Lots of potential things it could be, ranging from the capsule diaphragm shorting out on the backplate at excessive volume, to dry joints on the circuit board, to failing capacitors, to excessive moisture/humidity when singing close and loud.
A cheap 34mm capsule in a t.bone SC450
Re: A cheap 34mm capsule in a t.bone SC450
Posts: 39049 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote: ↑Thu Oct 14, 2021 10:30 am Lots of potential things it could be, ranging from the capsule diaphragm shorting out on the backplate at excessive volume, to dry joints on the circuit board, to failing capacitors, to excessive moisture/humidity when singing close and loud.
That "excessive volume" is really just a more powerful plosive, not superhigh sound pressure. A more pronounced "P" is enough to make it "pop". It really feels like a discharge and temporary loss of power. I'll try to reflow solder joints on both pcb-s and I'll see what happens.
Would be good to know if anyone experienced similar behaviour in any mic and if changing the capsule did solve that (I never had a capsule failing so I don't know what that does). I can order a new SC 450 capsule from Thomann, they sell them for not that much actually, but I'd love to be sure before I do
Other thing is that there's a small transformer in the base of the mic and when I first opened it, it had plastic corners broken off and small pieces dropped out so I suspect that at some point the mic probably was dropped (I bought it used so I don't know for sure). I don't know what the transformer potentially touching the casing would produce. Maybe that's a clue too...
You may well kill it altogether!
The PCBs of most capacitor mics are coated on the solder side to prevent moisture ingress which could cause issues due to the very high impedances involved in the circuitry. Indeed, it may actually be a faulty coating which is causing your problems... but certainly trying to reflow the solder joints will damage that coating.
...plastic corners broken off and small pieces dropped out so I suspect that at some point the mic probably was dropped (I bought it used so I don't know for sure). I don't know what the transformer potentially touching the casing would produce. Maybe that's a clue too...
Could be. Doesn't sound good. I'd certainly check the connecting wires carefully for breaks.
Hugh Robjohns wrote: ↑Wed Oct 20, 2021 1:02 pm
The PCBs of most capacitor mics are coated on the solder side to prevent moisture ingress which could cause issues due to the very high impedances involved in the circuitry. Indeed, it may actually be a faulty coating which is causing your problems... but certainly trying to reflow the solder joints will damage that coating....plastic corners broken off and small pieces dropped out so I suspect that at some point the mic probably was dropped (I bought it used so I don't know for sure). I don't know what the transformer potentially touching the casing would produce. Maybe that's a clue too...
I'll look for any coating, but so far I didn't have the impression that there was any coating on the joints. The PCB is coated to protect the traces, but solder doesn't seem to. I'm building circuits regularly, both through-hole and SMD so I've seen coated plates Thanks so much for the word of advice though. I'm new to servicing microphones, so there might be as well things I don't know, so I'm grateful for every advice.
Do you have an idea what a defective capsule sounds like, or how it behaves? Can it cause this kind of discharge-like temporary cease-of-function?
