Reamping doesn't seem to work with drive pedals for me
Re: Reamping doesn't seem to work with drive pedals for me
Post by cominginsecond »
The Elf wrote:Simplify, simplify, simplify. No pedals - that way you can check the basics. Once it's working as expected, then add more.
Wonks recommended the Boss pedal bypassed (when I'm recording the DI track) as a buffer in order to match impedance better. I saw some similar advice elsewhere on the web. I can try it without first, but without that, the only thing I have to try is to record at a lower level, and I really doubt that is going to make the difference in what I'm hearing.
cominginsecond
Posts: 12 Joined: Fri Sep 17, 2004 12:00 am Location: Boise, ID, USA
Wonks wrote:That doesn't sound right to me at all.
The API clone is the A12 module, so you must be feeding into a mic level input, and not a line or instrument input.
I'm confused. The A12 has an input and an output. I fed the output of the DI into the input of the A12. It works wonderfully for me for amp sim software.
Wonks wrote:Can you feed the DI straight into the mic input on the Focusrite, just to see if you get the same general bright sound quality?
Sure. I'm willing to try anything at this point.
Wonks wrote:Have you tried going straight into the instrument input on the Focusrite to see how that sounds? Just trying to find a way you can eliminate elements in your signal chain that could be causing your issues.
Sure. Again, willing to try anything at this point.
cominginsecond
But with a passive DI you may need a buffered pedal in bypass (when recording the signal) between the guitar and the DI box to get it sounding as expected. Just don't use one to start with when reamping.
Posts: 17040 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Some of the Seventh Circle Audio preamp modules have line/instrument inputs on the front panels as well as a mic XLR on the rear. I just wanted to make sure that yours was a mic input only unit. You know your setup well, but we can only go by what people tell us. It's amazing how often people leave out a piece of vital information when describing their system because they are so used to it.
So recording at a much lower level made it work 100 percent better. With my Timmy pedal, the output is identical. With my Joyo OCD type pedal, it was very close and with a little EQ it was also identical. My current theory is that I was clipping the interface outputs. I think they were turned up too loud in my interfaces mixer software and me recording at a lower level made it so it didn't clip the outputs. Thanks so much for your help.
cominginsecond
That's very good news.
The passive DI box impedance will be affecting the guitar signal a bit, so I'd look into getting an active one with at least a 500k input impedance.
A DI box is designed to convert an unbalanced line-level signal to a balanced mic-level signal. A mic-level signal is around 40dB less than a line-level signal.
A guitar level signal sits roughly in-between a line and a mic level signal, at about 20dB less than a line level signal. As a result, the DI signal is then about 20dB less than a mic level signal when it comes out of a typical DI box. Most mic pre-amps have enough gain to make this up, but more gain means an increase in noise, so it is best not to have to use a DI box that drops the signal level by 40dB or so, and the mic pre then having to raise it by an extra 20dB.
So if you want to improve your recorded guitar sound further, I'd have a look round at DI boxes designed specifically for passive guitar and bass use, with an input impedance in the 1 megohm region (or at least 500k). It's not something I've looked into in any great detail, and have no experience of the more expensive products. But looking round, Warm Audio do a Direct Box Active with a 1 meg input impedance and variable attenuation level. If you were in the UK, the Orchid Electronics products are often highly recommended in this forum.
+1 Good news.
With a little bit of tweaking here and there I think you are now on the right path. Again, compare and make adjustments until you have a system that you can reliably return to in future.
The trick is to ensure that the signal you generate from your DAW is as close as possible identical to the signal that would come from your guitar.
And to explain what I said above... 're-amping' is generally about re-doing the process of sending a guitar's pickup signal back to its amp for re-recording, just as if it were being played again at source - hence the phrase. That's not a good description of sending a vocal, for example, to some guitar pedals, where no 'amp' (or, indeed, any sense of 're') is likely to be involved.
Posts: 20089 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
