Project Ukulele
For all tech discussions relating to Guitars, Basses, Amps, Pedals & Accessories.
Re: Project Ukulele
Post by Dynamic Mike »
zenguitar wrote:At this rate I'll be making a truss rod cover rather than playing it.
An inverted white 'U' with a pheasantwood veneer?
By the way, do you normally have a logo on your handbuilt instruments?
Dynamic Mike
Posts: 5290 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
Re: Project Ukulele
Post by Sarah Gouldesbrough »
Please do!
Sarah Gouldesbrough
Posts: 4 Joined: Wed Aug 25, 2004 12:00 am
Re: Project Ukulele
Post by dwebb »
I won't argue about the damned silly instrument bit, but I did think that the tuning was effectively the top four strings of a guitar capoed at the 5th fret?
dwebb
Posts: 52 Joined: Wed Aug 26, 2009 12:00 am
Re: Project Ukulele
Post by yelemusic »
dwebb wrote:I won't argue about the damned silly instrument bit, but I did think that the tuning was effectively the top four strings of a guitar capoed at the 5th fret?
Yep, that's right. Which leaves us with G C E A. So you can play all your guitar chords on the Uke (minus the bottom two strings), only their names change. A D-Chord becomes a G-Chord, your average Cmaj (or Am7) turns into Fmaj (or Dm7) and so on.
Takes a little getting used to, but otherwise as a guitarist you shouldn't have any problems playing the Uke.
@Zen
I wouldn't mind having a go on this gorgeous Uke of yours :) Send it over, I'll do that recording for you 8-)
Unfortunately I'm not in the UK :frown:
I'd love to compare it to my commercial made Ukes (which aren't too shabby either). But then again, maybe not, I might end up GASing for a new Uke by the man himself :)
yelemusic
Posts: 16 Joined: Thu Jun 09, 2011 12:00 am
Re: Project Ukulele
I know guys, but it's the four silly strings on a guitar, not the sensible EADG strings :)
And besides, I decided to go for the traditional re-entrant tuning of gCEA with the octave G. Once I get the hang of different chord voicings beyond the first position it'll be fine, but for now some progressions have weak roots and contrary bass movement. Although the first thing I started learning was in B flat which could well be the worst key for those problems :)
So far, no headstock logo. I might come up with one one day, although I like to use the headstock for inlay sometimes.
And I think I have some ebony veneer lying around for the truss rod cover. But tradition dictates that I wait a few months minimum before making one.
Posts: 13021 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Re: Project Ukulele
Post by Kev Adams »
zenguitar wrote:Thanks Kev.
Nothing magical or mystical about the polishing mixture. I just read the instructions that came with the Rottenstone I bought from Luthiers Mercantile and used those as a starting point.
As I mentioned much earlier in the thread, these are the first instruments I've finished with shellac so I am learning as I go.
The instructions basically pointed to using the Rottenstone with a mineral oil as a lubricant and applied with felt pads. There was also a recipe for a polish based on methanol that scared me (as that would soften the shellac) but was more directed at restoring old finishes.
So I searched online, and found some more articles. Read through them, and then bit the bullet and came up with something that made sense to me. I took some Rottenstone, added a drop of washing up liquid as an antistatic/antisurficant and then added White Spirit (mineral oil) until it was the consistency of pancake batter.
So, basically, I relied on existing knowledge and experience, did some reading, and came at it from 1st principles. It worked well, and there was nothing in the mix that could have done any harm.
Thanks for that. It was the soap that intrigued me- I was picturing a bar of lifebuoy! D'oh!
I've got a big jar of polishing powder and one of a polishing talc, which is finer. I've never thought of pre-mixing the powder though. I put some in a small dish, put some polishing oil on my cloth and then pick up some powder with that. it obviously goes to a paste staright away as you apply it.
I do have a proprietary mixed polishing liquid called Super-nicko which is water based. Probably pretty similar to your mixture except for the water. I suspect that ther is something like soap in it too. The powder in that separates out when left for any time, but it reconstitutes easily enough.
If I use the talc for a final final go I put it on neat.
I have several cleaning concoctions too, gleaned from reading around. The simplest which I really like, and some times use with a bit of polishing powder, is eucalyptus oil and olive oil 50/50. Smells great! Not sure whether experts would approve of the organic as opposed to mineral oils though.
Kev Adams
Posts: 169 Joined: Wed Jan 05, 2011 12:00 am Location: MK UK
Re: Project Ukulele
I was about to offer to take the dear little thing off your hands, so helping you avoid the frustration of trying to play it with it's 'silly' tuning, only it dawned on me that I wouldn't know how to play it at all. :D
Posts: 19879 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Project Ukulele
I hear no uke :frown:
Re: Project Ukulele
Post by Frisonic »
Folderol wrote:I was about to offer to take the dear little thing off your hands
What I think is that if Andy doesn't bond with the fruit of his blood, sweat and tears over the next few months we should all chip in so it can be gifted to a suitable trust... which between us we ought to be able to identify. Someone equipped to use it within a well conceived and executed educational project. And in my wildest imagination it should spend time at somewhere like Tate St Ives, where it can be seen and played, along with the entire Project Ukulele thread and interpretive media about the educational project. Just a thought. But only if Andy decides he just ain't going to get into the uke thing for himself.
Project Ukulele has been a wonderful success and deserves to remain an inspiration in perpetuity.
Frisonic
Posts: 2951 Joined: Wed Jan 27, 2010 12:00 am Location: Refugee currently in transition.
Still strictly project but lately on the run.
Re: Project Ukulele
Yes, YES!! I Know!!! I've been slacking, started learning a few chords, even a song or two, then other things cropped up and it sat on the shelf staring at me accusingly. Even jumping off it's precarious perch balanced on my old 12-string mandolin (partially dismantled, awaiting a neck reset) and landing on my pillar drill, managing to chip the shellac discretely in the process :lol:
Then there was the wedding of the decade to attend (it made the back page of The Sunday Independent no less!!), and ordering a load of parts for some of my Arduino based projects....
But yes, I MUST get around to making a recording soon. Just bear in mind that I am largely (but not entirely) dysfunctional AND I live in Devon. ;)
Re: Project Ukulele
Post by Frisonic »
Bond away with it Andy, in your own time mate ;)
Frisonic
Re: Project Ukulele
Post by Frisonic »
Mighty Uke allert!!!
For those living in the UK with access to Sky Arts One: Tomorrow evening, Sunday 4th August at eight in the evening they are screening the excellent film 'the mighty uke'. Followers of this thread will most likely find it as enjoyable as inspirational.
Cheers,
Francis
Frisonic
Re: Project Ukulele
Cheers Francis :)
For one moment I thought you would be hinting for me to get off my fat ass and get a recording of it. And I was about to reply that I have been putting a great effort into eating and drinking too much, so as to make my ass sufficiently fat to get off :)
Re: Project Ukulele
Post by Frisonic »
I wasn't chiding you at all Andy! Although I did think you might enjoy the prog. Watch it if you can. Just the thing to help down a vat of chips and a bucket of scrumpy 8-)
Frisonic
Re: Project Ukulele
Re: Project Ukulele
Post by SoundsRMagical »
Our drummer just bought an electric uke!?!?! Looks like we'll be doing 'Over the Rainbow' anyhow...uh boy!
SoundsRMagical
Posts: 89 Joined: Thu Dec 12, 2013 12:00 am
Re: Project Ukulele
So did this Uke ever get finished? And recorded?
Posts: 18299 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Re: Project Ukulele
Finished yes, recorded not yet.
Although I still need to source a replacement back for the 2nd uke.
Re: Project Ukulele
Now, if you'd come to the meet, you could have brought it with you.
If you had brought it with you, you could have played along with CC
If we'd known that was a possibility there would definitely have been a suitable portable recorder there.
... and all for the want of a horse shoe nail!
Re: Project Ukulele
That Uke took so long that it is now a vintage instrument even though it's new!
Re: Project Ukulele
I keep on meaning to learn how to play it...
But I've settled comfortably into being largely but not entirely dysfunctional. It passes the days.
Re: Project Ukulele
Re: Project Ukulele
Post by octavedoctor »
zenguitar wrote:So, the afternoon started fine, added another drop of water to the glue in the jar as it had all been absorbed. Then we fired up the gas stove and brought the water close to boiling point.
That's when I put the jar of glue into the water.
Remembering first to remove the lid. You don't want it exploding when you heat it!! And when you finish, make sure to leave the lid off/loose until it cools. You don't want it imploding, or seizing the lid on with the vacuum. Here's a closer look, see how it's gone all liquid.
However, before getting on with the glueing I needed to take some precautions. So I put a sheet of greaseproof paper over the baseboard, and then glued some more greaseproof paper to the top boards I made.
And then left them all to dry.
But eventually I had to bite the bullet and start glueing. And I'm afraid there was no time to take pics as I went. I had one clean break and 4 splits to get glued. However, the method is straightforward enough... use small paintbrush and dip into the liquid glue, paint glue along split/wood to be joined. I applied glue from both sides, and worked the wood a little to draw as much as possible into the repair.
Then it was straight into the jig for clamping. And the clamping pressure comes from the loops of string you can see.
The secret is to tighten the loops like a Spanish Windlass. It's a very old woodworker's technique that can apply a LOT of pressure with remarkable control. I use a variation of the technique to glue broken headstocks and the only real problem is that it is incredibly easy to put too much pressure on the joint.
The wooden blocks are there to make sure that there is plenty of downward pressure to ensure that the back remains flat, as well as the cauls applying the sideways pressure to clamp the glue joints tight.
And now I am just waiting. Hide glue dries initially by gelling, and then by evaporation. With the baseboard and top plates, it will definitely need to be left for close to 24 hours to dry properly. And open, or rubbed, hide glue joints can dry fully in a few hours.
So, fingers crossed. Of the 5 joints required, 4 looked fine. But one was visibly gapping, although less than 1/2th a mm, and I couldn't tell how well it would close without giving it a go.
I'll have no idea whether or not I've been able to save the back until I remove it from the clamping jig tomorrow...
:roll:
Nice work Andy.
The Spanish Windlass is my favourite tool ever because it's so firkin simple.
I've just used it to fix a nasty cross grain break in a chinese Guild (with the afore mentioned Aliphatic resin glue). Damn thing had snapped like a carrot. Not even a shear line break to put a clamp on.
Video on my Facebook page...
Eltham
octavedoctor
Posts: 115 Joined: Sun Sep 07, 2008 12:00 am Location: Bridgend, Cardiff and Bristol
Re: Project Ukulele
Cheers Eltham :)
