Polysix Rebuild
Re: Polysix Rebuild
Post by nickle15 »
BJG145 wrote:
nickle15 wrote:one is $100
...what's that...?
Sorry - I was just going off some notes my dad had written on a diagram. But it looks like the SSM2044.
nickle15
Posts: 382 Joined: Mon Dec 16, 2019 4:29 pm
Re: Polysix Rebuild
Interesting chip. It wouldn't be easy to emulate that!
Posts: 18288 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Polysix Rebuild
Post by BJG145 »
nickle15 wrote:it looks like the SSM2044
I wondered if it might be. It's possible I might have one; I'll check.
Posts: 7215 Joined: Sat Aug 06, 2005 12:00 am
Re: Polysix Rebuild
Post by nickle15 »
Very cool - thanks!
nickle15
Re: Polysix Rebuild
Post by Dan LB »
nickle15 wrote: ........it looks like the SSM2044.
There’s somebody local to me selling two of these chips. He wants €45 each for them. If you get stuck and can’t find them in the US I’d be happy to pick one up for you and post it.
Dan LB
Posts: 1668 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
Re: Polysix Rebuild
Post by nickle15 »
Awesome offer and I'll let you know - thanks so much!!
nickle15
Re: Polysix Rebuild
Post by nickle15 »
At long last we were able to lay out all the parts. Here's what we know we're missing:
1 voice chip
Microcontroller
1 7 pin wiring harness
Pitch/mod wheel assembly
Wooden chassis case
All the knobs
One button
Dad started his work on the transformer and planned to work from board to board just trying to get a sense of what might need to be fixed. He didn't get very far - the transformer is bad. So that's where we stand as of this morning. I'm going to get started on pricing the replacement parts we need, starting with the transformer.
nickle15
Re: Polysix Rebuild
Best of luck with this.
I suggest you check on availability of the processor and the voice chip before spending too much.
Re: Polysix Rebuild
Post by nickle15 »
Folderol wrote:Best of luck with this.
Thanks!
Yes I plan to compile a list to see how much it will cost to get the known issues fixed. It's very possible that the cost of the parts would outweigh just buying a functional keyboard.
nickle15
Re: Polysix Rebuild
Post by jjlonbass »
Which microcontroller is missing? There are 2 - one, a 8049, is the "key assigner" and the other, a 8048, is the "programmer".
Both are mask programmed i.e. the software is hard-wired into the chip - there is no separate PROM. This means that you need the exact correct 8049 or 8048 part containing the correct software. Any old 8049 or 8048 won't work.
I suspect that these will be very difficult to find.
jjlonbass
Posts: 109 Joined: Wed Dec 19, 2018 3:52 pm Location: Ware, Hertfordshire UK
Re: Polysix Rebuild
Post by nickle15 »
jjlonbass wrote:Which microcontroller is missing? There are 2 - one, a 8049, is the "key assigner" and the other, a 8048, is the "programmer".
It's the 8049 that's missing. I was suspicious of how easy it was to find one - but now I know why. Again - your advice/direction is very helpful!
nickle15
Re: Polysix Rebuild
Post by rockydennis »
nickle15 wrote: It's the 8049 that's missing. I was suspicious of how easy it was to find one - but now I know why. Again - your advice/direction is very helpful!
Taking a quick look online, I do see one site selling the 8049 for the Polysix for 30 Euros.
Here's a site with firmware code for various synths available for free, including the Polysix. I'm guessing the 8748 and 8749 which have eprom and are programmable, and are from the same family can be substituted for the 8048 and 8049 but don't quote me on that.
https://dbwbp.com/index.php/9-misc/37-synth-eprom-dumps
Here's someone replacing the 8049 for the Polysix with Arduino with the code made available.
http://synthhacker.blogspot.com/2013/03/polysix-replacing-8049-key-assigner.html
rockydennis
Posts: 142 Joined: Sat Nov 03, 2018 5:36 am
Re: Polysix Rebuild
Post by nickle15 »
Excellent - thanks for adding this guidance!
nickle15
Re: Polysix Rebuild
The level of expert knowledge that is freely given on this site never ceases to amaze me. :clap::clap::clap:
Posts: 24714 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Polysix Rebuild
Post by nickle15 »
blinddrew wrote:The level of expert knowledge that is freely given on this site never ceases to amaze me. :clap::clap::clap:
Amen! :thumbup:
nickle15
Re: Polysix Rebuild
Maybe replacing the 8049 with Arduino is the way to go -
"As many of you know, I made some pretty substantial modifications to my Korg Polysix. One of the biggest changes was to replace the keybed to enable aftertouch. To make this happen, I had to replace the Polysix's Key Assigner with an Arduino. It was a lot of work, but once I made the core hardware modifications, I found that I was able to add lots of features to the Polysix, such as: aftertouch and portamento, more interesting detuning for unison mode, a poly-unison mode, a Moog-like single-trigger mode, and a sustain pedal. All of these modifications were effected through software changes on the Arduino."
http://synthhacker.blogspot.com/2014/03/polysix-sharing-my-arduino-code.html
rockydennis
Re: Polysix Rebuild
Post by BJG145 »
That's hardcore. Respect.
Re: Polysix Rebuild
I'd like to know how the guy got hold of a Fatar poly aftertouch keybed.
Oh, and did he have to remortgage the house.
Re: Polysix Rebuild
Folderol wrote:I'd like to know how the guy got hold of a Fatar poly aftertouch keybed.
I've often been told that they don't do one!
Posts: 20119 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Re: Polysix Rebuild
They certainly don't have one listed in their current line up.
They make plenty of keybeds with monophonic (channel) aftertouch, though -- and that's what the Arduino guy used to provide channel aftertouch in his Polysix, basically replicating the mod wheel functions from the keyboard pressure.
Posts: 39114 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
