21:9 screen vs. dual monitors
Re: 21:9 screen vs. dual monitors
Post by CS70 »
James Perrett wrote:I had three screens for a while and found that one of them simply didn't get used much so I reverted back to two which just seems right to me.
Two screens is fine for mixing, but I find I miss a third screen when editing video.
Conceptually I keep separate three zones - timeline, preview and a working area, ideally center, left and right. With two screens, the "working area" (trimmer, file system, plugin, external player etc) is always overlapping something else (and in Windows the interaction between the file explorer, Vegas preview window and returning from a full screen player is always annoying - as it alters the Z-order of the windows requiring one additional click).
So a horizontal three screens configuration would be great.
But since I use the same desk for both video and audio processing, it just doesn't fit... it would make it impossible to have the nearfields anywhere near a reasonable position. Already with two screens my head is a little "inside the triangle" and the stereo image is not as clear as it could be.
Compromises... :D
Posts: 7799 Joined: Mon Nov 26, 2012 12:00 am Location: Oslo, Norway
Post by CS70 »
Folderol wrote:I've only seen them in shop windows. They look weird to me. I suspect you would need one to completely fill your field of view, otherwise your brain will be fighting to differentiate this from the real surroundings.
I guess, as many things, you need to get used to them, trying for a while without preconceptions, before deciding if they're good or not.
They're definitely different, and we always instinctively equate "different" with "bad"..
The question is whether or not to go to the pain of purchasing, recabling, recalibrating and testing only to find out that it's not! :)
Post by CS70 »
Luke W wrote:I’ve got a 21:9 monitor which I intended to run on its own, but I really missed having a second screen quite quickly and added a TV above.
Thanks, yeah, that's what I'm fearing as well :)
A plus is that I'd need to color-calibrate only one monitor instead of two, and just to something that I perceive as a reasonable setup, instead of having to use a lot of time to color match two panels every month that drift in slightly different ways. I'm still pretty slow at color calibration.
The extra screen space is very nice though, I can open up a few plugins while working on an edit and still see enough of everything without dragging windows around. The one I’ve got came with some software that splits the screen into cells so that windows can snap to areas of the screen which can be really useful.
If I had the space I’d probably go for the best of both worlds approach and have two of them side by side :lol:
Yeah I've tried the cell-splitting software at the shop and it's really completely removed one of my main concerns (I hate resizing windows)
Post by ManFromGlass »
Justification #253B -
At least 2 is good because One could break so there will be a “spare” until the new one arrives. And they only break just before a deadline or a producer is coming over.
If you ordered a curved one from amazon or such you could always return it no questions asked.
Posts: 7492 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Post by CS70 »
ManFromGlass wrote:Justification #253B -
Ahah yeah I have plenty 27" monitors at home. Could have one up per room.
What I usually do is that I buy used and resell in case. New costs too much for anything that's obsolete after a couple years imho.
Compromises... :D
Raise the monitors over the screens and point them downwards?
Posts: 28092 Joined: Sun Jul 05, 2015 12:00 am Location: York
Which ones James?
In the home setup (which is the most used at the moment) I have a 15" Dell Precision laptop with a Full HD display (1920x1080) and then a 27" display on a shelf behind it so that it is almost directly above the laptop screen. The 27" display is actually one of these
https://www.laptopsdirect.co.uk/electri ... ersion.asp
though my laptop can only drive it at 2k resolution.
In the studio I'm using an old 17" 1280x1024 monitor with a 21" full HD monitor next to it.
Posts: 15892 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
This will sound crazy I know, but I'm sure that years ago I read something about an experiment to use the screen itself as a sound source. If it were possible it certainly would solve a lot of problems!
Posts: 19918 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
I have a large screen (32" I think) between and slightly behind my monitors, they are all in an alcove so the speakers are more or less flush with the wall and angled inwards and the screen is a few inches further back. Behind them is a bass trap about 220mm deep filling the whole of the 1300 x 900 mm alcove. The issue I have as a relatively old git (67) with normal(ish) failing eyesight is that my varifocals don't have a sweet spot for a 1.5 metre viewing distance. But, if I use appropriate single focus spectacles I can't read the legends/LCDs on my X32 Compact which is below the screen on the desk.
Posts: 21959 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by CS70 »
I actually have a good 32" or 36" panel myself, a Sony TV which was pretty good in its time and it's just lying around in storage... and I'd given a thought of re-purposing it - attaching it to the wall.
Unfortunately the geometry of the space doesn't allow it - my space is in an extension of the living room and I'm practically using every inch of it already.. but it's a good idea! Just need studio glasses! :D
Why has nobody invented comfortable omnifocular binoculars with eye sensors that track eye movement?
Sounds simple to me . . . . . . . . . . .
TBH I might buy some cheap prescription bifocals with reading and middle distance/screen viewing scrips. My current varifocals are overdue for replacement and the new prescription has less difference between my eyes, switching to cheap readers for super close up work or mid distance screen viewing is a real pain at present but I'm not about to pay proper money for glasses that will end up being sat upon or attacked with a soldering iron.....
Post by CS70 »
Sam Spoons wrote:TBH I might buy some cheap prescription bifocals with reading and middle distance/screen viewing scrips. My current varifocals are overdue for replacement and the new prescription has less difference between my eyes, switching to cheap readers for super close up work or mid distance screen viewing is a real pain at present but I'm not about to pay proper money for glasses that will end up being sat upon or attacked with a soldering iron.....
I have so far resisted buying glasses, but I will soon give up I guess. Time to recognize time's passing! Damn. :D
you worked hard to earn them!
Post by CS70 »
ManFromGlass wrote:Why has nobody invented comfortable omnifocular binoculars with eye sensors that track eye movement?
They actually have.. :mrgreen:
I can’t imagine anything sexier than these for attracting a life partner! :smirk:
On a slightly more serious note, I was throwing out old manuals from gear long gone last night and I come upon a manual for an LG monitor. It appears that there was included software for this monitor that allowed one to split the screen into 2 or 3 parts. I never knew this but for some this could be useful. It could deal with the bezel-in-the-middle issue.
Post by muzines »
ManFromGlass wrote:It could deal with the bezel-in-the-middle issue.
The easiest approach for this is simply to surround the middle bezel in a Someone Else's Problem field.
Then it will just magically disappear from view. :thumbup:
muzines
Post by CS70 »
OMG I discovered there are a 49" super ultra wide monitors.. the Samsung G9 for example.. and at 120cm it fits..
I had to think about that for a second. That’s big, That means You won’t need glasses!
What are you waiting for? :bouncy:
Post by CS70 »
ManFromGlass wrote:I had to think about that for a second. That’s big, That means You won’t need glasses!
It's actually just as big as two 27" side by side as I have now... and 1440 resolution - I can pretend I still do not need glasses.
Nothing not to like!
Apart from those numbers after the $ sign.
All those numbers... ;)
Folderol wrote:This will sound crazy I know, but I'm sure that years ago I read something about an experiment to use the screen itself as a sound source. If it were possible it certainly would solve a lot of problems!
Just noticed this comment, were you thinking of the NXT flat panel speakers Folderol?
Post by RichardT »
CS70 wrote:OMG I discovered there are a 49" super ultra wide monitors.. the Samsung G9 for example.. and at 120cm it fits..
It’s a monster!
RichardT
Posts: 4992 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Ah! So I'm not losing my marbles... yet :lol:
