Hello everyone!
I will eventually upgrade my laptop, because its getting really old and slow, but meanwhile Im using a ton of plugins and plan to grab some more during new years sale. Ive been wondering If i can install and run my VSTS from SSD, so when i get new PC i wont have to reinstall them one by one, which would be such a pain in the neck!
If thats not possible, How do you deal with moving to new PC and synchrinizing your PLUGINs and tools?
Thank you!
Installing and Running PLUGINS from SSD
Re: Installing and Running PLUGINS from SSD
Following the advice of folks here, i made a spreadsheet of the plugins, their locations, any authorisation files, and any instructions from the manufacturer about transferring licences. I wrote to any that didn't have instructions on their websites and they pretty much all replied with appropriate help.
Took a bit of time, but less than trying to fix a problem afterwards.
Forum Aficionado -
Posts: 24573 Joined: Sun Jul 05, 2015 12:00 am
Ignore the post count, I still have no idea what I'm doing...
For the purpose of managing plugin installs, vst and vstis etc fall into two categories.... Those which have only a single dll file, and those which have some supporting file structure (eg sample files or what ever)
The ones which are a single simple dll files can just he moved to anywhere at your convenience and just make sure the file path in you vst set up can find them and they will work. No 're-install required '
The latter, those that have some supporting file structure will need to be re-installed. These are typically any vst/vsti which calls upon some kind of library, often samples, but can be other things.
A review of you program files directory will usually give you a clue as to which ones have library files and therefore require a re-install.
Stu.
Stu.
- Moroccomoose
Regular - Posts: 474 Joined: Tue Apr 12, 2011 12:00 am Location: Leicester
