyle admits. “That’s when I worked out that the distorted crunchy guitar skanks that Lee has on some of his songs — I mean this took me weeks to work out — were actually really simply done by using the Grampian almost as a Pete Townshend-style fuzzbox. Sending the guitar chops into the Grampian, crunching it up and then sending it straight into the Bi-phase and then through the Space Echo without the echo on and then back into the desk. A lot of stuff, Lee doesn’t remember how he did it.”
Posts: 20388 Joined: Wed Jan 13, 2010 8:44 am
I have no historical info but I had a Peavey classic 50 (iirc) which sounded very much like that.
I have no idea what I did with that amp but I wish I still had it.
- shufflebeat
Jedi Poster - Posts: 8927 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
A site with lots of info on the Grampian 636 spring reverb unit.
https://soundgas.com/features/grampian- ... -type-636/
Germanium transistors, not valves, so driving it hard will give a reasonable fuzz effect.
Thanks for the info!
- Special Monkey
