Shame ! Korg wavestate problem with W10 usb midi connection
! My new Korg Wavestate will not connect to my W10 pc via USB midi. This apparantly is a known problem, introduced with a W10 update from more then a year ago.
Problem occurrs when more then 10 different usb/midi devices has been connected to the pc, ie the mid ports 0 to 9 are occupied, and the mid10 (or higher) is allocated to the wavestate.
Apparantly the korg driver does not recognize a 2 digit midi port number.
Korg forum: solution suggested is to (after install of latest sw/drivers etc) to use the korg usbmidi delete utility and delete a mid port. Done this, but after connecting the usb cable to my wavestate port mid11 is allocated, ie no connection. Even after deleting “all” mid ports, it Is not working.
A possible solution to this (desribed by a handy korg user on web), is to manually make changes to the register. This Allthough the procedure is documented very well, there even is a video, this to me is not a acceptable solution, just to risky.
Needless to say that the above mentioned procedure can not be supported by Korg whatsoever.
...... so what is Korg doing ??
Re: Shame ! Korg wavestate problem with W10 usb midi connection
I've never run into this as most of my synths are connected via 5 pin midi cables to a midi interface. I've seen and heard the horror stories though. Did you restart/boot after deleting all the usb midi ports? Worth a shot. You could always try using good old midi cables if you have an interface.
- RobustAmerican
Poster -
Posts: 34 Joined: Tue Mar 19, 2019 2:45 am
Robust American Patches
Very annoying that the fix you have been given doesn't work.
It's about time Korg updated their driver to cope with this. The Windows 10 update was to address a long standing limitation in Windows with the number of known MIDI devices and Korg are lacking if they still haven't updated their own driver accordingly. I know this doesn't help you now, but I felt like a little rant
- Rich Hanson
Frequent Poster - Posts: 3511 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Countless reboots .... not tested, but the good old 5 pin din midi cable will work. I have a motu Midi interface, usb to multiple ins and outs.
But I find single usb cable so much more convenient, and anno 2020 !
While I agree that Korg really should update their driver, you have to admit that you're something of an 'outlier customer' with more than 10 USB midi devices... (I have five and could push six at a stretch!
Posts: 42194 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote:While I agree that Korg really should update their driver, you have to admit that you're something of an 'outlier customer' with more than 10 USB midi devices... (I have five and could push six at a stretch!)
Seriously though... not that I was looking to, but it rules out buying one for me as that would be a dealbreaker in my environment. At a quick count I've got 19 USB MIDI devices here of which 16 or so are actually connected.
Posts: 9596 Joined: Wed Sep 01, 2004 12:00 am
I am somewhat surprised by comment from Hugh about no of mid devices.
Note that mid ports allocated by devices will not be freed up after disconnect (or even sell) of device. I was not aware of this, until after my problems with the wavestate.
There are many “non synth” usb/midi devices: WinPC (wdm mid, soundcard driver mid, Vmid), Motu usb/mid, midas m32, presonus faderport, roland guitar synth .. then my collection of synths..
Note that after “clean up” of the midport table (deleting mid ports), the Wavestate still allocates mid10, ie driver does not work.
Apparantly some other Korg devices experience this same problem. My Korg Kronos works fine, also after the cleanup.
Hmmm, a quick look round tells me I'm using 8 midi ports and don't have any hardware synths (but 3 controllers).
Posts: 28072 Joined: Sun Jul 05, 2015 12:00 am
I thought you said above there was a registry edit solution?
That sounds trivial enough to test to see if it works, and revert if it doesn't...
desmond wrote:I thought you said above there was a registry edit solution?
It does, but in that regard I am less tolerant than you are. If one has a roomful of sources then anything requiring a little 'special exception' workaround sets a precedent that can lead to pain later.
For some things it may be grudgingly acceptable but for something as daft as a contemporary device not recognising double figure port numbers I'd veto it on principle because that's shoddy engineering at best. They really should fix that.
Fortunately in my case not applicable but if I had bought one and it was exhibiting this issue I would undoubtedly return it for a refund.
Edit: I appreciate that I might be slightly more militant when it comes to some things than others, but I've been bitten in the past and as a result I've found myself with less tolerance for such things than some people might be!
Perhaps this utility might be of some help?
https://www.nirsoft.net/utils/usb_devices_view.html
I have currently 24 USB devices in my system.. but none used for MIDI
CS70 wrote:Perhaps this utility might be of some help?
Yes, I've recommended that utility in the past when I was still writing my PC Notes column, and still occasionally launch it.
It's amazing the number of USB devices that you build up over the years.
However, I still do my level best to use 5-pin DIN MIDI wherever possible, as this just works whereas USB MIDI can still have a few 'quirks'.
Posts: 21662 Joined: Wed Jan 13, 2010 8:44 am
I have to use a pair of 12-port USB hubs! I've hit the USB resourcedevice limit on one hub, so had to do some re-jigging, but I've not hit the MIDI device limit with any piece of gear - those days are long past, and Korg sofware designers really shouldn't be aware of this.
I do run a utility called 'Ghostbuster' from time to time to remove 'ghosted' devices.
Tried to find contact within Korg, ie email address or else. I was directed to Korg representative in the Netherlands/Benelux, a dutch company called Voerman. I have sent email describing my problem and asked for advise. I doubt whether Voerman is the right contact for this kind of sw problems
Can anybody help/advise me on a better/direct contact within Korg ?
Useful!
- resistorman
Frequent Poster - Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
