James Perrett wrote: ↑Sun Sep 19, 2021 1:46 am If I was in the market for a new amp now I'd see if I could find one of the Monacor or IMG Stageline STA-400D amps. I'm not sure if they are still current but the electronic design looks almost identical to the monitor amps that I built from Hypex modules.
https://monacor.co.uk/sta-400d.html
They're amazing value for money (assuming that they haven't messed anything up in the additions that they've made).
Thank you so much for your response James Perrett, I really appreciate it. Although, I am not very familiar with the brand of amps you have recommended I did have a look and they are significantly cheaper then the Avantone CLA 200 that I was considering, which is great. But I am still a little confused concerning Class D amps as my research consensus was mostly to steer clear of them as they often introduce noise and require some sort of int built noise filter etc. I am clueless in this area so maybe you could explain this?! Once again thank you for your help thus far and I welcome any further help and/or advice you might be able to provide.
