What drum sound is this?
Post by soundproofed bob »
Hello guys all,
Uploaded short clip there please take a look: https://ufile.io/g6p4g56i
What high frequency drum is playing right at the right ear?
Commonly used in trailers and soundtracks.
soundproofed bob
Posts: 42 Joined: Tue Apr 10, 2018 7:02 pm
Re: What drum sound is this?
Post by BJG145 »
Do you mean the high-pitched one...? Some kind of small or medium hand drum played near the rim I would guess; djembe/darbuka/doumbek.
https://youtu.be/d8X0nQqzJZ0?t=180
Posts: 7215 Joined: Sat Aug 06, 2005 12:00 am
There's a problem though that djembe, dumbek in my libraries don't sound that impressive. They sound thin, lonely. Unless author stacked 10 of them?
soundproofed bob
Post by BJG145 »
There's a lot of other stuff going on though; orchestral stabs, deep drums and other percussion. If you just heard the djembe (?) solo it wouldn't sound too earth-shattering. (Don't get me wrong, I like djembes.)
I suppose it's a sound from old commercial sample library!
soundproofed bob
I made 3 mouse clicks and still didnt access your audio.
I gave up
Posts: 3718 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Post by uselessoldman »
sound to me like tribal hand drums with a distinctive swang. Without trying to sound to daft, using a metal brisket tin or plastic tub would give a similar effect depending on how high/low you want them to sound.
Without looking I would guess an Indian or African percussion library would have something similar? That is where I would look, after trying what I said above.
uselessoldman
Posts: 246 Joined: Sun May 03, 2020 7:39 pm
N i g e l wrote: I gave up
This happens!
uselessoldman wrote:sound to me like tribal hand drums with a distinctive swang. Without trying to sound to daft, using a metal brisket tin or plastic tub would give a similar effect depending on how high/low you want them to sound.
I had 1 guess that it's played with a heavy stick, or at least some stick. But I'll consider hand playing as well.
I'll keep looking. Probably an library with ensemble and single drums layered in a mix. Thanks
soundproofed bob
