Discussion: putting together a single-synth Berlin School rig
Re: Discussion: putting together a single-synth Berlin School rig
Post by Ben Asaro »
The Elf wrote:I'm kicking myself that I didn't also mention the Audiothingies MicroMonsta 2.
The only problem is that they are rare as fish socks and the world is currently awaiting a new batch to arrive.
It is the size of a small paper-back book, powers from USB, 3-oscillators, 16-voices, or dual 8-voice... Really amazing synth at an amazing price,
Does it play multiple parts, though? That's where the rubber meets the road for me, I need to have 3-4 sequences running at once on a single unit.
Ben Asaro
Posts: 2365 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Post by YashN »
Big B's Deepmind 6 or 12D.
YashN
Posts: 62 Joined: Mon Oct 12, 2020 11:56 pm Location: North America
It can play 2 parts in dual mode (2 x 8-voice synths) - buy 2 of 'em for 4 parts! ;)
Seriously, for the money and physical size it would be worth considering.
Posts: 20100 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by Ben Asaro »
I'm sure it is, but that starts the slippery slope of getting away from a single box solution.
Ben Asaro
Isn't that what the second, portable, modular set-up is for?
Posts: 24680 Joined: Sun Jul 05, 2015 12:00 am Location: York
Glue them to a piece of wood - it would still be lighter and smaller than any rack.
Sent from my iPhone using Tapatalk
Post by Ben Asaro »
blinddrew wrote:Isn't that what the second, portable, modular set-up is for?
If I had my druthers, I would do this in 104hp with the NerdSerq, Chainsaw Quad VCA, and 4 filters ... but that creates more problems than it solves. I've played maybe 300 gigs in NYC over my lifetime and I know enough to know that ideally I want a maximum of 3 devices, no more than 5 cables, and less than 10 minutes (preferably 5) for setup and breakdown.
I need to get from my building onto a bus, the subway (1-2 trains) and back, so multiple power supplies, spare cables, even a tuner adds too much overhead to the travel requirements.
Ben Asaro
Post by Ben Asaro »
YashN wrote:Modal [Cobalt8, Argon8], Korg [Opsix, Modwave, Wavestate, Minilogue[XD]], etc...
Aren't we just spoilt for choice nowadays?
I'm not sure you read my OP; do any of those offer a significant improvement over what I already have? And if so, what? Just listing a bunch of synths isn't very helpful and I've already explained at length what my use case and needs are.
Ben Asaro
Post by YashN »
I sure did, because who wrote this, me?: "Or perhaps some other option?" I'll leave you to do the research on the other synths mentioned, e.g. on YT.
Re-read my post on the Kurz above (or perhaps you didn't find it helpful), but if you've already made up your mind not to use it, then go with the JV.
Either way you look at it, by your own admission, you haven't even programmed the JV in any depth. The Kurz either.
Had you done some work on the Kurz, you'd find it covers a lot of bases, to the extent you'd GAS less on additional synths.
For me, I'd definitely consider modular/analogue: a good portion of what constitutes the Berlin School is Tangerine Dream, and early TD had a lot of that.
That style is often fairly minimalist, the background being an 8-note sequence with played variations on top.
I can do that kind of thing in a single program, a single key played and the whole track evolving like that on the Kurz, with the ability to do more if I want, like playing live tracks manually...
Daniel Fischer did a whole Pink Floyd track on a Kurz like that once...
YashN
I was going to suggest a Waldorf blofeld but although its a small box, its solid and isnt tempo sync friendly.
Apart from that, its a competent VA, can do FM squeels, has a PPG filter & of course the PPG wavetables. Easier & quicker to program than a Kurzweil. .
for 10x the price theres Nord Wave II - does knobby hands on VA, FM & has sample replay - which is nice because Nords have access to the original mellotron master tapes. Some of which are customer specific, like the Tangerine dream reels.
:shock: that was pre-recorded and not synthed live ?????? All good fun :D
https://www.nordkeyboards.com/sound-lib ... ist-sounds
if time is not of the essence, Behringer are probably just finishing off their PPG wave 2.2 but that might only be duo timbral and Ive not heard if it includes the sequencer.
Posts: 3718 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Post by John Stafford »
For me, a sequencer like the Korg SQ-1 would be a must for a Berlin School setup.
You could carry the SQ-1 in your pocket, so it wouldn't feel like carting more gear.
John Stafford
Posts: 156 Joined: Sat Jun 27, 2020 8:51 am Location: Ireland
Post by Ben Asaro »
Just had my first round of editing an Init patch in the JV-1080. Patch Base is great in that it gives visual feedback. However, I am struggling to figure out how to apply the filter envelope in a way that will result in a decent pluck. I'm not even hearing the filter envelope, actually. Going to keep plugging (plucking?) away, I'm sure there's something obvious I'm missing. With an analogue synth, it's easy peasy. Back at it!
Ben Asaro
Post by Ben Asaro »
LOL got it, thanks to the diagram in the Owner's Manual. To set the decay for Level 1, you actually have to adjust the time of Level 2, since that's the time it takes to get from Level 1 to Level 2. It's versatile, but totally different from what I'm used to with analogue EGs.
Now to see if I can get a workable waveshape now! :D
Ben Asaro
Post by Ben Asaro »
Well, I'm pretty chuffed -- this sounds much better than it has any right to!
Figuring out how the effects are added was a bit more complex than it needed to be, but I sorted it out in the end. I'm a little disappointed by the fact that if you have effects on a patch, those effects are overridden when in Performance mode, but it's not a deal breaker.
After I dialed in a rough pluck patch, I felt it was a bit 'squelchy' in that way that Roland filters sound, but once I added delay and reverb, it sounded great!
The versatility and depth of the JV-1080's editing was quite surprising, and the manual actually has lots of useful info, I think it just automatically assumes you have a certain level of familiarity with the architecture.
I'll keep chipping away at it, my plan is to write the plucks on my own and then use the Orchestral and Bass & Drum expansion cards for bass, drums, and string sounds.
Will see how it goes!
Ben Asaro
Post by Ben Asaro »
Had a chance to work on this some more early this morning. Everything sounds/works great. I think that the ultimate setback is going to be the rhythm track. If I use the KSP for two melodic lines, bass, and leave one open for live improvisation over top, there are no tracks left for drums.
The question is: do I add the BeatStep Pro? Stand alone drum machine? Or scale it way back and have just one sequenced line, one bass track, one drum track, and one live improv track?
The advantage of using the BSP is that it also adds 2 more potential melodic lines, which can create some nice complex syncopations.
Hmmm ... will have to think about this!
Ben Asaro
Post by Ben Asaro »
Hit my first real snag.
I pulled out my BeatStep Pro, sync'd the two together, and off we go ... or so I thought. Turns out that the KSP's MIDI Out will not pass external MIDI, and the MIDI Thru won't send the internal sequencer's MIDI so I'm left with the JV-1080 receiving either the MIDI from the KSP or the BSP.
So, I guess a MIDI Merge box is needed to combine both pieces, which I must say is rather annoyance since they are both made by the same bloody manufacturer and one would think that they can be made to form a single system. :madas:
I'm not a fan of the box count, which will now creep to four, including the JV-1080, though it will double the amount of sequencer tracks available.
I had a moment of hope against hope that the K2000R would have two MIDI inputs, but it doesn't.
Tomorrow is Sunday, so I have another day to decide on my course of action. Worst case I'll order a MIDI merge box from Sweetwater on Monday.
Ben Asaro
Post by Ben Asaro »
Had another chance to give the setup a play today and start tweaking things.
I did an A/B of the internal effects on the Roland vs using my usual RV-500/Blackhole setup and of course there's no comparison in the quality department. I will probably end up setting up two Performances, one for each scenario so I have all of my bases covered, but the external effects do elevate the baisc sound of the Roland quite a bit!
This brings the grand total of boxes from 2 (KSP and JV-1080} to 6 (BSP, KSP, JV-1080, RV-500, Blackhole, MIDI merger) should I decide to go this route. I suspected that some sort of 'box creep' would occur and this would be the absolute maximum I think I could comfortably carry with me.
Ben Asaro
Maybe you need to look for a Kurzweil... ;)
Post by Ben Asaro »
blinddrew wrote:Maybe you need to look for a Kurzweil... ;)
HA!
I won’t have to look far! I think that the fundamental issues (needing more sequencing control and dated effects) would be the same, unfortunately. The size and weight of the K2000R just makes it a no-go for me.
However — I might do this in phases with Phase 1 using the Roland for travel and Phase 2 using the Kurz for at home?
Ben Asaro
Post by Ben Asaro »
Started from a clean slate this morning; factory reset the JV-1080, and worked on a bunch of patches from scratch now that I'm getting used to the way Patch Base works.
Patch Base is definitely a life saver, it works great.
Set up 4 different pluck sounds, the only one I have left is a Blade Runner-ish brass sound. I have all of the current patches running dry and using the RV-500 and Blackhole. For sounds that don't need a pile of delay and reverb, I'll use the other output.
I would imagine that I will probably need to have different performances set up eventually for different sound sets, but for now I'm probably going to set it up with:
Bass
Drums/Percussion
Orchestral Strings
Orchestral Brass
Synth Brass
2x different pluck sounds
That should be plenty of sounds available.
Just have to wait for the MIDI merger to show up and then I can start working out the logistics!
Ben Asaro
