Vinyl Recording - 24-bit, interface Q, processing
Re: Vinyl Recording - 24-bit, interface Q, processing
I saw that one Hugh and thought about buying a PCB but I don't see myself ever going for an MC cartridge so much of it would be redundant. The circuit that I linked to is basically the MM part of that design without the balanced output. The biggest hurdle at the moment is finding a suitable power supply from my collection of junk that I can turn into a dual rail supply.
Posts: 14380 Joined: Mon Sep 10, 2001 12:00 am
I have just bought the balanced phono PCB, (007), from Douglas, who very kindly sorted out the supply problem, which is referenced in the link Hugh kindly placed. So I paid for two in the end, but am very pleased, nonetheless. And I have bought all the parts now: incidentally, if you want the SBS737 transistors, six are used in the MC stage, Nikko Electronics still have some for sale on their eBay site.
Back in 2012, I built another Douglas Self designed phono board, again MM/MC, but relay switched, together with a rather rarely used IEC, relay switched, correction facility. That board featured twenty six polystyrene capacitors and is part of the Elektor 2012 preamplifier, which Douglas told me a few weeks ago, is: "So far as I know it remains the quietest preamp in the world".
I shall post a pic of the completed preamp if you're interested.
OK, I read the sticky about posting pics, so will have a go!
Interior Self design preamp
Front panel Self design preamp
I've replaced the links with the actual pictures — you need to paste links to the actual images (ending with jpg/jpeg) and enclose them within the Img BB codes for the pictures to appear in the post — HR
Very neat!
Forum Aficionado -
Posts: 24664 Joined: Sun Jul 05, 2015 12:00 am
Thanks Hugh, I shall post images like that next time.
Many thanks for the very kind comments about my wiring
Mrs J often comments about my wires, though, not always quite so enthusiastically!
Wow - that wiring is indeed a work of beauty Trevor!
Now if only you'd been able to fit a level meter, you'd have had (wait for it)...
...a loom with a VU
I don't need a coat in this warm weather, so I'll just take my leave quietly
...a loom with a VU
Funkyflash5 wrote:I've not done it myself, but if I were going to, I'd pickup a Radial J33 DI/preamp and then just run that via xlr into my usual interface.
I did exactly that when digitally archiving my vinyl. Worked a treat.
https://www.radialeng.com/product/j33
Martin Walker wrote:Wow - that wiring is indeed a work of beauty Trevor!
...a loom with a VU
We've warned you about that, Walker!!!
- Rich Hanson
Frequent Poster - Posts: 3319 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Martin Walker wrote:Now if only you'd been able to fit a level meter, you'd have had (wait for it)...
...a loom with a VU
Exceptional, Martin, quite exceptional! I've only just finished cleaning up the tea sprayed all over my desk!
Posts: 39042 Joined: Fri Jul 25, 2003 12:00 am
