Disappearing synth pad in mono - any tips?
Hello all,
I've been gradually working on the tips given to me from the last mix I put on here for feedback and a new improved version is just about done
However, I thought I'd do a quick check on what the mono version sounds like - mostly fine, but my super wide phasing synth pad pretty much disappears when in the mono version of the mix.
So far I have tried changing the polarity of the synth's left channel - this improved the mono level a little (not as much as I hoped) but the result doesn't sound anywhere near as good as the original noise in stereo.
I am suspecting that one of the causes of the problem is that I boosted only the 'Side' level of the synth sound to push it to the edges of the mix and leave space for the other instruments, if this is the case then is there another way of getting the width that would be more mono compatible?
Is there anything else I could try?
Thanks in advance.
Thanks in advance.
Re: Disappearing synth pad - sum to mono any tips?
Murray B wrote:my super wide phasing synth pad pretty much disappears when in the mono version of the mix.
Yes, it would. The clue is that it's 'super wide' which means most of the signal is carried in the Sides component, and very little in the Mid component. When summing to mono the Sides component is discarded, hence your problem.
I am suspecting that one of the causes of the problem is that I boosted only the 'Side' level of the synth sound to push it to the edges of the mix and leave space for the other instruments, if this is the case then is there another way of getting the width that would be more mono compatible?.
As explained above, if you put stuff only in the Sides component you inherently lose mono compatibility. No way around that.
So, you either:
1. reduce the width a bit to find a happier compromise,
2. or you blend in a little of a similar -- but different-- mono pad to give an acceptable (slightly different) sound in mono,
3. or you could try a phase rotator on one channel of the stereo pad. A 45 degree rotation may achieve what you want.
4. Or you could try introducing a short delay to one channel of the stereo pad, taking care with the value not to introduce obvious comb-filtering colouration in mono.
Posts: 39053 Joined: Fri Jul 25, 2003 12:00 am
Re: Disappearing synth pad in mono - any tips?
Thanks for taking the time to explain this Hugh and for the advice,
I'm still a novice with this stuff especially with the whole Mid/Sides thing and I still don't really know what I don't know yet...
I will try all of the above options and see what works best in the A B between the Mono and Stereo versions, every day's a school day
Murray B wrote: I'm still a novice with this stuff especially with the whole Mid/Sides thing and I still don't really know what I don't know yet...
Murray, you're not alone. I sort of get the the mid-side thing but in practice I could well find it difficult to identify the symptoms if summing to mono, which is something I do occasionally but need to do more of.
I'm continuously working on getting my engineering skills up to speed but much as I hate to admit my shortcomings on that front I'll always be more a performer than an engineer. Years of working on the engineering has definitely yielded great improvements but there is plenty I still need to learn and/or become familiar with.
Taking to heart the advice from folk who have done engineering for as long as one has done performing is humbling and enlightening in equal measure
Posts: 8853 Joined: Wed Sep 01, 2004 12:00 am
Eddy Deegan wrote: much as I hate to admit my shortcomings on that front I'll always be more a performer than an engineer.
Oh dear, I guess that makes me a well-intentioned noodler, as I can’t even play the instrument I’ve been writing in for the past 4 years.
Eddy Deegan wrote:I sort of get the the mid-side thing but in practice I could well find it difficult to identify the symptoms if summing to mono, which is something I do occasionally but need to do more of.
This is one area where the BBC's old A/B M/S twin-twin PPM was so useful, and why being able to monitor the stereo difference signal on a monitor controller makes identifying and solving this kind of issue so much easier!
An audio vectorscope or Lissajous display is also very helpful for spotting this kind of thing.
Hugh Robjohns wrote: An audio vectorscope or Lissajous display is also very helpful for spotting this kind of thing.
Duly bookmarked, along with a couple of notes for reference. Thanks Hugh
Ben Asaro wrote: Oh dear, I guess that makes me a well-intentioned noodler, as I can’t even play the instrument I’ve been writing in for the past 4 years.
I've heard your work Ben - you're comfortably past "well intentioned noodler", that much I can say for sure
Eddy Deegan wrote:Hugh Robjohns wrote: An audio vectorscope or Lissajous display is also very helpful for spotting this kind of thing.
Although there are plenty of plugins and interface/DAW displays that can provide audio vectorscopes I much prefer an external hardware meter, just because it doesn't take up screen space, never disappears, and it's always viewable at a glance.
Arguably the best value on the current market is the TC Clarity M which is a really versatile, well designed meter that includes a vectorscope display and the TC Radar display for loudness evaluation. It's available in stereo and stereo+5.1 versions and I highly recommend it -- buy it now before Uli decides to stop TC from building it!
The stereo version is around £225 and I've seen the 2+5.1 version for under £300 online.
+1 for the TC Clarity.
Yes, you can do it other ways, but I find that having the Clarity just sitting there doing its thing all the time means you reference it more often, even for simple curiosity.
Quite so... and the thing about vectorscope displays is that it takes time to learn how to intepret what you see and relate the display shapes to what you're hearing. So having the meter in the corner of the eye or just a glance away all the time really helps.
One will be turning up here on Monday
Eddy Deegan wrote:One will be turning up here on Monday
Having a tactical display is one thing, but having your own logo on there is far more important!
Show Off!
I haven't actually tried this but an engineer who's opinion I value once told me about a widening trick with a graphic EQ like the waves 32 band GEQ that preserves mono compatibility
On the left channel you cut every even band and on the right channel you cut every odd band, and then make up the overall gain.
The idea being that you end up with elements of the signal in the left channel and the missing elements in the right channel.
Like I said I have never actually tried this but perhaps luminaries with bigger brains than I could chip in on the practicality.
MarkOne wrote:On the left channel you cut every even band and on the right channel you cut every odd band, and then make up the overall gain.
Yes, this can work with a mono or not-too-wide stereo signal, but all those interacting filters can affect the sound quality too. It's a variation on a standard fake-stereo technique.
There’s a plug-in that makes the fake widening process very easy. I’m not at my computer, but I think it’s called “Wider” and is made by Infected Mushroom and I believe it is free.
Edit.. back at computer now..
Here's a link, and it is still a free plug-in!
https://polyversemusic.com/products/wider/
Spot on Kwackman!
According to Infected Mushroom:
"Thanks to Wider’s one-of-a-kind all pass and comb filtering algorithm, a natural sounding stereo image is created from a mono channel, without compromising the phase between the sides! Instead, Wider cancels itself out when summed to mono, so the original signal is left intact.
Wider can be used to increase the stereo image of any mono signal up to 200% of full stereo for an extra wide, exaggerated effect."
Martin Walker wrote:Spot on Kwackman!
Definitely going to investigate this - sounds like just the ticket Thank you
Murray B wrote:Definitely going to investigate this - sounds like just the ticket Thank you
Glad Kwackman and I could help!
Just be aware that it's intended for turn MONO sources into stereo ones, and not primarily to make already stereo sources wider - I downloaded it as a freebie and tried it out, but it's rare that I'd want to turn mono into stereo (my mono sources tend to either get mono or stereo effects on them, or just a little EQ and reverb, which places them in the stereo picture.
When I want to make something wider in the mix, it's invariably a stereo sound that I want to get out to the edges of the stereo image, beyond everything else, for dramatic effect. Apart from this special case, most of the time I'm far more likely to REDUCE the stereo width of a stereo sound so it doesn't take up so much real estate in the mix.
