Akai 4000DB tape recorder.
Re: Akai 4000DB tape recorder.
Yes... running a tape machine is an expensive business...
But hey -- think of the distortion you can create with it!
...assuming it does actually still work.
Posts: 39041 Joined: Fri Jul 25, 2003 12:00 am
It’s a gamble Hugh, I’ve found another place Protape, and I’m around the corner from them now, I’m going to buy a 7 inch reel, they’ve got empty spools too, £28, not much, but it’s something!
Arpangel wrote: It’s a gamble Hugh, I’ve found another place Protape, and I’m around the corner from them now, I’m going to buy a 7 inch reel, they’ve got empty spools too, £28, not much, but it’s something!
Protape have been around for years just off Tottenham Court Road but last time I was after tape they didn't have as wide a selection as Tape City.
Posts: 14380 Joined: Mon Sep 10, 2001 12:00 am
James Perrett wrote:Arpangel wrote: It’s a gamble Hugh, I’ve found another place Protape, and I’m around the corner from them now, I’m going to buy a 7 inch reel, they’ve got empty spools too, £28, not much, but it’s something!
Yes, I remember Protape, I used to get my cassettes from them in the 80’s, I actually thought they’d gone out of business.
Managed to get some sound out of it today, it powers up, all lights working, capstan working, and engages, I just threaded a tape, and pulled it through, got something on the meters, seems like it should be worthwhile getting an empty spool, my masters are stereo half track, but at least I can see if the mechanism is OK.
Promising start Tony!
I have visions of Tony recording a masterpiece with a coiling pile of tape slowly building on the floor!
Hugh Robjohns wrote:I have visions of Tony recording a masterpiece with a coiling pile of tape slowly building on the floor!
Not a problem if he runs the machine at the top of his tower
- Folderol
Jedi Poster -
Posts: 18236 Joined: Sat Nov 15, 2008 12:00 am
I was more imagining a spontaneous work of genius emerging to the tempo of the tape end flapping round the reel...
Forum Aficionado -
Posts: 24663 Joined: Sun Jul 05, 2015 12:00 am
Folderol wrote:Hugh Robjohns wrote:I have visions of Tony recording a masterpiece with a coiling pile of tape slowly building on the floor!
I’ll give you a mention on the album if it works……….
LMFAO
I'm All Ears.
Update, surprisingly, it’s all working fine, I got an empty reel, and some master tapes on seven inch reels, I recorded years ago.
They play back fine, although at half speed, as they were recorded at 15ips, on a half track machine, so I had to fiddle around with the head selector switch to get anything out of it.
I found some blank tape, all fine, records well, although the heads need a good clean, and I’ll de-mag them too.
So money well spent.
As you guessed, the Akai is quarter track. But IIRC, the capstan sleeve slides off to make it 15ips.
- Tomás Mulcahy
Posts: 2568 Joined: Wed Apr 25, 2001 12:00 am
Tomás Mulcahy wrote: ↑Fri Sep 03, 2021 6:59 pm
Thanks for that Tom, I’ll investigate.
One weird thing, the left tape guide has a wooden centre to it, I’m sure it should be metal, I think maybe someone has bodged it up at some point.
Yes, oh well, it seems to work OK, seeing as I'll probably use it for loops, and distressed things, it’s not that important.
On mine (now long gone) the capstan sleeve removal switched between 3.75 and 7.5 ips.
15 ips wasn’t an option.
- mooblie
Regular -
Posts: 158 Joined: Fri Mar 23, 2007 12:00 am
Martin at HeadSpin
I owned one too in the ‘70s and it definitely did not offer 15ips speed.
Sent from my iPhone using Tapatalk
- Forum Admin
Posts: 4291 Joined: Mon Jul 21, 2003 11:00 pm
