Too many pedals.
For all tech discussions relating to Guitars, Basses, Amps, Pedals & Accessories.
Re: Too many pedals.
Post by Murray B »
Wonks wrote:Basically you've currently got far fewer pedals than you will have in the future. Accept it as your destiny and move on.
Love it...
My name is Murray and it's been 6 months since I last bought an effects pedal...
I had a fairly basic set up that met all the sounds I needed - then I joined another band:
Result - I now need some modulation every now and again and there's no space on my smallish board to fit a mini pedal...
Solution 1 = more (smaller) pedals!
but... I don't like the sound of them as much so solution 2 = bigger pedal board, perhaps even a custom board for each band, I already had a pedal set up for the acoustic guitar and the bass so this is an obvious logical choice!
Now I have room for more pedals...and the small pedals are useful for a stripped down small pedal board if I ever get to fly to a gig ever again...
(I'm wondering if this will ever happen :frown: with the combination of Brexit and Covid- maybe the Orkney Folk Festival might have us back one day...best keep the lightweight set up, just in case :idea: )
And so it continues...the spare room is getting rather full.
I have 4 tuner pedals - that's ok isn't it? :shifty:
Murray B
Posts: 428 Joined: Mon Nov 28, 2011 12:00 am Location: Staffordshire
Murray B wrote: I have 4 tuner pedals - that's ok isn't it? :shifty:
Of course it’s OK, I have three tooth brushes, and they always come in handy.
Wonks wrote:Eventide
Time
Factor
Eventide Time Factor? why didn’t you tell us you were selling it? It’s only fair we should all give first refusal to forum members, that’s actually quite cruel.
Posts: 19829 Joined: Sat Jul 12, 2003 12:00 am
Arpangel wrote:Of course it’s OK, I have three tooth brushes, and they always come in handy.
I didn’t know you only had three teeth.
Posts: 18266 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
That’s a whole new perspective, of course, we could have a set of pedals for each guitar (or keyboard) we own, that’s a good way to justify owning so many, purely on a convenience footing, you could even have pedals just for gigging, and studio, that way you don’t have to keep disconnecting pedal and PSU's, I’m already doing this, it works well.
Quite a few people I know have different pedalboards for different situations. And with so many good, cheap Chinese clones of classic analogue pedals available for £20-£25, it doesn't have to cost too much to do so.
Wonks wrote:Quite a few people I know have different pedalboards for different situations. And with so many good, cheap Chinese clones of classic analogue pedals available for £20-£25, it doesn't have to cost too much to do so.
Yes, I’m thinking of trying those Behringer ones, also the Mooer ones, but what I’m really looking for is an all in one solution, a small synth, with every synthesis option built in, every effect built in, and a fully featured audio recorder and editor, built in, that weighs a few ounces, is battery powered and that can be played in bed, on a pillow.
:think::)
Post by Random Guitarist »
I can certainly identify with this having recently sold a pedal. It had sat on the office shelf for 15+ years without 9v troubling its slumber. I only plugged it in to test it, but I was still reluctant to put it in the post. On any sensible level it's ridiculous to want to hang onto these things, but the emotions are a different thing.
I have pedals I know I will never use again. but they are still on a shelf. Swivelling round on the office chair I can see 16 pedals from where I sit. Maybe 4 of them I will use again. I can pretend that they will be a source of inspiration some day, but I kind of doubt it.
The only other possibility is if I make up a secondary pedal board. But that makes no sense. I would build a chain of pedals that I rejected from my main pedal board.
I am convinced now, it's time to sell, or maybe create a small pedal board . . .
Random Guitarist
Posts: 1132 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
Random Guitarist wrote:I can certainly identify with this having recently sold a pedal. It had sat on the office shelf for 15+ years without 9v troubling its slumber. I only plugged it in to test it, but I was still reluctant to put it in the post. On any sensible level it's ridiculous to want to hang onto these things, but the emotions are a different thing.
It is true, certain pedals have a deep emotional connection, I bought some just as I was moving into my new place, and they sat in their boxes for weeks, owing to building works going on, so I was really anticipating using them, so all that goes through my mind, it bonds you to things, emotional and important associations.
Post by ManFromGlass »
It’s true. I just got a Boss SE-50 up and running and the sound took me right back to younger days.
And
An old toothbrush is perfect for getting the dust out of pedal crevices!
Posts: 7466 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
ManFromGlass wrote:It’s true. I just got a Boss SE-50 up and running and the sound took me right back to younger days.
And
MFG, you know that SE50 I bought recently from a "reputable dealer" it had a fault, presets wouldn’t hold in memory, had to change the battery, all is now fine.
But it just goes to show that they hadn’t tested it, they would have seen on fire-up that the screen was all hieroglyphics.
It had obviously been used by the dealer’s mummy.
Wonks wrote:It had obviously been used by the dealer’s mummy.
That’s bad Wonks, I expect better from you!
OK then; it was all part of a pyramid selling scheme .
That joke is older than the pharo...
Sorry. I'll see myself out.
Posts: 28016 Joined: Sun Jul 05, 2015 12:00 am Location: York
Tut tut.
n common?
And
The clip that held the battery in mine was bent so the battery was loose. Easy fix. Hieroglyphs now back to english after the factory reboot sequence..
Post by SecretSam »
You could always donate some of the excess pedals to poor people in Africa. I would be happy to accept them on the continent's behalf.
SecretSam
Posts: 2924 Joined: Tue Oct 29, 2002 12:00 am Location: Officially, I do not exist.
And obviously we'd have to take all your money, house and other possessions away first to make you poor so that you could accept them.
Wonks wrote:And obviously we'd have to take all your money, house and other possessions away first to make you poor so that you could accept them.
"Boss saves the world!"
They can join Behringer and their keyboards.
Post by Music Wolf »
You just need to visit a guitarist forum such as The Fretboard. You'll find out very quickly that you don't have too many pedals, you actually have too few. You'll also discover that;
The pedals that you do have are 'wrong'
You don't have enough guitars
The guitars that you do have lack 'mojo'
You need better cables to join your pedals together
Your amplifier is wrong
You need a new guitar but you'll also need to change the pickups (without even trying the ones that are already in it)
After a week your new guitar will be wrong for you and you'll need to sell it (to save time, place the advert to sell the guitar before the guitar arrives).
Music Wolf
Posts: 2865 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Music Wolf wrote:You just need to visit a guitarist forum such as The Fretboard. You'll find out very quickly that you don't have too many pedals, you actually have too few. You'll also discover that;
That’s all so true, against what I’d like to believe!
Mind you, most guitarists I know have been happy with what they have, a friend has had his Les Paul since 1982, his new acoustic was bought for him about three years ago, by his wife, he’s happy with it.
He has "no" pedals, he has never used them, preferring to get the sound he needs by using his amplifiers, an old Mesa Boogy, a Pignose, and a JC120.
It doesn’t seem to matter, he sounds the same through all of them!
Another friend has had his Strat since I’ve known him, about 30 years, he has a big old Peavy amp, and a Zoom 9030.
Arpangel wrote:He has "no" pedals, he has never used them, preferring to get the sound he needs by using his amplifiers, an old Mesa Boogy, a Pignose, and a JC120.
That clearly can't be true (for a certain definition of truth) but may go some way to explaining why to me, a guitar player, all synths sound the same :bouncy:
Posts: 21896 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by al_diablo »
I realised my pedal board is all wrong and actually what I need is a Kemper
al_diablo
Posts: 227 Joined: Thu Jul 24, 2003 12:00 am
Seems Mr Spoons may have gone missing. He has not been heard from since posting the phrase “all synths sound the same”
The only suspects are every synth player who follows the SOS forums!
' :shocked:
