Arranging strings, pop song
Hey peoples, looking for awesome approaches to arrange strings! I'm making a pop ballad, where piano and vocal are the main instruments, there is also a bass guitar, drums at the very end and a big ensemble of 60 string players.
So here are some questions.
1. I already have harmony. Would you start laying out each section (celli, violas, violins, etc.) individually or lay out an ensemble as one instrument first and then break it down to sections?
2. Would it be a good idea to aim for notes that piano doesn't play to avoid frequency conflicts?
3. Would you double the bass guitar part with bass strings at some spots (for intensity) and carve the low end out of the strings, so that just the character would remain, but not the frequency conflict?
4. Any other things to consider?
Re: Arranging strings, pop song
apaclin wrote:1. I already have harmony. Would you start laying out each section (celli, violas, violins, etc.) individually or lay out an ensemble as one instrument first and then break it down to sections?
I get a basic chord 'helper' part worked out (not strings), then begin laying solo lines for each part. As I progress I see where I have holes in the chords, or where I have doubles/clashes - and fix these by re-working each part. I don't find that an ensemble part helps - it actually makes my job more difficult.
apaclin wrote:2. Would it be a good idea to aim for notes that piano doesn't play to avoid frequency conflicts?
No. If you're going for a 4/5-part string arrangement, and the piano is playing anything more than single notes, then this would be near-impossible anyway.
apaclin wrote:3. Would you double the bass guitar part with bass strings at some spots (for intensity) and carve the low end out of the strings, so that just the character would remain, but not the frequency conflict?
If I have bass guitar in the mix then I would possibly leave out a bass string part altogether - or at least HPF it heavily. In any mix it's a good idea to decide which single instrument is handling the bass and restrict everything else in that frequency range.
apaclin wrote:4. Any other things to consider?
Make each string part as melodic as possible, especially in the higher parts. Get *very* busy with the dynamics and vibrato controls! Keep lower-pitched parts wide apart (octaves and fifths at least) and avoid large jumps if you can, especially in the higher parts. Avoid obvious parallel movement between parts. Use passing notes to smooth out lines and create melodic movement. Avoid 'block/keyboard' chords and sustain notes between chords when you can... And don't be afraid to compromise/ignore any of the above when it sounds right to do so. Nobody said this is easy!
A good string arrangement can take me days, and at times I can feel like I'm getting nowhere. Sometimes I'll scrap the lot and start again. It takes time and patience.
Thanks man! But let me be more specific on the point 2, of course it would be impossible to avoid common notes between the strings and the piano, but if I see a gap at the piano chord, I can consider to fill it with strings, rather than play the same notes that piano plays?
apaclin wrote:Thanks man! But let me be more specific on the point 2, of course it would be impossible to avoid common notes between the strings and the piano, but if I see a gap at the piano chord, I can consider to fill it with strings, rather than play the same notes that piano plays?
It's not something that would ever cross my mind. I really wouldn't be so clinical about it.
Have a look at this series for some ideas...
https://www.soundonsound.com/techniques/arranging-strings-part-1
wireman wrote:Have a look at this series for some ideas...
Thanks!
apaclin wrote:Hey peoples, looking for awesome approaches to arrange strings! I'm making a pop ballad, where piano and vocal are the main instruments, there is also a bass guitar, drums at the very end and a big ensemble of 60 string players.
I work differently from the Elf - which shows that many approaches clearly work!
1. I start with an ensemble part playing block chords, then evolve it, then split it into separate instruments.
2. There’s no strict rule here - just try things until you find something that sounds good.
3. That can work quite well in some cases. You can try pizzicato too. But I’d say take care here and don’t overdo it.
4. There’s a huge amount to think about, and it can take a long time to master it (which I haven’t yet!). So keep things simple to start with. Here are some thoughts, far from complete :
Voice leading is essential with string parts.
Dynamics (including within single notes) and appropriate vibrato are essential too.
Phrasing is vital, especially ensuring that the right parts are legato or detached.
Use passing notes to break up block chords.
Fast runs are much harder to get sounding right than slower transitions with samples.
Try to bring variety using contrary motion and parallel motion.
Choose a rhythmic or melodic motif and exploit it.
Cellos and double basses are often doubled an octave apart.
You can include parts for solo instruments too to add variety.
There are basic rules for close harmonisation that you can study to help choosing notes.
Are you talking about 60 real players? Or samples of a 60-piece string section? If you’re talking about real players then you have a lot more to consider! I would seriously think about engaging an expert to help you.
It would have been nice if George Martin had written Arranging for Dummies, but he didn’t. String arrangements come in many flavours, you can go from the rudimentary All the Lonely People arrangement to something using a full orchestral string section to result in some lush wall of sound. Depends what sort of mood you want the music to portray. That said, there are some basic rules, if choosing between a 3rd and a 5th, where you can, choose a 5th, try and space out the notes, you can get away with layering chords, but of course have to avoid clashes, except to create tension for example.
Take C major played on the piano C, E, G, on top of that put G, B, D but the B clashes with C, however with the B omitted, you have a C9 but leave the B in anyway and you get a chord with a note that is on a quest, endeavouring to find resolution - in this case the C, at the same time of course the D would move to E, you have so many choices, in the example the Gmajor chord on top of Cmajor could move to an Aminor on top of the Cmajor, again depending on the tune itself. I feel the bass has to be emphatic, if two notes are used then use octaves, to add variety use inversions. I find getting the bass right the most difficult challenge, trying to write an interesting bass line, but avoiding something that ends up too busy, distracting and discombobulated, but I want to avoid the standard root and 5th. Bach could get away with it, I can’t
OneWorld wrote:Bach could get away with it, I can’t
To be fair, that applies to most people!
Posts: 28016 Joined: Sun Jul 05, 2015 12:00 am
Thanks, I started laying out sections and noticed that I struggle with writing automation (modulation, expression). From what I see on Youtube many people write modulation and expression at the same time, but why? And what's the use of expression, just to emphasise the modulation? I didn't get it clearly. Second, there is this guy that makes dips on each note switch. In my case it doesn't sound realistic (am I doing it too much?), do you do it also?
https://youtu.be/JUmStR0kWh4?t=142
I didn't watch that video, but I will say that expression is THE most important aspect of string simulation.
As to dynamics versus expression - it depends on the library. Some libraries have layers of dynamic variances, and this alters the tone of the strings, so some correlation between dynamic layers and expression is important. With other libraries you may only have one layer, so it will all be about the expression.
To understand how the expression and dynamics might work you need to do your homework and listen to strings to understand how they emote. Unless you understand this then then no amount of technical background will help you create something both realistic *and* engaging.
I use this custom fader box for dynamics, expression and vibrato, and I record all three as I play:
apaclin wrote:Thanks, I started laying out sections and noticed that I struggle with writing automation (modulation, expression). From what I see on Youtube many people write modulation and expression at the same time, but why? And what's the use of expression, just to emphasise the modulation? I didn't get it clearly. Second, there is this guy that makes dips on each note switch. In my case it doesn't sound realistic (am I doing it too much?), do you do it also?
I think what the CCs do isn’t always consistent between libraries. What library are you using? There can be good reasons for linking CCs - I have an Embertone solo violin library and I often set it up so that modulation controls both the expression and the degree of vibrato.
No, I don’t dip the modulation on note switches, but my libraries (Spitfire) have a slight built-in crescendo on sustained notes which mimics what real players do. Some libraries have a uniform sustain patch though, in which case I understand what this guy is trying to achieve. If you don’t do something to the long notes in this kind of library, they will sound very dull.
Wow, Elf - that is a fantastic device!
RichardT wrote:Wow, Elf - that is a fantastic device!
It's a relatively simple device built around an Arduino, but it is nicely made - better than I could achieve. I had a USB socket added so I can use any length cable.
RichardT wrote: What library are you using?
At the moment Native Instruments Symphony Series strings and the dynamic range of it is bigger than in Spitfire.
The Elf wrote:I didn't watch that video, but I will say that expression is THE most important aspect of string simulation.
If expression is the most important, then why in Symphony Series modulation knob is a huge one and not the expression?
In that Library, the dynamics control affects the intensity of the playing. Expression is simply a volume control.
Still no. It doesn't really work like that. You won't hear a single balanced chord from bottom to top of which some notes are played by the strings and some by the piano. You'll hear a string chord with a particular balance, and a piano part with a particular balance, and an interaction between them (and between them and all the other parts).
Basically each timbre should sound balanced in itself. That's how classical composers and orchestrators do it in big orchestral tuttis. They write each section (strings, woodwind and brass) as if it were its own complete orchestra, and then put them together. This is even more so in your case because of the extreme timbral difference between strings and piano, which will separate them hugely in the ear of the listener.
If there's a gap in the piano chord that needs filling, then fill it in the piano!
What you do need to do with a big ensemble like that is be clear about the function of each part, and don't just shove parts on top of each other duplicating the same function. If your strings are playing block chords there's not much point having piano play them as well; you're better off having the piano arpeggiate through them or whatever. In one sense your inuition about making the parts compliment rather than duplicate each other is correct, but this should occur in terms of the kind of figuration they play, not in terms of which notes they sound.
I agree with a PP that I'd be tempted not to use bass strings, or at least not use them much.
You need to have a clear idea what you mean by "strings". The 4/5 part outlay of the classical orchestra wasn't designed to go with a pop or rock band, it was designed to be the main backbone of the music that composers started with and then added things do. It performs this function very well because the stringed instruments are so homogenous (a cello sounds pretty much like a violin but lower, whereas a bassoon doesn't really sound like a flute).
"Strings" in rock and pop music are often not this. Often they're just violins (as in a lot of Motown arrangements, disco licks etc.) Sometimes violins violas and cellos but with the cellos basically playing melodically, reinforcing the violins at the lower octave. They're not performing a bass function at all.
Where you DO use a full section including cellos and double basses, you need to control what you do between them and the electric bass so the bass part is clear and not muddied up. This is easy enough to do in a fully written part. With moderate moving parts you can even just double them, and it's similar to what classical composers did with arco cellos and pizzicato double basses. The real difficulty comes when you want the electric bass to improvise or play with some stylistic freedom. There's not really any way to make the string basses not get in the way of that and you're better off just dropping them out.
Wow - what an incredibly informative reply Wurlitzer!
Posts: 21631 Joined: Wed Jan 13, 2010 8:44 am
Wurlitzer wrote:3. Would you double the bass guitar part with bass strings at some spots (for intensity) and carve the low end out of the strings, so that just the character would remain, but not the frequency conflict?
You make a good point there, well relating to the bass end of things, which would be the cellos, but in pop, not really needed, or if used then double the violin parts, but often left out. Although this isn't pop, but jazz, I think the strings fit i just right....
Fox Capture Plan - The Butterfly Effect.........
https://www.youtube.com/watch?v=8cMhQ_teEoY
And on the subject of strings in pop, well what better example than this, Bohemian Rhapsody - Brooklyn Duo + Dover Quartet
https://www.youtube.com/watch?v=i1nGx4DX83U
OneWorld wrote:And on the subject of strings in pop, well what better example than this, Bohemian Rhapsody - Brooklyn Duo + Dover Quartet
What a wonderful video for studying how to voice a small string ensemble!
apaclin wrote:wireman wrote:Have a look at this series for some ideas...
Thanks!
In case you are *not* viewing that article on desktop, you won't see the sidebar righthand links to the other three Parts in the 4-part series, so here's a link to the whole series:
https://www.soundonsound.com/series/arranging-strings
BTW, there are some great other articles on the Series landing page:
- Forum Admin
Posts: 4607 Joined: Mon Jul 21, 2003 11:00 pm
FREE 2nd Edition RECORDING TECHNOLOGY eBook
Search 17,722 SOS Reviews+Techniques web articles plus 6,909 News stories (more added each day): www.soundonsound.com/search
SUBSCRIBE to SOS Print / Digital magazine
www.soundonsound.com/subscribe - help support your favourite content provider in the Music Technology & Recording space.
Podcasts - Listen to 190+ ear-grabbing episodes across 3 SOS Podcast channels - more podcasts released Weekly. Search "Sound On Sound" on Apple, Amazon, Spotify.
One thing I've found useful is to sway as Orchestral string players do.
The other thing is to imagine their bowing hand movements.
If the String part we are writing sitting down at a keyboard, makes us sway, then we are quite the way there.
If we can imagine the bowing hand movements, this helps us in how we write the String parts.
In relation to what Wurli said.
Pop has steady bass. So our Strings shouldn't have bass that clashes with this bass.
Similarly we can see (hear) what frequencies the singer, the vocal harmonies, the instrumentations take up.
Then we can see (hear) what frequencies our String parts take up.
We can then either drop out frequencies from our String parts or drop out something from the Pop parts : when both parts are playing together.
This way they won't clash (as much). They will have space.
- tea for two
Frequent Poster - Posts: 4015 Joined: Sun Mar 24, 2002 12:00 am
