Expression Pedal Recommendations?
Re: Expression Pedal Recommendations?
I have one of the M-Audio ones, and it works great.
I did convert it from wired to a TRS socket because the wire was way too long for my application, connecting to the control in of my Boss SY-1 synth pedal, which was 2 inches away from the expression pedal.
Regards, Simon.
Regards, Simon.
- Stratman57
Regular - Posts: 425 Joined: Wed Apr 20, 2005 12:00 am
Stratman57
I'll throw in a third mention of the m-audio one, as that's what handles the expression on my board right now. It's been trouble free for several years of service on my main pedalboard mostly controlling whammy-style pitch bend. I'm considering getting a 2nd Dunlop Volume X mini modded with a buffer for volume duty and shifting my current one to expression to save space on the board but if size isn't a problem it's a bit spendy.
- Funkyflash5
Regular - Posts: 215 Joined: Thu Apr 26, 2018 12:43 am Location: Wisconsin, USA
I also have the Hammond EXP-50 (which I use with an SKX keyboard) and an EXP-20 (used with an XK-1c). The 50 is nicer than the 20, but I wouldn't say it was significantly better than the Yamaha FC7 yet costs twice as much!
Posts: 39099 Joined: Fri Jul 25, 2003 12:00 am
I literally have a EXP-50 and an FC7 here under my feet. The Hammond is definitely the classier act! The fact that you can add your own length of cable to the Hammond is also a big plus here.
Yes... but twice-the-price classier?
Like you, I mildly prefer the EXP-50, but I'm not upset when using the FC7...
I have a couple of those moog pedals, not a great fan here, a bit on the light side!
The Alesis F2 is pretty good (nice and weighty), but everyone should have a FC-300
- Guest
Hugh Robjohns wrote:Yes... but twice-the-price classier?
I did allude to the difference in price. The FC7 is better value, but the Hammond is Rolls-Royce 'sod the expense'!
Hugh Robjohns wrote: ...yet costs twice as much!
From the prices I'm seeing, more than four times as much for the EXP-50 than for the FC7.
I also see there's an EXP-100, which looks the same as the 50 with an added kick switch. One of the customer reviewers on the 100 suggested that it's an optical pedal, but then they also said that they think that's the cause of extra latency, so...
I'm still thinking I'll order both the FC7 and the EP-3, and keep the EXP-50 as a future possibility.
BWC
You certainly are, Pepe!
BWC wrote:From the prices I'm seeing, more than four times as much for the EXP-50 than for the FC7.
Ouch!
In the UK, the FC7 is around £75 and the EXP50 is around £145 -- hence my double-price comment above.
However, I see Sweetwater's prices are $45 for the FC7 and $212 for the EXP50!
That makes the EXP-50 about the same price as in the UK, and the FC7 a real bargain!
Mechanically it is very similar, but the internal electronics are quite different -- whereas the EXP-50 (and -20) employ a simple pot, the EXP-100 uses a light-dependent resistor (photo-electric cell) as the control element. It connects via a DIN style plug and the foot side-switch toggles the Leslie speed. Naturally, though, the EXP-100 can only be used on a few specific Hammond keyboards like the XE-1 (and XE-101, XE-103), and the portable XK3 and new XK5 (and their variants).
It is.
..but then they also said that they think that's the cause of extra latency, so...
Quite. The Internet is a constant source of amazement and amusement...
Sounds like a fair plan to me.
Wow, I'm surprised the price difference is that extreme between here and there. The Moog is only slightly more than the Yamaha over here at $49. If the prices of those two were doubled, I wouldn't be so keen on buying them both.
BWC
Hugh Robjohns wrote:One of the customer reviewers on the 100 suggested that it's an optical pedal
It is...but then they also said that they think that's the cause of extra latency, so...
Actually, It's (sort of) true. In all the LDRs I've come across, resistance change from full light to full dark takes a whopping great 30-50mS
- Folderol
Jedi Poster -
Posts: 18282 Joined: Sat Nov 15, 2008 12:00 am
So more of a slew-rate issue than latency, then...
{advertising}
Our pedals employ a special device that smooths the change as you deploy the pedal. This avoids the annoying artifacts you get with simpler potentiometer type units.
{/advertising}
{/advertising}
- Folderol
Jedi Poster -
