Two small but possibly significant points:
A piercing or focus-grabbing sound can appear to the ear/mind more "powerful" than a mellow one in such a way that even when it's being compressed appropriately according to it's electrical magnitude it still demands significant attention.
If you're compressing a mix with a single compressor and one element suddenly dominates the compressor will reduce the gain of the entire mix which maintains the balance of the elements so if you're expecting the vocal to blend better into the guitar it won't, as the guitar is also being compressed.
[Edit]
Jack Ruston - proof positive that great minds and magnificent lovers think alike.
Audio Compressor Question.
Re: Audio Compressor Question.
- shufflebeat
Longtime Poster - Posts: 9105 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Could be proof that I don't properly read previous comments.
shufflebeat wrote:Two small but possibly significant points:
[Edit]
- Jack Ruston
Posts: 3847 Joined: Wed Dec 21, 2005 12:00 am
Jack Ruston wrote:Could be proof that I don't properly read previous comments.
We made very similar suggestions at the same time but yours made it's way through the pipeline marginally quicker.
Valid points expressed beautifully - twice - bonus!
- shufflebeat
Wise words from many fine folks here...
Also worth mentioning the side-chain (the signal that the compressor reacts to, which may or may not be identical to the one that's being processed).
First, some compressors react to signal peaks, others to an average signal. For very brief high level sounds, this could affect the compressor's action. You can also choose to filter the side-chain signal — eg use a low pass filter, high shelf cut/boost, tilt EQ or a regular boost/cut to make the compressor more or less sensitive to the cymbal. You can even automate that so that it's only more/less sensitive at certain times.
But in this specific situation, I think I'd be editing the guitar part where that cymbal strikes! Maybe taking notes from elsewhere to cover it up. Maybe using a spectral editor to remove the worst excesses of the cymbal. Etc.
The cymbal was just an example. The actual problem is a rock singer who occasionally shouts/sings/screams very loud, so in this instance it's all the same sound that's being processed. The peak vs RMS setting is a good one to consider here.
Fixing a vocal level individually with automation would be much more transparent and natural sounding than relying on an algorithm, almost like having a singer with decent mic technique. This frees up the compressor to do what it does best, coaxing rather than hammering.
Specific compressors have their own character and role in the process, of course, and it's difficult for anyone to pronounce chapter and verse without hearing the context so all advice here (particularly mine) will be pretty generic and come with caveats.
- shufflebeat
Yeah if this is a vocal, automate it.
- Jack Ruston
Yeah. Automation. Or editing and clip gains. Or both.
I mean, if you're really lazy, you can tackle this to an extent using multiple compressors. But the results won't be as good...
