Would some kind soul offer advice on proper dynamics and EQ for the Hammond B3 / Leslie setup in both a recording and live setting? I can find a good deal on mic technique but nothing on dynamics and EQ.
When doing my research I thought I'd be inundated with advise given the iconic stature of the Hammond B3 / Leslie.
A search at the Keyboards & Synthesis forum turned up no mention of "Hammond"; can that be real?
I have difficulty, particularly in EQ'ing as the droning of the rotor works against my natural instincts.
Thanks in advance for any and all suggestions or experiences.
Dynamics and EQ on the Hammond B3 / Leslie Setup
Re: Dynamics and EQ on the Hammond B3 / Leslie Setup
It shouldn't need EQ -- the drawbars are the EQ, really -- and I've never needed much in the way of dynamics processing either -- that's what the right foot is for on the expression pedal.
But if your player is not that great, then I'd look at a gentle leveller -- an optical compressor maybe with slowish attack and release times, and a moderate ratio of maybe 3:1 or less.
Posts: 39033 Joined: Fri Jul 25, 2003 12:00 am
A droning of the Leslie should not be easily audible. Perhaps you are recording it too quietly? Hammonds like to be noisy!
- The Red Bladder
Frequent Poster - Posts: 3328 Joined: Tue Jun 05, 2007 12:00 am Location: . . .
The Red Bladder wrote:Perhaps you are recording it too quietly?
Or applying too much compression?
Posts: 14379 Joined: Mon Sep 10, 2001 12:00 am
The Red Bladder wrote:A droning of the Leslie should not be easily audible. Perhaps you are recording it too quietly? Hammonds like to be noisy!
I've yet to hear a quiet one!
Hugh Robjohns wrote:It shouldn't need EQ -- the drawbars are the EQ, really
I've never done the real thing, but I do find that a gentle low cut can tame the bottom end a bit when mixing with a band. My modern Hammond (sk2) can push out a fair bit of bass end, so I permanently have the low end shelved rather than boom over the bass.
