merlyn wrote: ↑Wed Jan 01, 2020 2:57 pm
Thanks Bill!
That worked and my X25 is fully functional again. I've uploaded all the X25 files to Google Drive :
https://drive.google.com/open?id=1CKgR2 ... YOd_2Dsucy
The pdf describing controller recalibration has a warning about certain button presses that wipe the firmware.
For anyone who has an X25 -- if it's working there is no need to update the firmware. The fix is only to be used if your X25 isn't working, or appears dead.
On Linux flashing the firmware was straightforward using
dfu-util.
On Windows the procedure described in the readme requires XP. In other words something to be avoided unless you absolutely
have to.
THANKS SO MUCH , as far as i know , the photon is the only XY-"Z" AXIS , MIDI ,controller , (ie;- AIR Controlled ) keyboard , and is also extremely well built , full rotary , heavy rubberised vol/mod , and incremental backlit wheels , for dim-light / LIVE environment , I've owned my device , since virtual release date , and , actually was reluctant to go to Win 10 , from 7 , solely because of the photon's UNIQUE xy-z axis , however , it still shows up in Live 10/11 , and Win 10 , so "100 percent IS still, supported " ... which is all great news for all us Photon Users ... but , I lost my support CD , with the ASIO and USB Firmware fix/solution , lest to say I was distraught , as for all the above reasons , it is vital to have the software/firmware back-up.
So , thanks again , AND , to S-O-S , THE BEST ABSOLUTE BEST , source of audio-tech , in the world , great to have found it in the absolute most appropriate place too.
