Why the manufacturers of speakers/loudspeakers have not switched to production of speaker with neodymium magnets (especially, those for low freq). In the past two years, are producers who have won several international awards, some even innovation awards, with speakers that use ferrite magnets.
I know there are manufacturers who use neodymium magnet but represent a small percentage.
neodymium vs ferrite magnets in loudspeakers
Re: neodymium vs ferrite magnets in loudspeakers
If ferrite can generate the required flux density within acceptable size and weight constraints, why go to the expense of neodymium?
Posts: 34051 Joined: Fri Jul 25, 2003 12:00 am
While we're at it, can we agree a pronunciation?
...of the N word, that is.
- shufflebeat
Jedi Poster - Posts: 7584 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Hot tip:
I find keeping the good coffee in an old marmalade jar in the fridge makes it last much longer - the kids don't like marmalade.
neo·dym·i·um \ˌnē-ō-ˈdi-mē-əm\
Hugh Robjohns wrote:If ferrite can generate the required flux density within acceptable size and weight constraints, why go to the expense of neodymium?
It makes a huge difference to the sound... of marketing communications
- Logarhythm
Frequent Poster - Posts: 1092 Joined: Fri Mar 30, 2012 12:00 am Location: On an intergalactic voyage to collect fresh electrons
Hugh Robjohns wrote:neo·dym·i·um \ˌnē-ō-ˈdi-mē-əm\
Ta.
- shufflebeat
Hot tip:
Logarhythm wrote:Hugh Robjohns wrote:If ferrite can generate the required flux density within acceptable size and weight constraints, why go to the expense of neodymium?
It also makes a huge difference to the manufacturers bank balance.. coincidentally, yours too in the opposite direction.
- Folderol
Jedi Poster -
Posts: 14953 Joined: Sat Nov 15, 2008 12:00 am
Yes. I am that Linux nut.
I can lift my 2x10 bass speaker box with one hand since I swapped the original ones for Celestion neos.
Same reason I have swapped out a lot of my gear. Size and weight.
- IvanSC
Frequent Poster (Level2) - Posts: 3039 Joined: Tue Mar 08, 2005 12:00 am Location: UK France & USA depending on the time of year.
Two bottles of Corona lemon and lime, please!
IvanSC wrote:I can lift my 2x10 bass speaker box with one hand since I swapped the original ones for Celestion neos.
It makes a huge difference to your general fitness, as you don't get so much exercise
- Folderol
Jedi Poster -
if we talk about weight, IMO line array systems used for mobile scene, have the most benefit from neodymium
The main market for Neodymium loudspeakers are musicians who gig regularly and have to move their own gear without the benefit of a road crew. So full-range powered PA cabs and bass cabs are where all the innovations are being made and where you'll find people being enthusiastic about the technology.
It's not really an issue with permanent installations like studios, or bands who are successful enough to be able to employ people to move all their heavy speaker cabs about for them.
Also remember that neodymium speakers are not simply conventional ones with lighter magnets. As soon as the chassis no longer has to support the weight of traditional magnets, the designers have a lot more scope for saving even more weight and improving the performance of the speaker. This means that that neodymium based speakers are never going to sound the same as "traditional" ones. And as we all know in the field of audio, what is technically better is not always as pleasing to the human ear that has years of being attuned to a certain type of sound.
RockinRollin' VampireMan
If we take the speaker "A" and turns into a speaker with neodymium magnet "B" the only possible change that I see is some holes marked in red.
If you reduce the size of the chassis, will start to vibrate.
What other changes do you think are possible, to make it sound different?
