Akai DPS24 ADAT expansion card woes: no audio
Re: Akai DPS24 ADAT expansion card woes: no audio
Post by FrankF »
All 3 OUT leds, internal, 9-16, 17-24 are solid red, from powerup onwards - that's with no ADAT cables connected.
I guess you've reseated the ADAT card a few times when cleaning the thing?
If you think the card's faulty, you could contact vstservices: I bought several DPS24 cards from them. They advertise on Ebay UK, but not everything they have in stock.
FrankF
Posts: 498 Joined: Fri Sep 13, 2002 12:00 am Location: La Vendée, France
Post by Anthony gilbert »
FrankF wrote:All 3 OUT leds, internal, 9-16, 17-24 are solid red, from powerup onwards - that's with no ADAT cables connected.
Brilliant. That is most certainly different to mine, and makes perfect sense. My internal port stays on - why shouldn't the external?
I will contact VST services as suggested.
Thanks again.
Anthony gilbert
Posts: 16 Joined: Wed Dec 23, 2020 10:17 am
Post by forumuser840717 »
Anthony gilbert wrote:Sync results
ADAT Inputs
The onboard ADAT input will sync successfully to an external clock.
The ADAT expansion input will also sync to an external clock.
Does this work for both ports on the ADAT expansion board?
Also, when you get sync, do you also get 8 channels of audio on the appropriate port?
ADAT outputs
My RME (using the onscreen Fireface application) detects the internal clock of the DPS24 coming from the onboard ADAT output.
Good - that's what should happen
The RME doesn't detect the internal clock of the DPS24 coming from the expansion ADAT output.
Not so good. Though your explanation of the lack of any lights in the ADAT outputs would certainly explain it. (Incidentally, you shouldn't actually need to clock the RME from the DPS24 (though it's a perfectly valid way to work); everything should work ok with the RME acting as the master clock source (clocking internally) and the DPS24 set to use any working ADAT source from the RME as it's clock source.)
***breaking*** something I have overlooked. The red-LEDs of the expansion DATA output (TOSLINK) ports flash on for the first few seconds of boot up. Afterwhich they go off and stay off. If there isn't any optical port LEDs, there surely cannot be any valid output?
This doesn't explain the lack of function when it comes to INPUTs, but certainly points to a fault with the OUTPUT ports
Correct. One of the nice things about ADAT optical as a format is that it uses visible light so no light in the output socket is a good pointer to no signal.
I don't have one here to check but I'm pretty sure that the ADAT outputs on the expansion board should light up continuously in the same way as the DPS24's internal ADAT output does. The lights going on at boot up does suggest that if there's a fault it's not with the LEDs but them not staying on suggests that something is wrong elsewhere.
Bit of a random one - have you tried removing the card, checking carefully for any bent or broken pins in the edge connector and then re-seating it? (And doing the same to the ribbon cable joining the expansion card back plane sub board to the main board.)
forumuser840717
Posts: 481 Joined: Thu Jun 16, 2016 5:20 pm
Post by Kwackman »
Red Herring time....
ADAT can be 8 channels of audio, or a single stereo feed.
From memory RME can switch between these modes in software.
Probably not relevant, but, just in case!
Kwackman
Posts: 3478 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Kwackman wrote:Red Herring time....
Just to be picky... ;)
The toslink optical connection can carry ADAT or SPDIF. ADAT can be up to 8 channels depending on sample rate. SPDIF is always stereo.
The socket is the same but the configuration isn't and needs to be set accordingly.
[/pedantry]
Posts: 28013 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Kwackman »
blinddrew wrote:Just to be picky... ;)
[/pedantry]
Drew, have you not got anything better to do, like spotting frequencies in choirs no other humans can hear? :madas::protest:;)
PS. You are correct of course, that was very sloppy terminology on my part.
I'll be in the corner huffing for the rest of the afternoon...... :cry:
Kwackman
I'm sorry about the choir thing too. :(
But it's definitely there.
Yep, and all the RME's optical ports can function as either ADAT Lightpipe or SPDIF ports, as can the TOSLINK connection on the DPS24 itself. Hence asking whether there was a known working link passing clock and ADAT audio to use as a test source. I wondered whether the RME or DPS24 might be set to SPDIF on all or some of the ports.
If everything were set to SPDIF then obviously they'd sync up but wouldn't pass 8 channels of audio (and they'd show up in the DPS24 patch pages as a two channel link rather than 8 channel). Also, if the RME were set entirely to SPDIF, it wouldn't sync into the ADAT ports on the expansion board (as they don't do SPDIF) but could sync and send two channels into the DPS24's optical port if that were set to SPDIF. Gotta love digital formats!
The lack of output LEDs on the DPS24 expansion board isn't a good sign though.
forumuser840717
forumuser840717 wrote: I wondered whether the RME or DPS24 might be set to SPDIF on all or some of the ports.
Thanks again for the suggestions. It's set to ADAT. One of the nice things about the RME software is it displays the source type and sample-rate of the incoming signal it syncs to. I've had previous RME Digiface products and they remain pretty good.
forumuser840717 wrote:The lack of output LEDs on the DPS24 expansion board isn't a good sign though.
Agreed. I've had the DPS24 open over my lunch break. I've checked the pins of the DPS24 option interface PCB. I've also checked the micro-ribbon cables to the interface PCB. The other end of these go underneath the main PCB and aren't visible. A strip-down looks to be a "fair job", and one which may break more items than it may fix.
Next step is to try another IB-24ADT expansion card, or find someone to test mine. I've made an enquiry with VST Services.
Anthony gilbert
Anthony gilbert wrote:Thanks again for the suggestions. It's set to ADAT. One of the nice things about the RME software is it displays the source type and sample-rate of the incoming signal it syncs to. I've had previous RME Digiface products and they remain pretty good.
I'm a big RME fan. Since getting my first RME card - a Digi96/8 PST in about 2002 (still got it and it's still working fine in an old WinXP machine), I went on to get another one the same (sold a few years ago), then in 2005, an HDSP-MADI and, later, HDSPe-MADI and HDSPe-MADI-FX Triple MADI cards (all now gone in favour of external interfaces to make it easier to move them between computers). I currently have 19 assorted RME boxes - mostly MADI related - and couldn't be happier with them. If only all manufacturers were as reliable and straightforward.
Definitely try another expansion board if you can get one, before taking everything apart. It's not terribly difficult to strip it down but it is generally fiddly, involving more screws than a screwy thing and, as the DPS is getting on in age now, there's lots of potential to accidentally make things worse so it's best avoided until you eliminate other possibilities.
If you don't get any joy with VST Services, it might be worth trying a post in the SOS Reader Ads Wanted section.
Failing that, I don't know whether you've tried it but there used to be a really good user board for the DPS products. I don't know how functional it still is but there's what looks like an archive of it here. If it's still running, there might be some sources of parts there or current users who might be able to help.
Please do let us know how this develops and any outcome as it'd be good to know what's wrong for future reference. All this chat about the DPS24 has reminded me what a great bit of kit it is and how much I miss mine. It took me ages to sell them as, even when I'd stopped using them, every time I started the sale process I was reminded how much I liked them and kept changing my mind :tongue:
One other thing - do you have the ak.Sys TrackView DPS24 PC software for the DPS24? It probably needs a fairly ancient PC to run it - mine was on WinXP - but it does have some useful facilites that make things like metering and editing clearer. There might be a version floating around online but if not and you think it'd be useful I probably still have it lurking on an old hard drive somewhere.
forumuser840717
I certainly will do.
I thought I was an RME fan! It's not cheap but a classic case of getting what you pay for - especially the longevity of driver support. That's a rare thing these days.
This was my first post on the SOS forum and the response, knowledge and helpfulness has been quite overwhelming.
I've been an SOS reader since the days of Electronics & Music Maker. Never thought to ask the forum before today, and I'm now wondering why.
The DPS24 continues to impress (other than the obvious exception). I get 20 live mixer channels currently (12 analogue and 8 ADAT), using the old trick of armed track channels. I can output to the RME using an 8-buss output, or multi-passes of track-per-channel. Above all, I find it still delivers musical results whilst being intuitive and tactile.
I'll certainly keep on hunting for a solution to keep the old thing alive.
Thanks again everyone for your time and assistance.
Anthony gilbert
Quick update and a question...
I've been scouring all the usual places for a replacement ADAT expansion card to try. No luck to date.
This creates the question: what if it's not my existing expansion card? I've done continuity and power checks on the expansion card and it's all good. It is also detected by the DPS24.
Is anyone willing to test my existing ADAT expansion on their DPS24? I will gladly post it for "field trials", and supply it with some beer/wine funds...
Anthony gilbert
Post by OneWorld »
Do you have another audio interface you can try. I too use RME and I too get a no audio issue using one of the ADAT ports. I have some external effects which I want to use as insert effects, which use ADAT (in SPDIF - stereo) mode, I have set up the RME for ADAT to work as stereo, I had the red lights showing on the ADAT output, etc but try as I may I simply cannot get get the audio into the RME, in this insert effects scenario, but the ADAT works in other setups. It has to do with the patching or clocking I am sure.
I have given up and used the analogue i/o instead.
OK I guess this is a 'longshot' and quite often these 'have you tried' suggestions often lead you down a garden path and you end up given a dis-proportionate amount of time to something that will come to nothing but I suppose in the absence of anything else then owts better than nowt and it might be worth a try.
Best of luck. The DPS24 is a lovely machine and I suppose came along at the wrong time, when HDD recorders finally gave way to DAWs
OneWorld
Posts: 5286 Joined: Tue Apr 07, 2009 12:00 am
OneWorld wrote: Wed Oct 13, 2021 1:47 pm I have some external effects which I want to use as insert effects, which use ADAT (in SPDIF - stereo) mode, I have set up the RME for ADAT to work as stereo, I had the red lights showing on the ADAT output, etc but try as I may I simply cannot get get the audio into the RME, in this insert effects scenario, but the ADAT works in other setups. It has to do with the patching or clocking I am sure.
It may just be sloppy terminology but I just wanted to check... You can only run ADAT format signals in stereo if you are using a 192kHz sample rate. So do you have all the RME inputs and outputs set to SPDIF or ADAT? It should be SPDIF. Are you using the RME as the audio clock master and is everything else set to external audio clock?
Posts: 15849 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
There is a lot of confusion over the optical interface, and routine misnaming is a common cause.
The socket is identified in technical circles variously as the EIAJ RC-5720, the CP-1201, or the JIS C5974 F05 -- but probably the most common shorthand is the JIS F-05.
In consumer hi-fi circles it is more usually known as the TOS-Link socket, after the 'Toshiba Link'.
But just like the humble XLR-3, the socket itself doesn't define its function. The JIS F-05 is regularly used as the interface connection for either S/PDIF two-channel digital data or ADAT multi-channel data -- and many platforms allow the electronics to be configured manually to support either format.
In both cases, the S/PDIF or ADAT data carries embedded clocking data, so can be used as the clock source for the receiving device if suitably selected for that function.
Common reasons for non-working optical ports are:
* Wrong data mode selected.
* Wrong clocking source selected
* Multiple unsynchronised sources feeding the device simultaneously
* Excessively long or poor quality optical fibre
* Kinked or damaged fibre
* Dust or dirt in optical sockets
* Optical fibres connected to the wrong sockets (in/out reversed)
Posts: 42142 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Thanks for all the response on ADAT and optical.
For my DPS24 ADAT expansion card, the problem is quite fundamental as described earlier in the thread. To recap, the ADAT expansion optical-out ports x2 LEDs flash on boot, but then go out. The in-built ADAT optical-out port LED x1 happily glows red - and does so irrespective of clocks, config etc.
The control of the optical LED may well be done by the DS24, but perhaps acting on a control signal/state of the ADAT expansion. This is why I'm wondering is it the DPS24 or the expansion card?
Anthony gilbert
Anthony gilbert wrote: Wed Oct 13, 2021 4:09 pm To recap, the ADAT expansion optical-out ports x2 LEDs flash on boot, but then go out. The in-built ADAT optical-out port LED x1 happily glows red - and does so irrespective of clocks, config etc.
I wouldn't assume that to be a fault. I have several bits of kit that turn off the optical outputs when not assigned (so the red light goes out). The Akai may be the same.
As you mentioned earlier, you really need a current DS24 user to compare and confirm... Sorry I can't help, but I hope you get to the bottom of it.
Hugh, that's worth knowing and very helpful. Thanks.
Anthony gilbert
Post by OneWorld »
James Perrett wrote: Wed Oct 13, 2021 2:07 pm
That might be the issue then, as the external equipment does not have the 192kHz sample rate. It is not such a big issue as I am using the analogue instead
OneWorld
Post by Coz14 »
Hi Anthony - I think I might be able to help you out with your ADAT expansion card. I am in a similar situation as you which is how I found this post. I have a DSP24 which I bought in 2004 and still own. I have just upgraded my PC based DAW (Reaper) and wanted to use the DPS24 as a front end (Pre-amp and ADC) to send up to 16 tracks of ADAT to my RME HDSP 9652 soundcard.
Currently I am able to send 8 tracks via the DPS24's internal ADAT port.
Back in ~2012 I found/bought the ADAT extension board. The board worked for a little while but it was a bit flakey. Whenever I sent audio out on ADAT 9/10 the gain would increases in steps until the audio was distorting. Eventually out of frustration I hot swapped the board (removing and reinserting it while the DPS was still powered on), it stopped passing audio from that point. I fear/suspect that I may have damaged the Xilinx Spartan FPGA at the heart the board.
Recently, I have had renewed interest in seeing if I can get this card working again (or at least understanding/verifying what is wrong with it). This is what led me here. I saw your request for help, and I am willing to test your expansion card. If your are still interested in help, please reach out.
Steve
Coz14
Posts: 3 Joined: Fri Dec 24, 2021 1:03 pm
Hi Steve,
Thanks for sharing your experiences. Very interesting read. Funny you mentioned the Xilinx Spartan IC, which I replaced. Of course it needs programming, so no board detection at all when I did this.
I'm not able to send the expansion card over until the new year, but I would love to see if you have any luck on your DPS24.
Send me a PM if you can for details.
Cheers,
Anthony
Anthony gilbert
Post by Coz14 »
Hi Anthony - I am unable to send you a PM. I have not been given PM privileges yet, due to my lack of posts on this forum.
I just went back and re-read this thread and I have some questions. 1) Did your expansion card ever work properly? 2) When did you replace the FPGA, was this before or after you noticed the LEDs in the ADAT TX ports flashing/extinguishing? 3) Do you still have the original FPGA? As you have stated these IC's need to be programmed with the appropriate firmware. At this stage further troubleshooting is pointless without the original FPGA on the board.
Steve
Coz14
Coz14 wrote: Sun Dec 26, 2021 3:27 pm Hi Anthony - I am unable to send you a PM. I have not been given PM privileges yet, due to my lack of posts on this forum.
Steve
One more approved post and your future posts will be auto-approved along with your PM privileges being activated.
Posts: 21880 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Coz14 »
Anthony - I did want to pass on some more information. I don't know if you have any of the schematics for the DPS and/or expansion boards. Many years ago one of the guys on the DPS World forum posted the DPS24 schematics, board layouts, service manuals and software files. I checked and it appears that all this content is still available and can be found here:
http://steve.sideroadsband.com/DPS24/
To see the entire ADAT path within the DSP24 you will need the following four schematics:
"IB_24ADT_PC_ADAT" - this is the adat expansion board schematic.
"PC Mother" - this shows the connectors and wiring of the DSP expansion bay where the ADAT, SMPTE & SCSI card connect.
"PC CPU 2" - This shows the Internal Master FPGA (IC2) and where the Master/Slave FPGA communications originate. It also shows how the Internal FPGA is connected to the Internal ADAT TX/RX Ports.
"PC CPU 1" - This shows how the Master/Slave FPGA communications are sent from the CPU Board to the PC Mother via J201-J203 then ultimately onto the expansion card.
Using the schematics we can now work off of some of your observations. For instance the Adat LEDs that are flashing then turning off (As stated in a previous post, this is not normal. The TX LEDs on my expansion board always stay solidly lit, mimicking the TX internal port). We can see that the LEDs within the adat TX ports are simply driven from the 5v that the DPS supplies to the expansion board. If they are flashing and turning off, it would suggest that the DPS is shutting down that 5v line. This can be verified by probing the Sync connector with a multimeter on pins 3,4 or 5 (5v) and pin 1 (ground) at bootup.
Why would the LEDs flash and shut off? There could be many reasons (take my explanation below with a grain of salt. I am not an expert and I am learning this stuff as I go). Again looking at the schematic there are SPI communication signals going between the Master FPGA (Internal) and Slave FPGA (Expansion) these are denoted by MOSI and MISO (Master In Slave Out, Master Out Slave In). If there is a communication problem at boot up this could be throwing an error causing the 5v line to shut down. Also someone else in this thread stated that the expansion card may be good and the problem could be within the DPS, this is also a valid possibility.
The other day I removed my ADAT card and powered it up on the bench using a 5v power supply feeding Pins 1 (5v) & 14 (GND). I was able to verify that the board power was working find (Adat ports were powered, the 3.3v and 2.5v voltage regulators were working, the 50MHz clock was working). My next step is to figure out a way to instrument the board to see if IC communication is present and if digital audio is getting passed to the board.
I hope this helps.
Coz14
