Murray B wrote:Definitely going to investigate this - sounds like just the ticket
Thank you
Glad Kwackman and I could help!
Just be aware that it's intended for turn MONO sources into stereo ones, and not primarily to make already stereo sources wider - I downloaded it as a freebie and tried it out, but it's rare that I'd want to turn mono into stereo (my mono sources tend to either get mono or stereo effects on them, or just a little EQ and reverb, which places them in the stereo picture.
When I want to make something wider in the mix, it's invariably a stereo sound that I want to get out to the edges of the stereo image, beyond everything else, for dramatic effect. Apart from this special case, most of the time I'm far more likely to REDUCE the stereo width of a stereo sound so it doesn't take up so much real estate in the mix.
