Building my home-studio
Re: Building my home-studio
nifaun wrote: Tue Jul 06, 2021 10:22 amI hope the positioning of the panels are fine. Could you check please?
https://imgur.com/iZ1RS0m
You might want to think about some panels on the wall opposite the speakers - that's another 'mirror point'.
nifaun wrote: Tue Jul 06, 2021 10:22 amSince I can't rest them on the floor, bass traps should be at hight of the singers mouth??? And I have tubes in one corner, I'd like to attach them to the wall.. But I dont know to be honoust.
Bass traps work best in corners, triple-corner are the best, but you'll have to find the compromise that works for you and the room.
The height of the singers mouth won't make much difference a low frequencies.
What you've drawn up should make a significant difference to the room and give you much more accurate monitoring.
Posts: 24669 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by nifaun »
blinddrew wrote: Tue Jul 06, 2021 4:57 pm
Okay, so you suggest me to set them on the floor? It is difficult to cover the bottom and top triple corner, I actually dont know how to do this in a practical way, Would you have suggestions?
I have located the monitors with the mirror trick, and pointed the location at the side wall. Would you suggest to attach those panels(1,80) to the wall or is setting them on the floor sufficient?
nifaun
Posts: 15 Joined: Mon Jun 07, 2021 2:59 pm
nifaun wrote: Wed Jul 07, 2021 6:26 amOkay, so you suggest me to set them on the floor? It is difficult to cover the bottom and top triple corner, I actually dont know how to do this in a practical way, Would you have suggestions?
If you scroll about halfway down this page: https://www.soundonsound.com/forum/view ... &start=120 you'll see how I made my bass traps, as you can see it's a very simple and lightweight frame to raise half the treatment to the top corner. Something like this might work for you.
nifaun wrote: Wed Jul 07, 2021 6:26 amI have located the monitors with the mirror trick, and pointed the location at the side wall. Would you suggest to attach those panels(1,80) to the wall or is setting them on the floor sufficient?
I would expect putting them on the floor will be fine (unless you have a really, really high seating position), just make sure they're secured for safety's sake.
