Hi guys, I just bought a Fractal Audio AXE FX 3 and I wanted to connect it to my UAD Apollo Twin.
The AXE FX has an SPDIF output and the UAD has optical in.
Is that a none compatible scenario? Or is there a cable for that which would be good?
Thanks for any help.
Matthew
SPIDIF to Optical. Does it work ?
- Matthew Seed
Regular - Posts: 394 Joined: Mon Dec 18, 2006 12:00 am
Re: SPIDIF to Optical. Does it work ?
If you're in UK this converter box is readily available, I used it and it works. Note that it does not include the optical cable, or the S/Pdif cable, or the USB power plug. But those are readily available elsewhere (or you probably have them already).
- Tomás Mulcahy
Frequent Poster (Level2) -
Posts: 2230 Joined: Wed Apr 25, 2001 12:00 am
Hi there, thanks for this. Is there such a thing as quality when it comes to something like this. Or is digital - digital !
I guess what I’m saying is I’m plugging a £2300 modelling amp into a £1000 UAD preamp with a £10 box.
I don’t want it to be a case of being the weakest link.
Or is a more expensive one no better quality.
Thanks
Matt
Thanks
Matt
- Matthew Seed
A £10 box like this should work fine - it is probably very similar to the input and output stages of your other units. I use something similar to hook up a Mini-disc player to the rest of my setup. There are possibly issues if you are using high sample rates with some budget units but you should soon hear if there are problems with dropouts and clicks in the signal.
Posts: 12094 Joined: Mon Sep 10, 2001 12:00 am
Matthew Seed wrote: ↑Thu Nov 25, 2021 6:52 pm Hi there, thanks for this. Is there such a thing as quality when it comes to something like this. Or is digital - digital !
The electronics involved are very simple and the few components needed are very cheap. The power supply and the case are probably the most expensive parts!
Posts: 34050 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote: ↑Thu Nov 25, 2021 8:21 pmMatthew Seed wrote: ↑Thu Nov 25, 2021 6:52 pm Hi there, thanks for this. Is there such a thing as quality when it comes to something like this. Or is digital - digital !
Yes, I took one apart and it used a HEX inverter chip, a very fast switch. One way it is fed from an opto-diode and the other it drives an IR LED whole thing is smaller than a postage stamp.
I used a pair for some time getting signals in and out of a MD recorder and 2496 sound card. Never noticed any quality loss at all.
Thank you all for the advice. I shall make a purchase.
Thanks again
Matthew
Thanks again
Matthew
- Matthew Seed
