Am I going nuts (or just ga-ga)?
Nothing to do with music but, I have downloaded 2 .pdf blood pressure logs as my doctor has suggested I monitor my BP. I have bought a machine. 20 quid from a local pharmacy and that works fine.
However, when I open the .pdf charts with Acrobat reader I find I cannot enter any text.
I was doing this for Blackstar some ten years ago with amp test data and I even tried the same W7 laptop I used then after giving up with W10.
So, what is the daft old fekker getting wrong?
Re: Am I going nuts (or just ga-ga)?
Are they definitely editable pdfs, or just standard pdfs you're supposed to print out?
- Random Guitarist
Frequent Poster - Posts: 1134 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
Random Guitarist wrote: ↑Fri May 27, 2022 8:58 am Are they definitely editable pdfs, or just standard pdfs you're supposed to print out?
Wow! That's quick. How can I tell Random? I thought a .pdf was just a .pdf! The whole point of which being you could enter data?
Av' of 2 at 06:45 today 147/76. I actually did see a doctor face to covered face yesterday. She seemed quite anxious to be shot of me!
But yes, getting in is a bind that is why I thought a .pdf log and then I could email it in periodically. Have to find out how to do that though. I use 'systemonline' to get my drugs, probably a way in that.
but I use good old fashioned pen and paper,
This is what I do. Painless and fail safe.
If it is anything liike this one
https://bihsoc.org/wp-content/uploads/2 ... _diary.pdf
There is nothing editable about it. I could convert yours to Word format if that would help.
Hi Dave
What version of Word do you have - assuming you have it? As has been said, later versions have a PDF-Word converter built in...
On my new Win 11 laptop I have opted-out of 'Office' and am using this:
https://www.wps.com/
Comes with various PDF manipulation options... Works well and is compatible with Win 7...
I'm just a 'bread and butter' user and haven't explored if it can do some of the more esoteric functions that Excel, f'r instance, provides...
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
BillB wrote: ↑Fri May 27, 2022 10:17 am If it is anything liike this one
I've always found Acrobat Reader quite confusing and annoying. However, by clicking on the icon for "Sign document by typing or drawing a signature" in the toolbar (Acrobat Reader DC v2022), I was able to fill in the fields on that document and save it.
I use Microsoft Edge as my PDF wrangler, and you can mark up PDFs with it. That's all it's good for these days, which is sad as it had a promising start when it went to chromium.
- resistorman
Frequent Poster - Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Thanks chaps.
Resistorman, I did get Edge to work but tis very fiddly and I cannot change the typeface or density.
I shall print out a form and do it by hand as advised, if I can get my scanner working I could still email it in.
Not sure what kind of phone (if any) you have Dave but I've not used my scanner in ages, a photo of an A4 doc comes through more than good enough for legibility purposes.
Posts: 28044 Joined: Sun Jul 05, 2015 12:00 am
Good enough perhaps Drew but my colour scanner does not 'shake' or screw the geometry. I reckon I could do better with a proper camera than a phone?
I use 'Genius Scan' app on the iPad to scan, PDF and email receipts etc. Very painless once set up and understood - and it allows you to correct wonky perspectives. Also available on Android.
- resistorman
You don't GET "wonky perspectives with a scanner! Geez! Talk about re inventing the wheel!
Dave, you raised the concern about screwing the perspective with a phone, I’m just letting you know that the app can deal with it and, as Drew says, with plenty of resolution to be readable. I use it because I can’t take a scanner on the train, and also because it’s a lot easier even when I am in the office or at home. But if you can get your scanner working, carry on with what you like and know.
BillB wrote: ↑Fri May 27, 2022 11:47 pm Dave, you raised the concern about screwing the perspective with a phone, I’m just letting you know that the app can deal with it and, as Drew says, with plenty of resolution to be readable. I use it because I can’t take a scanner on the train, and also because it’s a lot easier even when I am in the office or at home. But if you can get your scanner working, carry on with what you like and know.
Yeah, I know Be' Just me being a cranky, flippant old sod!
Try the "Fill and Sign" button in Acrobat Reader.
https://helpx.adobe.com/acrobat/using/f ... -sign.html
Click on the button, click on the field, and type away.
(This is assuming that the form has been created with fields, but it probably has.)
