Good small monitor controller.
Re: Good small monitor controller.
The TC is just fine - simple big knob with a nice action and you won’t notice any problems.
- Bob Bickerton
Longtime Poster -
Posts: 5427 Joined: Fri Dec 20, 2002 12:00 am
What Bob said. ^^^
It's the ideal tool for the job you want to do.
Posts: 28086 Joined: Sun Jul 05, 2015 12:00 am
Arpangel wrote:After all this talk I’m regretting ordering my TC, sounds like passive is verboten from what you all say!
You're really not good with decisions are you? Or technical descriptions, come to that...
A passive controller is absolutely fine when used appropriately. And inherently compromised when not used appropriately.
Your application is an appropriate use for a passive controller, and hopefully you can be trusted to install it correctly as previously advised.
The alternative is a well-designed active controller and that's going to cost you £200+ as a minimum....
Posts: 42207 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote:Arpangel wrote:After all this talk I’m regretting ordering my TC, sounds like passive is verboten from what you all say!
Thanks, I’m using short leads, as I said, so it should be OK.
I know it’s not a good idea, but there are Youtube reviews that have said it sounds very good, more transparent than the Mackie for instance, but who knows, I’m sure it’ll be fine.
Arpangel wrote:Thanks, I’m using short leads, as I said, so it should be OK.
Yes, it should.
...there are Youtube reviews that have said it sounds very good, more transparent than the Mackie for instance...
I was very disappointed with the sound quality of the original Big Knob (I haven't listened to the later models). I found it a little noisy and veiled... but PW thought it was fine and used one for years very happily...
The original Big Knob is active, isn't the one discussed up-thread the BK Passive?
Forum Aficionado - Posts: 21954 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
It's my age...
Sam Spoons wrote:The original Big Knob is active, isn't the one discussed up-thread the BK Passive?
I've lost track... but it's hard to imagine a comparison with a passive BK involving comments about a lack of transparency. But I could see how that comment might be levelled at an active BK, and especially the early ones.
Both BK's were mentioned early in the thread with the discussion moving towards passive controllers later.
WRT my possible DIY job*, I'm trying to get a schematic drawn out and was wondering what app you used to draw your diagram? All the ones I can find for Mac seem to either be general drawing apps or for PCB design (or hugely expensive and/or complicated).
* Costed out at around £65 but if I can make it work I have some DT4P toggles switches, a large knob and a bucketload of XLR and phono sockets so just need a box, stepped attenuator and a bag of suitable resistors which ebay will provide for the princely sum of £36.56. That said a Big Knob passive would pretty much get the job done for £65 and save me the hassle
Sam Spoons wrote:...was wondering what app you used to draw your diagram?
Coreldraw. Straightforward vector drawing program.
So often the case! Unless you want something particularly unusual a commercial product will often work out less expensive than a custom DIY job.
Still pondering, the features on the BKP are almost spot on :-
Stereo balanced input - (X32 control room outputs)
Stereo unbalanced input - (Logitech BT receiver)
Stereo balanced output - (Quad 522/Kef 104bAs)
Mono balanced output - (Avantone Mixcube)
Volume control
Input switching
Output switching
Mute
BKP features not required on custom box :-
Mono (output 2 is mono)
Dim
Volume control
Input switching
Output switching
Mute
Dim
You could see how much John at Orchid would charge you?
Takes the fun out of it of course...
True, and at least I'd be sure he'd design it properly... But the fun aspect would definitely be a loss...
Sam Spoons wrote:Still pondering, the features on the BKP are almost spot on :-
The details aren't entirely clear from the manual, and the block diagram indulges in a fair bit of 'artistic licence', but it appears that the BKP is actually unbalanced throughout. It appears to ignore the cold leg of the inputs completely, and the outputs appear to adopt an impedance-balanced approach, although its hard to see how that would work reliably given the inherently variable source impedance of the volume control.
That's not to say that being unbalanced won't work -- it obviously will and does -- but it could lead to oddities...
Dim
I wouldn't be so quick to dismiss the Dim function. When using a conventional pot (rather than a stepped attenuator), channel tracking is inherently poor at low listening levels. Using a Dim switch extends the useful working range of the control downwards by 20dB which is very useful for late night working, checking mixes at low level, and for answering the phone or having a conversation without having to tweak the volume knob.
Hugh Robjohns wrote:I wouldn't be so quick to dismiss the Dim function. When using a conventional pot (rather than a stepped attenuator), channel tracking is inherently poor at low listening levels. Using a Dim switch extends the useful working range of the control downwards by 20dB which is very useful for late night working, checking mixes at low level, and for answering the phone or having a conversation without having to tweak the volume knob.
Dim is, I believe, easy enough to implement so I will draw it in the schematic even if I don't build it into the first version.
Sam, the BKP is indeed flawed, the input resistance of the ring input is low at 1k and can therefore cause distortion with some sources. As you say, the output is not even close to balanced but AFAICT there is a 'cold' signal.
Other than those flaws, the box works very well and if it seems to satisfy your requirements I would suggest you get one and simple make NE5532 buffers for the inputs and a pair of symmetrical outputs ? The LM4562 will be even better, lower noise and greater drive capability though I doubt you would hear any difference.
Lot less trouble than a 'New Wheel'?
Arpangel wrote:Review, Pilot now set-up, it’s completely transparent, it works, review over.
Think of how many ads we could get in the mag if all my reviews were that short...
Hugh Robjohns wrote:Arpangel wrote:Review, Pilot now set-up, it’s completely transparent, it works, review over.
I’m always here Hugh, I'm looking forward to doing a one line review of the Behringer/Neve 8068 reissue.
NO!!!! Many are too short as it is. I cannot think of it now but there was a review of something quite high end and complex last year that was dismissed in less than a page.
Might I have the temerity to suggest "quantity" often triumphs over "quality"? Or, if not "quality" certainly 'depth'? And, compared to many 'skinnies' I buy occasionally, SoS magazine is STUPIDLY cheap! Another quid is surely justified especially if it means reviewers can take just a bit more 'time'?
ef37a wrote:Hugh Robjohns wrote:Arpangel wrote:Review, Pilot now set-up, it’s completely transparent, it works, review over.
Might I have the temerity to suggest "quantity" often triumphs over "quality"? Or, if not "quality" certainly 'depth'? And, compared to many 'skinnies' I buy occasionally, SOS magazine is STUPIDLY cheap! Another quid is surely justified especially if it means reviewers can take just a bit more 'time'?
Sometimes there’s not a lot you can say, beyond it meeting certain personal requirements, and it sounding sort of "OK" and most gear these days "is" sort of OK there aren’t any real turds, do you remember those "stereo" radios in the 70’ that were just one speaker with two cardboard tubes going to a couple of fake grills? we need more stuff like that to liven things up!
Surely Sam would just send you more stuff to review?
