Adding a 3rd Tape Head to (mono) Reel-to-Reel.
Re: Adding a 3rd Tape Head to (mono) Reel-to-Reel.
This is almost annoying! I've got a faint memory about something on using a separate head for the bias, opposite the record head, rather than mixing it in the signal.
Ha! Got it :bouncy:
Right here
Posts: 19864 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Martin Walker wrote: Wow, fascinating stuff Hugh - it's not often that we can retrieve data from the past with greater fidelity than at the time :shock:
There are still people working on ways of improving quality from old tapes. I'm currently testing some Dolby A decoding software that claims to retrieve significantly more detail than the old Dolby hardware. There are a huge number of masters that could possibly be improved by using this software.
And of course we have Jamie Howarth's Plangent Process which claims to eliminate wow and flutter using the bias signal or other continuous tones recorded on the tape as a reference.
Posts: 15849 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Yes... I wonder what they'll come up with in the 2060s to improve the reproduction from early digital recordings... :lol:
Posts: 42142 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Elephone »
Hugh Robjohns wrote:Yes... I wonder what they'll come up with in the 2060s to improve the reproduction from early digital recordings... :lol:
...or really early wax recordings! Could AI actually re-imagine them into pristine renditions?
That's another story.
Elephone
Posts: 1114 Joined: Wed Feb 11, 2009 12:00 am
Post by Elephone »
"Martin Walker" Wow, fascinating stuff Hugh - it's not often that we can retrieve data from the past with greater fidelity than at the time :shock:
Have you heard what they did with the Robert Johnson recordings? They may have made even further enhancements since then.
Elephone
I did... and I have some. :-)
Post by Tim Gillett »
Quoting myself here:
Tim Gillett wrote: So I'm not sure that even around 1950 they couldn't make a repro head with narrower gap, so much as they didn't see the need to do so, to go above 15 kHz as the upper frequency limit for playback...
I did a few few quick calculations and cross checked another's figures. https://electronics.stackexchange.com/q ... -tape-head
It seems for a tape repro head to reproduce 20 kHz at cassette speed (1.875ips), its gap length must be 1.2 microns or less. But at 15ips, 8 times faster tape speed, that gap length only needs to be 9.5 microns or less.
In the early to mid 60's, Akai was making tape heads for open reel domestic recording with 1 micron gap lengths. I still have an Akai X-IV portable (Germanium transistors!) which claimed 13 kHz upper freq response at 1.875 ips (cassette tape speed). In the late 1950's, or even earlier, that they couldn't construct a repro head with a gap length of 0.374 thou (9.5 microns),
8 times less critical than what Akai achieved in gap lengths the early to mid 60's seems unlikely.
Tim.
Tim Gillett
Posts: 2698 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
